LCD1602显示系统真实时钟
#include "stm32f10x.h"
void LCD1602_GPIO_Config(void)
RCC_APB2PeriphClockCmd(LCD1602_CLK, ENABLE);
GPIO_InitTypeDef LCD1602_GPIOStruct;
LCD1602_GPIOStruct.GPIO_Mode = GPIO_Mode_Out_PP;
LCD1602_GPIOStruct.GPIO_Speed = GPIO_Speed_10MHz;
LCD1602_GPIOStruct.GPIO_Pin = LCD1602_E | LCD1602_RS | LCD1602_RW ;
GPIO_Init(LCD1602_GPIO_PORT,&LCD1602_GPIOStruct);
//LCD1602_GPIOStruct.GPIO_Mode = GPIO_Mode_Out_OD;
LCD1602_GPIOStruct.GPIO_Pin = DB0 | DB1 | DB2 |DB3 | DB4 | DB5|
DB6 | DB7 ; //若设置为开漏输出 需要上拉电阻
void LCD1602_WaitReady(void) //检测忙状态
uint8_t sta;
LCD1602_GPIO_PORT->ODR =0x00FF;
RSO(0);
RWO(1);
EO(1);
SysTick_Delay_Us(1);
do{
sta=GPIO_ReadInputDataBit(LCD1602_GPIO_PORT,GPIO_Pin_7);
EO(0);
}while(sta);
void LCD1602_WriteCmd(uint8_t cmd) //写指令
LCD1602_WaitReady();
RSO(0);
RWO(0);
EO(0);
EO(1);
LCD1602_GPIO_PORT->ODR &= (cmd|0xFF00);
EO(0);
SysTick_Delay_Us(400);
void LCD1602_WriteDat(uint8_t dat) //写数据
RSO(1);
RWO(0);
SysTick_Delay_Us(30);
EO(1);
LCD1602_GPIO_PORT->ODR &=(dat|0xFF00);
EO(0);
void LCD1602_SetCursor(uint8_t x, uint8_t y)
uint8_t addr;
if (y == 0) //由输入的屏幕坐标计算显示RAM的地址
addr = 0x00 + x; //第一行字符地址从0x00起始
addr = 0x40 + x; //第二行字符地址从0x40起始
LCD1602_WriteCmd(addr|0x80); //设置RAM地址
void LCD1602_ShowStr(uint8_t x, uint8_t y, uint8_t *str, uint8_t len)
LCD1602_SetCursor(x, y); //设置起始地址
while (len--) //连续写入len个字符数据
LCD1602_WriteDat(*str++);
void LCD1602_Init(void)
LCD1602_GPIO_Config(); //开启GPIO口
LCD1602_WriteCmd(0X38); //16*2显示,5*7点阵,8位数据接口
LCD1602_WriteCmd(0x0C); //显示器开,光标关闭
LCD1602_WriteCmd(0x06); //文字不动,地址自动+1
LCD1602_WriteCmd(0x01); //清屏
int main(void)
{ uint8_t str[8];
RCC_ClocksTypeDef RCC_Clocks; //时钟结构体
SysTick_Init(); //滴答定时器初始化
LCD1602_Init();
RCC_GetClocksFreq(&RCC_Clocks); //获取片上时钟
str[0]=RCC_Clocks.SYSCLK_Frequency/10000000+0x30;
str[1]=RCC_Clocks.SYSCLK_Frequency/1000000%10+0x30;
LCD1602_ShowStr(0,0,"sysclk:",7);
LCD1602_ShowStr(7,0,str,2);
LCD1602_ShowStr(9,0,"MHz",3);
while(1);
void SysTick_Delay_Us( __IO uint32_t us) //us延时函数
uint32_t i;
RCC_GetClocksFreq(&RCC_Clocks); //获取片上真实系统时钟
SysTick_Config(RCC_Clocks.SYSCLK_Frequency/1000000);
for(i=0;i<us;i++)
// 当计数器的值减小到0的时候,CRTL寄存器的位16会置1
while( !((SysTick->CTRL)&(1<<16)) );
// 关闭SysTick定时器
SysTick->CTRL &=~SysTick_CTRL_ENABLE_Msk;
void SysTick_Delay_Ms( __IO uint32_t ms) // ms延时函数
uint32_t i;
SysTick_Config(RCC_Clocks.SYSCLK_Frequency/1000);
for(i=0;i<ms;i++)
// 当置1时,读取该位会清0
// 关闭SysTick定时器
SysTick->CTRL &=~ SysTick_CTRL_ENABLE_Msk;
全部资料51hei附件下载:
滴答定时器LCD1602仿真代码.7z
(189.71 KB, 下载次数: 102)
