查看: 2099|回复: 0
基于51单片机的四驱寻迹小车代码
ID:959863 发表于 2021-8-18 11:28 | 显示全部楼层 |阅读模式
#include <reg51.h>
sbit ENA = P2^0;                    //右
sbit IN1 = P2^1;    //右
sbit IN2 = P2^2;
sbit IN3 = P2^3;   // 左
sbit IN4 = P2^4;
sbit ENB = P2^5;                     //左             //电驱端口配置
sbit left = P1^2;
sbit middle =P1^1;
sbit right =P1^0;           //循迹
unsigned char zkb1 = 0;//定义了一下左边两个轮的占空比
unsigned char zkb2 = 0;//定义了一下右边两个轮的占空比
int t = 0;
void PIT_Init()  //初始化
   EA   = 1;
   TMOD |= 0x01;
   TH0   = (65536 - 200) / 256;
   TL0   = (65536 - 200) % 256;
   ET0   = 1;
   TR0   = 1;
void timer()interrupt 1   // pwm
  TH0 = (65536-200)/256;
  TL0 = (65536-200)%256;
if(t<zkb1)
    ENA = 1;
   ENA = 0;
if(t<zkb2)
    ENB = 1;
   ENB = 0;
t = (t + 1) %50;
void run()
    zkb1  = 20;
    zkb2  = 20;
        IN1 = 0; //右轮正转
    IN2 = 1;
    IN3 = 1; // 左轮正转
    IN4 = 0;
void stop(void)
{   zkb1 = 0;
    zkb2 = 0;
    IN1  = 0;
    IN2  = 0;
    IN3  = 0;
    IN4  = 0;
void leftrun(void)
    zkb1 = 35;
    zkb2 = 35;
        IN1=0;
    IN2=1; //右轮正转
    IN3=0 ;//左轮反转
    IN4=1;
void rightrun(void)
    zkb1 = 35;
    zkb2 = 35;
        IN1=1; //右轮反转
    IN2=0;
    IN3=1;
    IN4=0; //左轮正转
void xunji()//检测到黑线为1高电平
if( (left == 1)&&(middle == 1)&&(right==1) )
    run();
if( (left ==0 )&&(middle == 1)&&(right==0) )
    run();
if( (left ==0 )&&(middle == 0)&&(right==0) )
    run();
if( (left == 0)&&(middle == 1)&&(right==1) )
      rightrun();
if( (left == 0)&&(middle == 0)&&(right==1) )
    rightrun();
if( (left == 1)&&(middle == 1)&&(right==0) )
    leftrun();
if( (left == 1)&&(middle == 0)&&(right==0) )
    leftrun();
if( (left == 1)&&(middle == 0)&&(right==1) )
    leftrun();
run();
PIT_Init();
zkb1 = 20  ;
zkb2 = 20  ;
    run();
  xunji();
参与人数 1黑币 +20 收起 理由
admin + 20 共享资料的黑币奖励!
