- #include "stm32f10x.h"
- #include "AHT20-21_DEMO_V1_3.h"
- void Delay_N10us(uint32_t t)//延时函数
- uint32_t k;
- while(t--)
- for (k = 0; k < 2; k++);//110
- void SensorDelay_us(uint32_t t)//延时函数
- for(t = t-2; t>0; t--)
- Delay_N10us(1);
- void Delay_4us(void) //延时函数
- Delay_N10us(1);
- Delay_N10us(1);
- Delay_N10us(1);
- Delay_N10us(1);
- void Delay_5us(void) //延时函数
- Delay_N10us(1);
- Delay_N10us(1);
- Delay_N10us(1);
- Delay_N10us(1);
- Delay_N10us(1);
- void Delay_1ms(uint32_t t) //延时函数
- while(t--)
- SensorDelay_us(1000);//////延时1ms
- void AHT20_Clock_Init(void) //延时函数
- RCC_APB2PeriphClockCmd(CC_APB2Periph_GPIOB,ENABLE);
- void SDA_Pin_Output_High(void) //将PB15配置为输出 , 并设置为高电平, PB15作为I2C的SDA
- GPIO_InitTypeDef GPIO_InitStruct;
- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;//推挽输出
- GPIO_InitStruct.GPIO_Pin = GPIO_Pin_15;
- GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOB,& GPIO_InitStruct);
- GPIO_SetBits(GPIOB,GPIO_Pin_15);
- void SDA_Pin_Output_Low(void) //将P15配置为输出 并设置为低电平//SDA配置为浮空输出
- GPIO_ResetBits(GPIOB,GPIO_Pin_15);
- void SDA_Pin_IN_FLOATING(void) //SDA配置为浮空输入
- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN_FLOATING;//
- GPIO_Init( GPIOB,&GPIO_InitStruct);
- void SCL_Pin_Output_High(void) //SCL输出高电平,P14作为I2C的SCL
- GPIO_SetBits(GPIOB,GPIO_Pin_14);
- void SCL_Pin_Output_Low(void) //SCL输出低电平
- GPIO_ResetBits(GPIOB,GPIO_Pin_14);
- void Init_I2C_Sensor_Port(void) //初始化I2C接口,输出为高电平
- GPIO_SetBits(GPIOB,GPIO_Pin_15);//输出高电平
- GPIO_InitStruct.GPIO_Pin = GPIO_Pin_14;
- void I2C_Start(void) //I2C主机发送START信号
- SDA_Pin_Output_High();
- SensorDelay_us(8);
- SCL_Pin_Output_High();
- SDA_Pin_Output_Low();
- SCL_Pin_Output_Low();
- void AHT20_WR_Byte(uint8_t Byte) //往AHT20写一个字节
- uint8_t Data,N,i;
- Data=Byte;
- i = 0x80;
- for(N=0;N<8;N++)
- Delay_4us();
- if(i&Data)
- else
- Delay_4us();
- Data <<= 1;
- SDA_Pin_IN_FLOATING();
- uint8_t AHT20_RD_Byte(void)//从AHT20读取一个字节
- uint8_t Byte,i,a;
- Byte = 0;
- for(i=0;i<8;i++)
- Delay_5us();
- a=0;
- if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_15)) a=1;
- Byte = (Byte<<1)|a;
- Delay_5us();
- return Byte;
- uint8_t Receive_ACK(void) //看AHT20是否有回复ACK
- uint16_t CNT;
- CNT = 0;
- while((GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_15)) && CNT < 100)
- CNT++;
- if(CNT == 100)
- return 0;
- return 1;
- void Send_ACK(void) //主机回复ACK信号
- void Send_NOT_ACK(void) //主机不回复ACK
- void Stop_I2C(void) //一条协议结束
- uint8_t AHT20_Read_Status(void)//读取AHT20的状态寄存器
- uint8_t Byte_first;
- I2C_Start();
- AHT20_WR_Byte(0x71);
- Receive_ACK();
- Byte_first = AHT20_RD_Byte();
- Send_NOT_ACK();
- Stop_I2C();
- return Byte_first;
- uint8_t AHT20_Read_Cal_Enable(void) //查询cal enable位有没有使能
- uint8_t val = 0;//ret = 0,
- val = AHT20_Read_Status();
- if((val & 0x68)==0x08)
- return 1;
- else return 0;
- void AHT20_SendAC(void) //向AHT20发送AC命令
- I2C_Start();
- AHT20_WR_Byte(0x70);
- Receive_ACK();
