查看: 1822|回复: 1
51单片机TM1637驱动程序
ID:917238 发表于 2021-8-12 16:10 来自手机 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
#include<intrins.h>
sbit CLK = P0^0;  //时钟信号
sbit DIO = P0^1;  //数据/地址数据
        //共阴极数码管
unsigned char code SEGData[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//1-9
unsigned char code SEGDataDp[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef}; //有小数点只用于地址0xc1
unsigned char dpFlag = 0; //控制第二个数码管的dp的显示
void TM1637_start( void );
void TM1637_stop( void );
void TM1637_write1Bit(unsigned char mBit);
void TM1637_write1Byte(unsigned char mByte);
void TM1637_writeCammand(unsigned char mData);
void TM1637_writeData(unsigned char addr, unsigned char mData);
void time_set(char hour, char min);
void time_judge( void );
void time_display( void );
void timer0_init( void );
void delay_140us( void );
void delay_1ms(unsigned int i);
unsigned int countTime = 0;
unsigned char time, sec;
struct {
        char shi;
        char ge;
}Hour;
struct {
        char shi;
        char ge;
}Min;
***** 主函数
void main( void )
        timer0_init();
        time_set(5, 0);  //设置5小时倒计时
                time_display();         //显示时间
                if(countTime <= 10)
                        dpFlag = 0;
                if(countTime <= 20)
                        dpFlag = 1;
                        countTime = 0;
                        time_judge();
        if((hour < 0) || (min<0))
                hour = 0;
                min = 0;
        Hour.shi = hour/10;
        Hour.ge = hour%10;
        Min.shi = min/10;
        Min.ge = min%10;
* 名称 : time_judge( void )
* 功能 : 判断时间变化
* 输入 : void
* 输出 : 无
        if(++sec == 60)           //60秒
                sec = 0;
                if((Hour.shi || Hour.ge || Min.shi || Min.ge) && (--Min.ge <= -1))
                        Min.ge = 9;
                        if((Hour.shi) ||(Hour.ge) && (--Min.shi <= -1))
                                Min.shi = 5;
                                if(Hour.shi && (--Hour.ge <= -1))
                                        Hour.ge = 9;
                                        if(--Hour.shi <= -1)
                                                Hour.shi = 0;
                                if((!Hour.shi) && (--Hour.ge <= -1))
                                        Hour.ge = 0;
                        if((!Hour.shi) && (!Hour.ge) && (--Min.shi <= -1))
                                Min.shi = 0;
                if(((!Hour.shi) && (!Hour.ge) && (!Min.shi) ) && (Min.ge <= -1))
                        Min.ge = 0;
* 名称 : void time_display( void )
* 功能 : 显示时间
* 输入 : void
* 输出 : 无
        TM1637_writeCammand(0x44);
        TM1637_writeData(0xc0, SEGData[Hour.shi]);
        if(dpFlag)
                TM1637_writeData(0xc1, SEGDataDp[Hour.ge]); //小数点标志为1则用小数点那个数组
                TM1637_writeData(0xc1, SEGData[Hour.ge]);
        TM1637_writeData(0xc2, SEGData[Min.shi]);
        TM1637_writeData(0xc3, SEGData[Min.ge]);
        TM1637_writeCammand(0x8a);
* 名称 : void TM1637_start( void )
* 功能 : start信号
* 输入 : void
* 输出 : 无
        CLK = 1;
        DIO = 1;
        delay_140us();
        DIO = 0;
        delay_140us();
        CLK = 0;
        delay_140us();
* 名称 : void TM1637_stop( void )
* 功能 : stop信号
* 输入 : void
* 输出 : 无
        CLK = 0;
        delay_140us();
        DIO = 0;
        delay_140us();
        CLK = 1;
        delay_140us();
        DIO = 1;
        delay_140us();
void TM1637_write1Bit(unsigned char mBit )
        CLK = 0;
        delay_140us();
        if(mBit)
                DIO = 1;
                DIO = 0;
        delay_140us();
        CLK        = 1;
        delay_140us();
* 名称 : void TM1637_write1Byte(unsigned char mByte)
* 功能 : 写1byte
* 输入 : unsigned char mByte
* 输出 : 无
        char loop = 0;
        for(loop = 0; loop < 8; loop++)
                TM1637_write1Bit((mByte>>loop)&0x01); //取得最低位
        CLK = 0;
        delay_140us();
        DIO = 1;
        delay_140us();
        CLK = 1;
        delay_140us();
        while(DIO == 1);  //获得应答位
* 名称 : void TM1637_writeCammand(unsigned char mData)
* 功能 : 写指令1byte
* 输入 : unsigned char mData
* 输出 : 无
        TM1637_start();
        TM1637_write1Byte(mData);  //数据
        TM1637_stop();
* 名称 : void TM1637_writeData(unsigned char addr, unsigned char mData)
* 功能 : 固定地址写数据1byte
* 输入 : unsigned char addr, unsigned char mData
* 输出 : 无
        TM1637_start();
        TM1637_write1Byte(addr);  //地址
        TM1637_stop();
        TMOD=0X01;
        TH0=(65535-50000)/256;
        TL0=(65535-50000)%256;
        ET0=1;
        EA=1;
        TR0=1;
* 名称 :
* 功能 : 定时50ms,实际运行中由于指令运行造成的延时,实际时间肯定大于50ms
* 输入 : 无
* 输出 : 无
void timer0_isr() interrupt 1
        TH0=(65535-50000)/256;  //50ms
        TL0=(65535-50000)%256;        //
        countTime++;
* 名称 : Delay_1ms(unsigned int i)
* 功能 : 延时子程序,延时时间为 140us
* 输入 :
* 输出 : 无
    int i;
    for(i=0; i<20; i++)
      _nop_();
* 功能 : 延时子程序,延时时间为 1ms * x
* 输入 : x (延时一毫秒的个数)
* 输出 : 无
void Delay_1ms(unsigned int i)//1ms延时
    unsigned char x,j;
    for(j=0;j<i;j++)
    for(x=0;x<=148;x++);
参与人数 1黑币 +10 收起 理由
admin + 10 共享资料的黑币奖励!
收藏收藏2 分享淘帖 顶 踩
ID:328014 发表于 2021-8-12 16:17 | 只看该作者
楼主你好,有原理图吗?
