使用1602显示DHT22的温湿度,精确到小数点的后一位
// DHT21使用范例
//单片机 AT89S52 或 STC89C52RC
//功能 串口发送温湿度数据 晶振 11.0592M 波特率 9600
//硬件 P2.0口为通讯口连接DHT22,DHT22的电源和地连接单片机的电源和地,单片机串口加MAX232连接电脑
#include <reg51.h>
#include <intrins.h>
typedef unsigned char U8; /* defined for unsigned 8-bits integer variable 无符号8位整型变量 */
typedef signed char S8; /* defined for signed 8-bits integer variable 有符号8位整型变量 */
typedef unsigned int U16; /* defined for unsigned 16-bits integer variable 无符号16位整型变量 */
typedef signed int S16; /* defined for signed 16-bits integer variable 有符号16位整型变量 */
typedef unsigned long U32; /* defined for unsigned 32-bits integer variable 无符号32位整型变量 */
typedef signed long S32; /* defined for signed 32-bits integer variable 有符号32位整型变量 */
typedef float F32; /* single precision floating point variable (32bits) 单精度浮点数(32位长度) */
typedef double F64; /* double precision floating point variable (64bits) 双精度浮点数(64位长度) */
#define Data_0_time 4
#define LCD1602_DB P0
sbit LCD1602_RS = P2^0;
sbit LCD1602_RW = P2^1;
sbit LCD1602_E = P2^2;
/* 等待液晶准备好 */
void LcdWaitReady()
unsigned char sta;
LCD1602_DB = 0xFF;
LCD1602_RS = 0;
LCD1602_RW = 1;
do {
LCD1602_E = 1;
sta = LCD1602_DB; //读取状态字
LCD1602_E = 0;
} while (sta & 0x80); //bit7等于1表示液晶正忙,重复检测直到其等于0为止
/* 向LCD1602液晶写入一字节命令,cmd-待写入命令值 */
void LcdWriteCmd(unsigned char cmd)
LcdWaitReady();
LCD1602_RS = 0;
LCD1602_RW = 0;
LCD1602_DB = cmd;
LCD1602_E = 1;
LCD1602_E = 0;
/* 向LCD1602液晶写入一字节数据,dat-待写入数据值 */
void LcdWriteDat(unsigned char dat)
LcdWaitReady();
LCD1602_RS = 1;
LCD1602_RW = 0;
LCD1602_DB = dat;
LCD1602_E = 1;
LCD1602_E = 0;
/* 设置显示RAM起始地址,亦即光标位置,(x,y)-对应屏幕上的字符坐标 */
void LcdSetCursor(unsigned char x, unsigned char y)
unsigned char addr;
if (y == 0) //由输入的屏幕坐标计算显示RAM的地址
addr = 0x00 + x; //第一行字符地址从0x00起始
addr = 0x40 + x; //第二行字符地址从0x40起始
LcdWriteCmd(addr | 0x80); //设置RAM地址
/* 在液晶上显示字符串,(x,y)-对应屏幕上的起始坐标,str-字符串指针 */
void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str)
LcdSetCursor(x, y); //设置起始地址
while (*str != '\0') //连续写入字符串数据,直到检测到结束符
LcdWriteDat(*str++);
/* 打开光标的闪烁效果 */
void LcdOpenCursor()
LcdWriteCmd(0x0F);
/* 关闭光标显示 */
void LcdCloseCursor()
LcdWriteCmd(0x0C);
/* 初始化1602液晶 */
void InitLcd1602()
LcdWriteCmd(0x38); //16*2显示,5*7点阵,8位数据接口
LcdWriteCmd(0x0C); //显示器开,光标关闭
LcdWriteCmd(0x06); //文字不动,地址自动+1
LcdWriteCmd(0x01); //清屏
//----------------IO口定义区--------------------//
sbit P2_0 = P2^3 ;
//----------------定义区--------------------//
U8 U8FLAG,k;
U8 U8count,U8temp;
U8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
U8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
U8 U8comdata;
U8 outdata[5]; //定义发送的字节数
U8 indata[5];
U8 count, count_r=0;
U8 str[4];
U16 U16temp1,U16temp2;
SendData(U8 *a)
outdata[0] = a[0];
outdata[1] = a[1];