- AHT20_WR_Byte(0xac);//0xAC采集命令
- Receive_ACK();
- AHT20_WR_Byte(0x33);
- Receive_ACK();
- AHT20_WR_Byte(0x00);
- Receive_ACK();
- Stop_I2C();
- //CRC校验类型:CRC8/MAXIM
- //多项式:X8+X5+X4+1
- //Poly:0011 0001 0x31
- //高位放到后面就变成 1000 1100 0x8c
- //C现实代码:
- uint8_t Calc_CRC8(uint8_t *message,uint8_t Num)
- uint8_t i;
- uint8_t byte;
- uint8_t crc=0xFF;
- for(byte=0; byte<Num; byte++)
- crc^=(message[byte]);
- for(i=8;i>0;--i)
- if(crc&0x80) crc=(crc<<1)^0x31;
- else crc=(crc<<1);
- return crc;
- void AHT20_Read_CTdata(uint32_t *ct) //没有CRC校验,直接读取AHT20的温度和湿度数据
- volatile uint8_t Byte_1th=0;
- volatile uint8_t Byte_2th=0;
- volatile uint8_t Byte_3th=0;
- volatile uint8_t Byte_4th=0;
- volatile uint8_t Byte_5th=0;
- volatile uint8_t Byte_6th=0;
- uint32_t RetuData = 0;
- uint16_t cnt = 0;
- AHT20_SendAC();//向AHT10发送AC命令
- Delay_1ms(80);//延时80ms左右
- cnt = 0;
- while(((AHT20_Read_Status()&0x80)==0x80))//直到状态bit[7]为0,表示为空闲状态,若为1,表示忙状态
- SensorDelay_us(1508);
- if(cnt++>=100)
- break;
- I2C_Start();
- Receive_ACK();
- Byte_1th = AHT20_RD_Byte();//状态字,查询到状态为0x98,表示为忙状态,bit[7]为1;状态为0x1C,或者0x0C,或者0x08表示为空闲状态,bit[7]为0
- Send_ACK();
- Byte_2th = AHT20_RD_Byte();//湿度
- Send_ACK();
- Byte_3th = AHT20_RD_Byte();//湿度
- Send_ACK();
- Byte_4th = AHT20_RD_Byte();//湿度/温度
- Send_ACK();
- Byte_5th = AHT20_RD_Byte();//温度
- Send_ACK();
- Byte_6th = AHT20_RD_Byte();//温度
- Send_NOT_ACK();
- Stop_I2C();
- RetuData = (RetuData|Byte_2th)<<8;
- RetuData = (RetuData|Byte_3th)<<8;
- RetuData = (RetuData|Byte_4th);
- RetuData =RetuData >>4;
- ct[0] = RetuData;//湿度
- RetuData = 0;
- RetuData = (RetuData|Byte_4th)<<8;
- RetuData = (RetuData|Byte_5th)<<8;
- RetuData = (RetuData|Byte_6th);
- RetuData = RetuData&0xfffff;
- ct[1] =RetuData; //温度
- void AHT20_Read_CTdata_crc(uint32_t *ct) //CRC校验后,读取AHT20的温度和湿度数据
- volatile uint8_t Byte_7th=0;
- uint16_t cnt = 0;
- // uint8_t CRCDATA=0;
- uint8_t CTDATA[6]={0};//用于CRC传递数组
- cnt = 0;
- if(cnt++>=100)
- break;
- I2C_Start();
- Receive_ACK();
- CTDATA[0]=Byte_1th = AHT20_RD_Byte();//状态字,查询到状态为0x98,表示为忙状态,bit[7]为1;状态为0x1C,或者0x0C,或者0x08表示为空闲状态,bit[7]为0
- Send_ACK();
- CTDATA[1]=Byte_2th = AHT20_RD_Byte();//湿度
- Send_ACK();
- CTDATA[2]=Byte_3th = AHT20_RD_Byte();//湿度
- Send_ACK();
- CTDATA[3]=Byte_4th = AHT20_RD_Byte();//湿度/温度
- Send_ACK();
- CTDATA[4]=Byte_5th = AHT20_RD_Byte();//温度
- Send_ACK();
- CTDATA[5]=Byte_6th = AHT20_RD_Byte();//温度
- Send_ACK();
- Byte_7th = AHT20_RD_Byte();//CRC数据
- Send_NOT_ACK(); //注意: 最后是发送NAK
- Stop_I2C();
- if(Calc_CRC8(CTDATA,6)==Byte_7th)
- RetuData = 0;
- else
- ct[0]=0x00;
- ct[1]=0x00;//校验错误返回值,客户可以根据自己需要更改
- }//CRC数据
- void AHT20_Init(void) //初始化AHT20
- Init_I2C_Sensor_Port();
- I2C_Start();
- Receive_ACK();
- AHT20_WR_Byte(0xa8);//0xA8进入NOR工作模式
- Receive_ACK();
- Receive_ACK();
- Receive_ACK();
- Stop_I2C();
- Delay_1ms(10);//延时10ms左右
- I2C_Start();
- Receive_ACK();
- AHT20_WR_Byte(0xbe);//0xBE初始化命令,AHT20的初始化命令是0xBE, AHT10的初始化命令是0xE1
