- #include "stm32f10x.h"
- #include "ili9325.h"
- void DataToWrite(u16 data)
- GPIOB->ODR=((GPIOB->ODR&0x00ff)|(data&0xff00));
- Clr_nWr;
- Set_nWr;
- GPIOB->ODR=((GPIOB->ODR&0x00ff)|(data<<8));
- * 函数名:LCD_GPIO_Config
- * 描述 :根据FSMC配置LCD的I/O
- * 输入 :无
- * 输出 :无
- * 调用 :内部调用
- static void LCD_GPIO_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- /* Enable the FSMC Clock */
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
- /* config lcd gpio clock base on FSMC */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE , ENABLE);
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- /* config tft back_light gpio base on the PT4101 */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- /* config tft BL gpio */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 ;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- /* config tft data lines base on FSMC
- * data lines,FSMC-D0~D15: PD 14 15 0 1,PE 7 8 9 10 11 12 13 14 15,PD 8 9 10
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_8 | GPIO_Pin_9 |
- GPIO_Pin_10 | GPIO_Pin_14 | GPIO_Pin_15;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 |
- GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 |
- GPIO_Pin_15;
- GPIO_Init(GPIOE, &GPIO_InitStructure);
- /* config tft control lines base on FSMC
- * PD4-FSMC_NOE :LCD-RD
- * PD5-FSMC_NWE :LCD-WR
- * PD7-FSMC_NE1 :LCD-CS
- * PD11-FSMC_A16 :LCD-DC
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 ;
- /* tft control gpio init */
- GPIO_SetBits(GPIOD, GPIO_Pin_13); // RST
- GPIO_SetBits(GPIOD, GPIO_Pin_4); // RD = 1
- GPIO_SetBits(GPIOD, GPIO_Pin_5); // WR = 1
- GPIO_SetBits(GPIOD, GPIO_Pin_11); // RS
- GPIO_SetBits(GPIOD, GPIO_Pin_7); // CS = 1
- GPIO_SetBits(GPIOC, GPIO_Pin_5); // BL = 1
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //按键 OK
- // right up left down
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_1 | GPIO_Pin_5 | GPIO_Pin_6;
- * 函数名:LCD_FSMC_Config
- * 描述 :LCD FSMC 模式配置
- * 输入 :无
- * 输出 :无
- * 调用 :内部调用
- static void LCD_FSMC_Config(void)
- FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure;
- FSMC_NORSRAMTimingInitTypeDef p;
- p.FSMC_AddressSetupTime = 0x02; //地址建立时间
- p.FSMC_AddressHoldTime = 0x00; //地址保持时间
- p.FSMC_DataSetupTime = 0x05; //数据建立时间
- p.FSMC_BusTurnAroundDuration = 0x00;
- p.FSMC_CLKDivision = 0x00;
- p.FSMC_DataLatency = 0x00;
- p.FSMC_AccessMode = FSMC_AccessMode_B; // 一般使用模式B来控制LCD
- FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;
- FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
- FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_NOR;
- FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
- FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
- FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
- FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
- FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
- FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
- FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
- FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
- FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
- FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
- FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
- FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
- /* Enable FSMC Bank1_SRAM Bank */
- FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);
- volatile void LCD_delay(char j)
- volatile u16 i;
- while(j--)
- for(i=7200;i>0;i--);
- static void LCD_Rst(void)
- GPIO_ResetBits(GPIOD, GPIO_Pin_13);
- LCD_delay(10);
- GPIO_SetBits(GPIOD, GPIO_Pin_13 );
- LCD_delay(10);
- static void WriteComm(u16 CMD)
- *(__IO u16 *) (Bank1_LCD_C) = CMD;
- static void WriteData(u16 tem_data)
- *(__IO u16 *) (Bank1_LCD_D) = tem_data;
- Lcd初始化函数
- void Lcd_Initialize(void)
- LCD_GPIO_Config();
- LCD_FSMC_Config();
- LCD_delay(20);
- LCD_Rst();
- WriteComm(0x11);
- LCD_delay(20);
- WriteComm(0xD0);
- WriteData(0x07);
- WriteData(0x42);
- WriteData(0x18);
- WriteComm(0xD1);
- WriteData(0x00);
- WriteData(0x07);//07
- WriteData(0x10);
- WriteComm(0xD2);
- WriteData(0x01);
- WriteData(0x02);
- WriteComm(0xC0);
- WriteData(0x10);
- WriteData(0x3B);
- WriteData(0x00);
- WriteData(0x02);
- WriteData(0x11);
- WriteComm(0xC5);
- WriteData(0x03);
- WriteComm(0x00C8);//Gamma Setting,有12个参数,P114
- WriteData(0x0000);//P114
- WriteData(0x0014);//P114
- WriteData(0x0033);//P114
- WriteData(0x0010);//P114
- WriteData(0x0016);//P114
- WriteData(0x0044);//P114
- WriteData(0x0036);//P114
- WriteData(0x0077);//P114
- WriteData(0x000F);//P114
- WriteComm(0x3A);
- WriteData(0x55);
- WriteComm(0x2A);
- WriteData(0x00);
- WriteData(0x00);
- WriteData(0x01);
- WriteData(0x3F);
- WriteComm(0x2B);
- WriteData(0x00);
- WriteData(0x00);
- WriteData(0x01);
- WriteData(0xE0);
- LCD_delay(120);
- WriteComm(0x29);
- WriteComm(0x2c);
- WriteComm(0x36); //Set_address_mode
- WriteData(0x28); //横屏,从左下角开始,从左到右,从下到上
- Lcd_Light_ON;
- // Lcd_ColorBox(0,0,320,480,Yellow);Delay(5000000);
- // Lcd_ColorBox(0,0,320,480,Blue);Delay(5000000);
- // Lcd_ColorBox(0,0,320,480,Red);Delay(5000000);
- // Lcd_ColorBox(0,0,320,480,Green);Delay(5000000);
- // Lcd_ColorBox(0,0,320,480,Magenta);Delay(5000000);
- // Lcd_ColorBox(0,0,320,480,Cyan);Delay(5000000);
- // Lcd_ColorBox(0,0,320,480,White);Delay(5000000);
- 函数名:Lcd写命令函数
- 功能:向Lcd指定位置写入应有命令或数据
- 入口参数:Index 要寻址的寄存器地址
- ConfigTemp 写入的数据或命令值
- void LCD_WR_REG(u16 Index,u16 CongfigTemp)
- *(__IO u16 *) (Bank1_LCD_C) = Index;
- *(__IO u16 *) (Bank1_LCD_D) = CongfigTemp;
- 函数名:Lcd写开始函数
- 功能:控制Lcd控制引脚 执行写操作
- void Lcd_WR_Start(void)
- *(__IO u16 *) (Bank1_LCD_C) = 0x2C;
- void BlockWrite(unsigned int Xstart,unsigned int Xend,unsigned int Ystart,unsigned int Yend)
- //ILI9481
- Ystart += 24;
- Yend += 24;
- WriteComm(0x2a);
- WriteData(Xstart>>8);
- WriteData(Xstart&0xff);
- WriteData(Xend>>8);
- WriteData(Xend&0xff);
- WriteComm(0x2b);
