查看: 1535|回复: 0
LCD12864简易计算器
ID:995364 发表于 2021-12-21 19:29 | 显示全部楼层 |阅读模式
#include<reg52.h>
#define K P2
typedef unsigned int u16;
typedef unsigned char u8;
sbit RS = P1^0;
sbit RW = P1^1;
sbit E =  P1^2;
void delay(int i)
while(i--);
int a;
void AJ()        //按键函数
int b=0;
K=0x0f;
  if(K!=0x0f)
           delay(1000);
           if(K!=0x0f)
                  switch(K)
                    case 0x07: a=0;break;
                        case 0x0b: a=1;break;
                        case 0x0d: a=2;break;
                        case 0x0e: a=3;break;
                    K=0xf0;
                   if(K!=0xf0)
                   delay(1000);
                  if(K!=0xf0)
                          switch(K)
                            case 0x70: a=a;break;
                                 case 0xb0: a=a+4;break;
                                case 0xd0: a=a+8;break;
                                case 0xe0: a=a+12;break;
               while(b<50&&K!=0xf0);
                         delay(100);
                         b++;
u8 code  SHU[]={0x31,0x32,0x33,0x2b,0x34,0x35,0x36,0x2d,0x37,0x38,0x39,0x2a,0x2f,0x30,0x3d};
{  1  2  3    +
   4  5  6    -
   7  8  9    *
   /  0  =
//u8 code        FU[]={0x2b,0x2d,0x2a,0x2f};                // + - * /
/*LCD12864程序函数*/
void LCD12864_SetPos(unsigned char x,unsigned char y) ;
void LCD12864_WDAT(unsigned char dat);
void LCD12864_WCMD(unsigned char cmd);
void LCD12864_BusyCheck();
void LCD12846_DisHZ_Str(unsigned char *s);
void  YX()
  char m[100];     //m为第一个数
char n[100];         //n为第二个数
      int i,j,b=0,c=0;
          int q,h;
          int d=-1;
          int s1=0,s2=0;
   for(i=2;i>1;i++)
          LCD12864_SetPos(0,b);
          b++;
          if(a)
           AJ();
           d=a;
           if(d!=-1)
           LCD12864_WDAT(SHU[a]);
           if(a==15)
                     for(;s1>0;s1--)
                    q=q*10+m[s1-1];
                  for(;s2>0;s2--)
                  h=h*10+n[s2-1];
                  if(j==3)
                  LCD12864_WDAT(SHU[14]);
                   LCD12864_WDAT(q+h);
                   else if(j==7)
                   LCD12864_WDAT(q-h);
                              else if(j==11)
                   LCD12864_WDAT(q*h);
                              else if(j==12)
                   LCD12864_WDAT(q/h);
           if(a!=3&&a!=7&&a!=11&&a!=12)
                   m[i-2]=a;
                s1++;
           c=1;
           i=2;
           j=a;
            if(c==1)
                        n[i-2]=a;
                        s2++;
           a=16;
           if(a==15)
           LCD12864_WCMD(0x0c);
               LCD12864_WCMD(0x30);
        delay(10000);
        d=-1;
//    LCD12846_DisHZ_Str("欢迎使用科学计算器");
//   LCD12864_SetPos(0,0);
          YX();
//        LCD12864_WCMD(0x0c);
//        LCD12864_WCMD(0x30);
//  LCD12864_SetPos(0,b);
//        b++;
/*            AJ();
           m[j]=a;
           j++;
          //for(i=1;i>1;i++)
           delay(1000);
//                   AJ();
//                   LCD12864_SetPos(0,0+b);
//                b++;
//                LCD12864_WDAT(SHU[a]);
//                if(a==14)
//                LCD12864_SetPos(1,0);
        /*LCD12864_WDAT(SHU[0]);
        LCD12864_WDAT(0x04);
        LCD12864_WDAT(0x05 + '0'); //'0' = 48 = 0x30
        LCD12864_WDAT(0x06);
        LCD12846_DisHZ_Str("李朝贺");
/*        while(1)
        if(a==15)
        break;
        unsigned char temp;
        P0 = 0xff;
        RS = 0;
        RW = 1;
                E = 1;
                temp = P0;
                E = 0;
                if((temp & 0x80) == 0)
                        break;
        RS = 0;
        RW = 0;
        P0 = cmd;
        E = 1;
        E = 0;
        RS = 1;
        RW = 0;
        P0 = dat;
        E = 1;
        E = 0;
        unsigned char pos;
        switch(x)
                case 0 : x = 0x80;break;
                case 1 : x = 0x90;break;
                case 2 : x = 0x88;break;
                case 3 : x = 0x98;break;
                default:break;
        pos = x + y; //x范围0-3  y范围0-7
        LCD12864_WCMD(pos);
        while(*s)
                LCD12864_WDAT(*s++);