- Receive_ACK();
- AHT20_WR_Byte(0x08);//相关寄存器bit[3]置1,为校准输出
- Receive_ACK();
- Receive_ACK();
- Stop_I2C();
- void JH_Reset_REG(uint8_t addr)
- uint8_t Byte_first,Byte_second,Byte_third,Byte_fourth;
- I2C_Start();
- AHT20_WR_Byte(0x70);//原来是0x70
- Receive_ACK();
- AHT20_WR_Byte(addr);
- Receive_ACK();
- Receive_ACK();
- Receive_ACK();
- Stop_I2C();
- Delay_1ms(5);//延时5ms左右
- I2C_Start();
- AHT20_WR_Byte(0x71);//
- Receive_ACK();
- Send_ACK();
- Byte_second = AHT20_RD_Byte();
- Send_ACK();
- Byte_third = AHT20_RD_Byte();
- Send_NOT_ACK();
- Stop_I2C();
- I2C_Start();
- AHT20_WR_Byte(0x70);///
- Receive_ACK();
- AHT20_WR_Byte(0xB0|addr);////寄存器命令
- Receive_ACK();
- AHT20_WR_Byte(Byte_second);
- Receive_ACK();
- AHT20_WR_Byte(Byte_third);
- Receive_ACK();
- Stop_I2C();
- Byte_second=0x00;
- Byte_third =0x00;
- void AHT20_Start_Init(void)
- JH_Reset_REG(0x1b);
- JH_Reset_REG(0x1c);
- JH_Reset_REG(0x1e);
- int32_t main(void)
- uint32_t CT_data[2];
- volatile int c1,t1;
- /**///①刚上电,产品芯片内部就绪需要时间,延时100~500ms,建议500ms
- Delay_1ms(500);
- /**///②上电第一次发0x71读取状态字,判断状态字是否为0x18,如果不是0x18,进行寄存器初始化
- if((AHT20_Read_Status()&0x18)!=0x18)
- AHT20_Start_Init(); //重新初始化寄存器
- Delay_1ms(10);
- /**///③根据客户自己需求发测量命令读取温湿度数据,当前while(1)循环发测量命令读取温湿度数据,仅供参考
- while(1)
- AHT20_Read_CTdata(CT_data); //不经过CRC校验,直接读取AHT20的温度和湿度数据 推荐每隔大于1S读一次
- //AHT20_Read_CTdata_crc(CT_data); //crc校验后,读取AHT20的温度和湿度数据
- c1 = CT_data[0]*100*10/1024/1024; //计算得到湿度值c1(放大了10倍)
- t1 = CT_data[1]*200*10/1024/1024-500;//计算得到温度值t1(放大了10倍)
- ////下一步客户处理显示数据,
复制代码- #ifndef _AHT20_DEMO_
- #define _AHT20_DEMO_
- void Delay_N10us(uint32_t t);//延时函数
- void SensorDelay_us(uint32_t t);//延时函数
- void Delay_4us(void); //延时函数
- void Delay_5us(void); //延时函数
- void Delay_1ms(uint32_t t);
- void AHT20_Clock_Init(void); //延时函数
- void SDA_Pin_Output_High(void) ; //将PB15配置为输出 , 并设置为高电平, PB15作为I2C的SDA
- void SDA_Pin_Output_Low(void); //将P15配置为输出 并设置为低电平
- void SDA_Pin_IN_FLOATING(void); //SDA配置为浮空输入
- void SCL_Pin_Output_High(void); //SCL输出高电平,P14作为I2C的SCL
- void SCL_Pin_Output_Low(void); //SCL输出低电平
- void Init_I2C_Sensor_Port(void); //初始化I2C接口,输出为高电平
- void I2C_Start(void); //I2C主机发送START信号
- void AHT20_WR_Byte(uint8_t Byte); //往AHT20写一个字节
- uint8_t AHT20_RD_Byte(void);//从AHT20读取一个字节
- uint8_t Receive_ACK(void); //看AHT20是否有回复ACK
- void Send_ACK(void) ; //主机回复ACK信号
- void Send_NOT_ACK(void); //主机不回复ACK
- void Stop_I2C(void); //一条协议结束
- uint8_t AHT20_Read_Status(void);//读取AHT20的状态寄存器
- uint8_t AHT20_Read_Cal_Enable(void); //查询cal enable位有没有使能
- void AHT20_SendAC(void); //向AHT20发送AC命令
- uint8_t Calc_CRC8(uint8_t *message,uint8_t Num);
- void AHT20_Read_CTdata(uint32_t *ct); //没有CRC校验,直接读取AHT20的温度和湿度数据
- void AHT20_Read_CTdata_crc(uint32_t *ct); //CRC校验后,读取AHT20的温度和湿度数据
- void AHT20_Init(void); //初始化AHT20
- void JH_Reset_REG(uint8_t addr);///重置寄存器
- void AHT20_Start_Init(void);///上电初始化进入正常测量状态
