proteus仿真电路:
输出波形:
源代码: PS:需要什么波就留什么波,把其他注释掉。你们也可以自己改一下,通过按键控制相应波形输出。谢谢
- //#include <reg51.h>
- //#include <absacc.h>
- //#define uint unsigned int
- //#define DAC0832 XBYTE[0xFEFF]
- //void main(void)
- // uint i;
- // while(1)
- // for(i=0;i<0x100;i++)
- // {DAC0832=i;}
- //} //锯齿波
- //#define uchar unsigned char
- //void main()
- // uchar i;
- // while(1)
- // for(i=0;i<0xff;i++)
- // {DAC0832=i;}
- // for(i=0xff;i>0;i--)
- // {DAC0832=i;}
- //} //三角波
- //uchar code sinbuf[] =
- // 0x80,0x83,0x86,0x89,0x8D,0x90,0x93,0x96,0x99,0x9C,0x9F,0xA2,0xA5,0xA8,0xAB,0xAE,
- // 0xB1,0xB4,0xB7,0xBA,0xBC,0xBF,0xC2,0xC5,0xC7,0xCA,0xCC,0xCF,0xD1,0xD4,0xD6,0xD8,
- // 0xDA,0xDD,0xDF,0xE1,0xE3,0xE5,0xE7,0xE9,0xEA,0xEC,0xEE,0xEF,0xF1,0xF2,0xF4,0xF5,
- // 0xF6,0xF7,0xF8,0xF9,0xFA,0xFB,0xFC,0xFD,0xFD,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- // 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFD,0xFC,0xFB,0xFA,0xF9,0xF8,0xF7,0xF6,
- // 0xF5,0xF4,0xF2,0xF1,0xEF,0xEE,0xEC,0xEA,0xE9,0xE7,0xE5,0xE3,0xE1,0xDF,0xDD,0xDA,
- // 0xD8,0xD6,0xD4,0xD1,0xCF,0xCC,0xCA,0xC7,0xC5,0xC2,0xBF,0xBC,0xBA,0xB7,0xB4,0xB1,
- // 0xAE,0xAB,0xA8,0xA5,0xA2,0x9F,0x9C,0x99,0x96,0x93,0x90,0x8D,0x89,0x86,0x83,0x80,
- // 0x80,0x7C,0x79,0x76,0x72,0x6F,0x6C,0x69,0x66,0x63,0x60,0x5D,0x5A,0x57,0x55,0x51,
- // 0x4E,0x4C,0x48,0x45,0x43,0x40,0x3D,0x3A,0x38,0x35,0x33,0x30,0x2E,0x2B,0x29,0x27,
- // 0x25,0x22,0x20,0x1E,0x1C,0x1A,0x18,0x16,0x15,0x13,0x11,0x10,0x0E,0x0D,0x0B,0x0A,
- // 0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
- // 0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,
- // 0x0A,0x0B,0x0D,0x0E,0x10,0x11,0x13,0x15,0x16,0x18,0x1A,0x1C,0x1E,0x20,0x22,0x25,
- // 0x27,0x29,0x2B,0x2E,0x30,0x33,0x35,0x38,0x3A,0x3D,0x40,0x43,0x45,0x48,0x4C,0x4E,
- // 0x51,0x55,0x57,0x5A,0x5D,0x60,0x63,0x66,0x69,0x6C,0x6F,0x72,0x76,0x79,0x7C,0x7E
- //void main()
- // uchar i;
- // while(1)
- // for(i=0;i<=0xff;i++)
- // DAC0832=sinbuf[i];
- //} //正弦波
- #include <reg51.h>
- #include <absacc.h>
- #define uchar unsigned char
- #define DAC0832 XBYTE[0xFEFF]
- void delay()
- uchar i;
- for(i=0;i<0xff;i++)
- void main()
- uchar i;
- while(1)
- DAC0832=0;
- delay();
- DAC0832=0xff;
- delay();
- } //方波
