- #ifndef _LCD12864BU_H_
- #define _LCD12864BU_H_
- /*****液晶显示器的端口定义*****/
- #define LCD_data P0 //数据口
- sbit LCD_RS = P2^0; //寄存器选择输入
- sbit LCD_RW = P2^1; //液晶读/写控制
- sbit LCD_EN = P2^2; //液晶使能控制
- sbit LCD_PSB = P3^6; //串/并方式控制
- sbit RST_12864 = P2^5;
- #define uchar unsigned char
- #define uint unsigned int
- unsigned char code pictrue1[1024]={
- /*-- 调入了一幅图像:E:\Desktop\冰.bmp --*/
- /*-- 宽度x高度=128x64 --*/
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x7B,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x57,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xF3,0xFF,0xFF,0xFF,0xF8,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0x3F,0xFF,0xCC,0xFF,0xFF,0xFF,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFC,0xDF,0xFF,0xE1,0xFF,0xFF,0xF8,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFD,0x7C,0x00,0x1E,0xFF,0xFF,0xF0,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xF0,0x00,0x0E,0xFF,0xFF,0xF0,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xE0,0x00,0x05,0xFF,0xFF,0xC2,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xC0,0x01,0x81,0xFF,0xFF,0x80,0x00,0x00,0x02,0x20,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0x80,0x28,0x09,0xDE,0x01,0xC0,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x04,0x00,0x9F,0xFA,0xE0,0x01,0xC0,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x06,0x02,0x70,0x06,0x4F,0x03,0xC0,0x00,0x00,0x09,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x0C,0x07,0x88,0x09,0xFF,0x83,0xC2,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x0C,0x0F,0x20,0x00,0xFF,0x83,0xB8,0x00,0x00,0x00,0x80,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x18,0x1E,0x00,0x01,0x7F,0x07,0x80,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x18,0x3F,0x00,0x04,0x3F,0x87,0x00,0x00,0x80,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x18,0x38,0x7C,0x0F,0x3E,0x07,0x00,0x00,0x00,0x00,0x40,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x18,0x78,0xE4,0x01,0x7F,0x07,0x00,0x00,0x00,0x00,0x40,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x18,0x75,0xE6,0x05,0xDC,0x06,0x0C,0x00,0x30,0x04,0x40,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x10,0x3B,0xFE,0x05,0x98,0x06,0x0C,0x00,0x00,0x3F,0xC0,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x10,0x63,0xE4,0x7D,0x9C,0x02,0x00,0x00,0x00,0x7F,0xC0,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x10,0xE3,0xE4,0x67,0x98,0x02,0x00,0x00,0xC0,0x3F,0xC0,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x10,0xEB,0xF8,0x07,0x98,0x03,0x00,0x00,0xC0,0x7F,0xC0,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x10,0xE3,0xF1,0x13,0x98,0x01,0x80,0x00,0x00,0x7F,0x80,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x10,0xE3,0xE0,0x01,0x90,0x01,0xF0,0x00,0x00,0x7F,0x80,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x38,0x61,0xC0,0x00,0x10,0x00,0xFC,0x00,0x00,0x3F,0x80,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x3C,0x78,0x00,0x00,0x50,0x00,0x7F,0x00,0x00,0x3F,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x7C,0x70,0x00,0x00,0xB0,0x00,0x3F,0xFF,0x7C,0x7E,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x3E,0x38,0x00,0x01,0x60,0x00,0x3F,0xFF,0xFF,0xFC,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x7E,0x1F,0x20,0x3D,0xC0,0x00,0x7F,0xFF,0xFF,0xF8,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0xFE,0x1F,0xE0,0x07,0xC0,0x00,0x7F,0xFF,0xFF,0xE0,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0xFF,0x07,0xFF,0xFF,0x80,0x00,0x7F,0xFF,0xFF,0x80,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0xFF,0x83,0xFF,0xFF,0x00,0x00,0x7F,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x01,0xFF,0x80,0x7F,0xF8,0x00,0x00,0x3F,0xFF,0xFF,0x80,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x01,0xF8,0x00,0x00,0x81,0x80,0x00,0x1F,0xFF,0xFF,0xC0,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x01,0xF8,0x00,0x01,0xE1,0x00,0x00,0x07,0xC0,0x3F,0xC0,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x03,0xF8,0x00,0x01,0xFF,0x00,0x00,0x03,0xD8,0x3F,0xC0,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