查看: 1170|回复: 0
单片机数码管动态显示代码
ID:959863 发表于 2021-8-10 18:35 | 显示全部楼层 |阅读模式
#include<reg52.h>
#defineuint unsigned int
#define  uchar unsigned char
sbitdula=P2^6;
sbitwela=P2^7;
ucharcode table[]={0x06,0x5b,0x4f,0x66,
                    0x6d,0x7d,0x07,0x7f,0x6f,
                    0x77,0x7c,0x39,0x5e,0x79,
                    0x71,0x00,0x80};
ucharcode tablewe[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf};
uintnum,t;
sbitd1=P1^0;
voiddelay(uint);
voidmain()
     TMOD=0x01;
                  TH0=(65536-2000)/256;
                  TL0=(65536-2000)%256;
                  EA=1;
                  ET0=1;
                  TR0=1;
                 num=0;
                                                   if(t=1)
        t=0;
        wela=1;
        P0=tablewe[num];
        wela=0;
        dula=1;
        P0=table[num];
        dula=0;
        delay(10);
        num++;
        if(num==6)
        num=0;
voiddelay(uint b)
    uint a, c;
                 for(a=10;a;a--)
                     for(c=b;c;c--);
void extern0()interrupt 1
     t++;