outdata[2] = a[2];
outdata[3] = a[3];
outdata[4] = a[4];
count = 1;
SBUF=outdata[0];
void Delay(U16 j)
{ U8 i;
for(;j>0;j--)
for(i=0;i<27;i++);
void Delay_10us(void)
U8 i;
i--;
i--;
i--;
i--;
i--;
i--;
void COM(void)
U8 i;
for(i=0;i<8;i++)
U8FLAG=2;
while((!P2_0)&&U8FLAG++);
Delay_10us();
Delay_10us();
Delay_10us();
U8temp=0;
if(P2_0)U8temp=1;
U8FLAG=2;
while((P2_0)&&U8FLAG++);
//超时则跳出for循环
if(U8FLAG==1)break;
//判断数据位是0还是1
// 如果高电平高过预定0高电平值则数据位为 1
U8comdata<<=1;
U8comdata|=U8temp; //0
}//rof
//-----湿度读取子程序 ------------
//----以下变量均为全局变量--------
//----温度高8位== U8T_data_H------
//----温度低8位== U8T_data_L------
//----湿度高8位== U8RH_data_H-----
//----湿度低8位== U8RH_data_L-----
//----校验 8位 == U8checkdata-----
//----调用相关子程序如下----------
//---- Delay();, Delay_10us();,COM();
void RH(void)
//主机拉低18ms
P2_0=0;
Delay(180);
P2_0=1;
//总线由上拉电阻拉高 主机延时20us
Delay_10us();
Delay_10us();
Delay_10us();
Delay_10us();
//主机设为输入 判断从机响应信号
P2_0=1;
//判断从机是否有低电平响应信号 如不响应则跳出,响应则向下运行
if(!P2_0) //T !
U8FLAG=2;
//判断从机是否发出 80us 的低电平响应信号是否结束
U8FLAG=2;
//判断从机是否发出 80us 的高电平,如发出则进入数据接收状态
//数据接收状态
COM();
U8RH_data_H_temp=U8comdata;
COM();
U8RH_data_L_temp=U8comdata;
COM();
U8T_data_H_temp=U8comdata;
COM();
U8T_data_L_temp=U8comdata;
COM();
U8checkdata_temp=U8comdata;
P2_0=1;
//数据校验
U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
if(U8temp==U8checkdata_temp)
U8RH_data_H=U8RH_data_H_temp;
U8RH_data_L=U8RH_data_L_temp;
U8T_data_H=U8T_data_H_temp;
U8T_data_L=U8T_data_L_temp;
U8checkdata=U8checkdata_temp;
}//fi
}//fi
//main()功能描述: AT89C51 11.0592MHz 串口发
//送温湿度数据,波特率 9600
U16 wendu = 0;
U16 shidu = 0;
U8 wendu_zu[4];
U8 shidu_zu[4];
//uchar str[6]={"RS232"};
/* 系统初始化 */
TMOD = 0x20; //定时器T1使用工作方式2
TH1 = 253; // 设置初值
TL1 = 253;
TR1 = 1; // 开始计时
SCON = 0x50; //工作方式1,波特率9600bps,允许接收
ES = 1;
EA = 1; // 打开所以中断
TI = 0;
RI = 0;
SendData(str) ; //发送到串口
Delay(10); //延时100US(12M晶振)
InitLcd1602();
//调用温湿度读取子程序
RH();
//串口显示程序
wendu = (((U16)U8RH_data_H<<8)|(U16)U8RH_data_L);
shidu = (((U16)U8T_data_H<<8)|(U16)U8T_data_L);
wendu_zu[3]=wendu%10 + '0';
wendu_zu[2]='.';
wendu_zu[1]=(wendu/10)%10+ '0';
wendu_zu[0]=wendu/100+ '0';
shidu_zu[3] = shidu%10 + '0';
shidu_zu[2] = '.';
shidu_zu[1] = (shidu/10)%10+ '0';
shidu_zu[0] = shidu/100 + '0';
LcdShowStr(0,0,wendu_zu);
LcdShowStr(0,1,shidu_zu);
//读取模块数据周期不宜小于 2S
Delay(2000);
}//elihw
}// main
//void RSINTR() interrupt 4 using 2
// U8 InPut3;
// if(TI==1) //发送中断
// TI=0;
// if(count!=5) //发送完5位数据
// SBUF= outdata[count];
// count++;
// if(RI==1) //接收中断
// InPut3=SBUF;
// indata[count_r]=InPut3;
// count_r++;
// RI=0;
// if (count_r==5)//接收完4位数据
// //数据接收完毕处理。
// count_r=0;
// str[0]=indata[0];
// str[1]=indata[1];
// str[2]=indata[2];
// str[3]=indata[3];
// str[4]=indata[4];
// P0=0;