0xE8,0xFE,0x3F,0xFE,0x00,0x00,0x03,0xC8,0x3F,0xC0,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0xF0,0xFF,0xFF,0xFE,0x00,0x00,0x03,0x90,0x1F,0xC0,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x00,0xFF,0xFF,0xFC,0x00,0x00,0x03,0xA0,0x3E,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x01,0x7F,0xFF,0xFC,0x00,0x00,0x01,0x80,0x3C,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x00,0x7F,0xFF,0xFC,0x00,0x00,0x01,0xC0,0x3C,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x00,0xFF,0xFF,0xFC,0x00,0x00,0x01,0xFC,0xFC,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x00,0xBF,0xFF,0xFC,0x00,0x00,0x00,0xFF,0xF8,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x00,0x3F,0xF7,0xF8,0x00,0x00,0x00,0xFF,0xC0,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x00,0x3F,0xC1,0xF8,0x00,0x00,0x00,0xFF,0x10,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x00,0x3F,0x81,0xF8,0x00,0x00,0x00,0x79,0xF8,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x00,0x3F,0x80,0x74,0x00,0x00,0x00,0x01,0xF0,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x00,0x5F,0x41,0x98,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x00,0x3F,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF};//\Desktop\冰.bmp0
- 函数功能:LCD延时程序
- 入口参数:del
- 出口参数:
- //忙检测,若忙则等待,最长等待时间为60ms
- //延时子程序
- void delay_12864(unsigned int del){
- unsigned int i;
- for(i = 0; i < del; i++){; }
- 状态检查,LCD是否忙
- //void busychk_12864(void){
- //unsigned int timeout = 0;
- // LCD_EN = 0;
- // LCD_RS = 0;
- // LCD_RW = 1;
- // LCD_EN = 1;
- //while(( LCD_data & 0x80)&& ++timeout != 0); //忙状态检测,等待超时时间为60ms
- // LCD_EN = 0;
- 函数功能:写命令到LCD程序,RS(DI)=L,RW=L,EN=H,即来一个脉冲写一次
- 入口参数:cmd
- 出口参数:
- //写命令子程序
- void wrtcom_12864(unsigned char com){
- //busychk_12864();
- LCD_EN = 0;
- LCD_RS = 0;
- LCD_RW = 0;
- LCD_data = com;
- LCD_EN = 1;
- delay_12864(50); //使能延时!!!注意这里,如果是较快的CPU应该延时久一些
- LCD_EN = 0;
- ////读数据子程序
- //unsigned char reddat_12864(void){
- //unsigned char temp;
- // LCD_EN = 0;
- // LCD_data = 0xff; //IO口置高电平,读引脚
- // LCD_RS = 1;
- // LCD_RW = 1;
- // LCD_EN = 1;
- //delay_12864(50); //使能延时!!!注意这里,如果是较快的CPU应该延时久一些
- //temp = LCD_data;
- //return temp;
- //写数据子程序
- void wrtdat_12864(unsigned char dat){
- LCD_EN = 0;
- LCD_RS = 1;
- LCD_RW = 0;
- LCD_EN = 1;
- LCD_data = dat;
- LCD_EN = 0;
- 函数功能:LCD初始化程序
- 入口参数:
- 出口参数:
- //初始化12864子函数
- void initial_12864(void){
- delay_12864(40000);
- RST_12864 = 1;
- RST_12864 = 0; //复位
- delay_12864(500);
- RST_12864 = 1;
- wrtcom_12864(0x30); //设置为基本指令集动作
- delay_12864(100);
- delay_12864(37);
- wrtcom_12864(0x08); //设置显示、光标、闪烁全关。
- delay_12864(100);
- wrtcom_12864(0x01); //清屏,并且DDRAM数据指针清零
- delay_12864(100000);
- wrtcom_12864(0x06); //进入模式设置
- wrtcom_12864(0x0c); //开显示
- void Clear12864Screen()
- unsigned char i,j;
- wrtcom_12864(0x34);//功能设定:8位控制方式,使用扩充指令
- wrtcom_12864(0x36);//使用扩充指令,绘图显示控制
- for(i=0;i<32;i++)
- //ST7920可控制256*32点阵(32行256列),而12864液晶实际的行地址只有0-31行,
- //12864液晶的32-63行的行是0-31行地址从第128列划分一半出来的,所以分为上下两半屏,
- //也就是说第0行和第32行同属一行,行地址相同;第1行和第33行同属一行,以此类推
- wrtcom_12864(0x80|i);//写行地址(垂直地址)
- wrtcom_12864(0x80);//写列地址(水平地址)
- for(j=0;j<32;j++)
- wrtdat_12864(0x00);//清屏
- void LCD12864DisplayPictrue(unsigned char y,unsigned char x,
- unsigned char px,unsigned char py, unsigned char *pp)
- //y-起始行(数值0-63),x-起始列(16位宽,数值0-7),
- //px-图片宽度,py-图片高度,pp-指针指向图片数组
- //因为上下屏的地址不连续,要在任意位置显示完整的图像,处理起来比较繁琐
- unsigned char i,j,k;
- Clear12864Screen();//清屏
- if(y<32)//如果起始行在上半屏
- k=32-y;//算出上半屏的行数
- for(i=0;i<k;i++,y++)//上半屏行数
- wrtcom_12864(0x80|y);//写行地址(垂直地址)
- wrtcom_12864(0x80|x);//写列地址(水平地址)
- for(j=0;j<px/8;j++)
- wrtdat_12864(pp[i*px/8+j]);//写图片数据
- y=0;//下半屏起始行,接上半屏继续写数据
- for(;i<py;i++,y++)//下半屏剩下的行数
- wrtcom_12864(0x80|(8+x));//写列地址(水平地址)
- else //如果起始行在下半屏
- for(i=0;i<py;i++,y++)//行数
- wrtcom_12864(0x80|(y-32));//写行地址(垂直地址)
- #endif
复制代码- #include < reg52.h>
- #include < lcd12864bu.h>
- void main()
- initial_12864(); //初始化12864
- LCD12864DisplayPictrue(0,0,128,64,pictrue1);//显示
- while(1);
Keil代码下载:
冰.7z
(17.44 KB, 下载次数: 22)
