查看: 1736|回复: 0
密码锁+lcd1602+独立键盘+eprrom继电器 普中单片机
ID:955647 发表于 2021-7-28 20:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#include<intrins.h>
uchar key[]="7777";  //初始密码
#define I2CDelay() {_nop_();_nop_();_nop_();_nop_();}
sbit DOUT = P3^7;
sbit CLK  = P3^6;
sbit DIN  = P3^4;
sbit CS   = P3^5;          //eeprom 定义
sbit lcden=P2^7;
sbit lcdrs=P2^6;
sbit lcdrw=P2^5;     //LCD1602定义
sbit key2=P3^0;  //比较函数
sbit key3=P3^2;  //确认键
uchar code table[]="012345789";
uint bai,num,keynum1,d1,d2,d3,d4;
void delay(uint i)
        while(i--);
void delayms(uint xms)
        uint i,j;
        for(i=xms;i>0;i--)
        for(j=110;j>0;j--);
void SPI_Write(uchar dat)
        uchar i;
        CLK = 0;
        for(i=0; i<8; i++)
                DIN = dat >> 7;
                dat <<= 1;
                CLK = 0;
                CLK = 1;
uint SPI_Read(void)
        uint i, dat=0;
        CLK = 0;
        for(i=0; i<12; i++)
                dat <<= 1;
                CLK = 1;
                CLK = 0;
                dat |= DOUT;
        return dat;
uint Read_AD_Data(uchar cmd)
        uchar i;
        uint AD_Value;
        CLK = 0;
        CS  = 0;
        SPI_Write(cmd);
        for(i=6; i>0; i--);
        CLK = 1;
        _nop_();
        _nop_();
        CLK = 0;
        _nop_();
        _nop_();
        AD_Value=SPI_Read();
        CS = 1;
        return AD_Value;
void write_com(uint com)
        lcdrs=0;
        P0=com;
        lcden=0;
        delayms(5);
        lcden=1;
        delayms(5);
        lcden=0;
void write_date(uint date)
        lcdrs=1;
        P0=date;
        lcden=0;
        delayms(5);
        lcden=1;
        delayms(5);
        lcden=0;
void init_lcd()
        lcden=0;
        lcdrw=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
void datapros()
        uint temp;
        static uchar i;
        if(i==10)
                i=0;
                temp = Read_AD_Data(0x94);
        i++;
void display()
        uint temp;
        bai=temp%1000/100;  //将继电器阻值百位作为每一次输入的密码
         write_com(0x80);
         write_date(table[bai]);
void compare()  //比较函数  比较设定数组和输入数组
        if(d1==key[0]&&d2==key[1]&&d3==key[2]&&d4==key[3])
                write_com(0x80+4);
                write_date('1');  //若每一位数组都相同,则在1602液晶上显示1
                write_com(0x80+5);
                write_date('0'); //若并非每一位数组都相同,则在1602液晶上显示0
void keypro()
        if(key2==0)
                delayms(5);
                if(key2==0)
                        compare();
                while(!key2);
        if(key3==0)
                delayms(5);
                if(key3==0)
                        keynum1++;
                        while(!key3);
                        if(keynum1==1)
                         write_com(0x80+0x40);
                                d1=table[bai];
                                if(keynum1==2)
                                write_com(0x80+0x40+1);
                                d2=table[bai];
                        if(keynum1==3)
                                write_com(0x80+0x40+2);
                                d3=table[bai];
                        if(keynum1==4)
                                write_com(0x80+0x40+3);
                                d4=table[bai];
        init_lcd();
                keypro();
                datapros();
                display();
收藏收藏1 分享淘帖 顶 踩