- WriteData(Ystart>>8);
- WriteData(Ystart&0xff);
- WriteData(Yend>>8);
- WriteData(Yend&0xff);
- WriteComm(0x2c);
- u16 GetPoint(u16 x,u16 y)
- volatile u16 a;
- WriteComm(0x2a);
- WriteData(x>>8);
- WriteData(x&0xff);
- WriteComm(0x2b);
- WriteData(y>>8);
- WriteData(y&0xff);
- a=0;a=0;a=0;a=0;a=0;
- WriteComm(0x2E);
- a=0;a=0;a=0;a=0;a=0;a=0;
- a = *(__IO u16 *) (Bank1_LCD_D);
- return a;
- // return (a&0xf800)|((a&0x03f0)<<1)|((a&0x3)<<3)|(b>>13);
- 函数名:Lcd块选函数
- 功能:选定Lcd上指定的矩形区域
- 注意:xStart和 yStart随着屏幕的旋转而改变,位置是矩形框的四个角
- 入口参数:xStart x方向的起始点
- ySrart y方向的终止点
- xLong 要选定矩形的x方向长度
- yLong 要选定矩形的y方向长度
- 返回值:无
- void Lcd_ColorBox(u16 xStart,u16 yStart,u16 xLong,u16 yLong,u16 Color)
- u32 temp;
- BlockWrite(xStart,xStart+xLong-1,yStart,yStart+yLong-1);
- for (temp=0; temp<xLong*yLong; temp++)
- *(__IO u16 *) (Bank1_LCD_D) = Color>>8;
- *(__IO u16 *) (Bank1_LCD_D) = Color;
- 函数名:Lcd写开始函数
- 入口参数:无
- 返回值:无
- void Lcd_CMD_WR_Start(void)
- Clr_Cs;
- Clr_Rs;
- DataToWrite(0x0000);
- Clr_nWr;
- Set_nWr;
- Set_Rs;
- 函数名:Lcd全屏擦除函数
- 功能:将Lcd整屏擦为指定颜色
- 入口参数:color 指定Lcd全屏颜色 RGB(5-6-5)
- 返回值:无
- void Lcd_Clear(u16 Color)
- u32 temp;
- Lcd_Start();
- if((Color>>8)==(Color&0x00ff))
- DataToWrite(Color);
- for (temp = 0; temp < 76800*2-1; temp++)
- Clr_nWr;
- Set_nWr;
- else
- for (temp = 0; temp < 76800; temp++)
- Clr_nWr;
- Set_nWr;
- 函数名:Lcd光标起点定位函数
- 功能:指定320240液晶上的一点作为写数据的起始点
- 入口参数:x 坐标 0~239
- y 坐标 0~319
- 返回值:无
- void Lcd_SetCursor(u16 x,u16 y)
- //坐标调转
- LCD_WR_REG(0x20,y);//水平坐标
- LCD_WR_REG(0x21,x);//垂直坐标
- 函数名:Lcd块选函数
- 功能:选定Lcd上指定的矩形区域
- ySrart y方向的终止点
- xLong 要选定矩形的x方向长度
- yLong 要选定矩形的y方向长度
- 返回值:无
- void Lcd_SetBox(u16 xStart,u16 yStart,u16 xLong,u16 yLong,u16 x_offset,u16 y_offset)
- Lcd_SetCursor(xStart+x_offset,yStart+y_offset);
- LCD_WR_REG(0x0050,yStart+y_offset);//水平GRAM起始位置
- LCD_WR_REG(0x0051,yStart+yLong-1+y_offset);//水平GRAM终止位置
- //x,y坐标对调
- LCD_WR_REG(0x0052,xStart+x_offset);//垂直 GRAM起始位置
- LCD_WR_REG(0x0053,xStart+xLong-1+x_offset);//垂直GRAM终止位置
- void Lcd_ClearCharBox(u16 x,u16 y,u16 Color)
- u32 temp;
- Lcd_SetBox(x*8,y*16,8,16,0,0);
- Lcd_WR_Start();
- Set_Rs;
- for (temp=0; temp < 128; temp++)
- Clr_nWr;
- Set_nWr;
- void DrawPixel(u16 x, u16 y, int Color)
- BlockWrite(x,x,y,y);
- 函数名:Lcd图像填充100*100
- 功能:向Lcd指定位置填充图像
- void LCD_Fill_Pic(u16 x, u16 y,u16 pic_H, u16 pic_V, const unsigned char* pic)
- unsigned long i;
- unsigned int j;
- // WriteComm(0x36); //Set_address_mode
- // WriteData(0x08); //横屏,从左下角开始,从左到右,从下到上
- BlockWrite(x,x+pic_H-1,y,y+pic_V-1);
- for (i = 0; i < pic_H*pic_V*2; i++)
- // j=pic[i];
- // j=j<<8;
- // j=j+pic[i+1];
- *(__IO u16 *) (Bank1_LCD_D) = pic[i];
- // WriteData(0x68);
- //开始全屏写,设置地址
- void Lcd_Start(void)
- Lcd_SetCursor(0,239);
- LCD_WR_REG(0x0050,0x00);//垂直 GRAM起始位置
- LCD_WR_REG(0x0051,239);//垂直GRAM终止位置
- LCD_WR_REG(0x0052,0x00);//水平GRAM起始位置
- LCD_WR_REG(0x0053,319);//水平GRAM终止位置
- Lcd_WR_Start();
- * 名 称:void Put32_32HZ(u16 x,u16 y,const unsigned char *c,u16 charColor,u16 bkColor,u8 flag)
- * 功 能:在指定座标显示一个点阵的汉字
- * 入口参数:x 行座标
- * y 列座标
- * charColor 字符的颜色
- * bkColor 字符背景颜色
- * 出口参数:无
- * 说 明:显示范围限定为可显示的ascii码
- * 调用方法:ssd1289_PutChar(10,10,'a',0x0000,0xffff, 1);
- // void Put32_32HZ(u16 x,u16 y,const unsigned char *c,u16 charColor,u16 bkColor,u8 flag)
- // u8 i,j,k;
- // u8 tmp_char=0;
- // Lcd_SetBox(x,y,32,32,0,0);
- // Lcd_WR_Start();
- // Set_Rs;
- // for (i=31;i>=0;i--)//32行
- // for (j=3;j>=0;j--)//每行4字节
- // tmp_char=c[4*i+j];
- // for (k=0;k<8;k++)//每字节8位
- // if (((tmp_char << k) & 0x80) == 0x80)
- // DataToWrite(charColor);
- // Clr_nWr;
- // Set_nWr;
- // else
- // if(flag){
- // DataToWrite(bkColor);
- // Clr_nWr;
- // Set_nWr;
- // Set_Cs;
- * 名 称:void Put16_16HZ(u16 x,u16 y,const unsigned char *c,u16 charColor,u16 bkColor,u8 flag)
- * 入口参数:x 行座标
- * y 列座标
- * charColor 字符的颜色
- * bkColor 字符背景颜色
- * 出口参数:无
- void Put16_16HZ(u16 x,u16 y,const unsigned char *c,u16 charColor,u16 bkColor,u8 flag)
- char i,j,k;
- u8 tmp_char=0;
- Lcd_SetBox(x,y,16,16,0,0);
- Lcd_SetCursor(x,y+15);
- Lcd_WR_Start();
- Set_Rs;
- for (i=0;i<16;i++)//16行
- for (j=0;j<2;j++)//每行2字节
- tmp_char=c[2*(15-i)+j];
- for (k=0;k<8;k++)//每字节8位
- if (((tmp_char << k) & 0x80) == 0x80)
- DataToWrite(charColor);
- Clr_nWr;
- Set_nWr;
- else
- DataToWrite(bkColor);
- Clr_nWr;
- Set_nWr;
- Set_Cs;
- void Put8_16Char(u16 x,u16 y,const unsigned char *ascii_8x16,u8 ch,u16 charColor,u16 bkColor,u8 flag)
- char i=0,j=0;
- u8 tmp_char=0;
- Lcd_SetBox(x,y,8,16,0,0);
- Lcd_WR_Start();
- Set_Rs;
- tmp_char=ascii_8x16[((ch-0x20)*16)+(15-i)];
- for (j=0;j<8;j++)
- if(((tmp_char<<j) & 0x80) == 0x80)
- Clr_nWr;
- Set_nWr;
- else
- DataToWrite(bkColor); //0x7BEF
- Clr_nWr;
- Set_nWr;
- Set_Cs;
- void Put16x32Num(u16 x,u16 y,const unsigned char *num_16x32,u8 ch,u16 charColor,u16 bkColor,u8 flag)
- char i=0,j=0,k=0;
- u8 tmp_char=0;
- Lcd_SetBox(x,y,16,32,0,0);
- Lcd_SetCursor(x,y+31);
- Lcd_WR_Start();
- for (i=0;i<32;i++)
- for (k=0;k<2;k++)
- tmp_char=num_16x32[ch*32*2+(31-i)*2+k];
- for (j=0;j<8;j++)
- Clr_nWr;
- Set_nWr;
- else
- Clr_nWr;
- Set_nWr;
- void LCD_Scan_Set(char i)
- if(i==0) {LCD_WR_REG(0x0003,0x1038);Lcd_SetCursor(0,239);}//
- if(i==1) {LCD_WR_REG(0x0003,0x1028);Lcd_SetCursor(0,239);}//
- if(i==2) {LCD_WR_REG(0x0003,0x1008);Lcd_SetCursor(319,0);}//
- if(i==3) {LCD_WR_REG(0x0001,0x0100);return;}//
- LCD_WR_REG(0x0050,0x00);//垂直GRAM起始位置
- Lcd_WR_Start();
- 功能: 竖直滚屏
- 入口参数:line_num 滚动行数
- void lcd_scrol_screen(unsigned int line_num)
- LCD_WR_REG(0x006a, line_num);// set scrolling line
- LCD_WR_REG(0x0061, 0x0003);//enable scrol
- // LCD_WR_REG(0x006a, line_num);// set scrolling line
- // LCD_WR_REG(0x0061, 0x0001);////disable scrol
- 功能: 禁止竖直滚屏
- void lcd_scrol_disable(void)
- LCD_WR_REG(0x006a, 0x0000);// set scrolling line
- LCD_WR_REG(0x0061, 0x0001);//disable scrol
Keil代码下载:
uc_gui_4.63_IL9488.7z
(2.37 MB, 下载次数: 28)
