- #include <REGX52.H>
- #include <INTRINS.H>
- sbit SCL=P1^0; //IIC时钟引脚定义
- sbit SDA=P1^1; //IIC数据引脚定义
- unsigned char BUF[6]; //接收数据缓存区
- signed int XYZ_data[3];
- void Init_ADXL345(void); //初始化ADXL345
- void Single_Write_ADXL345(unsigned char REG_Address,unsigned char REG_data); //单个写入数据
- void Multiple_Read_ADXL345(); //连续的读取内部寄存器数据
- void Delay5us();
- void Delay5ms();
- void Delay50ms();
- void ADXL345_Start();
- void ADXL345_Stop();
- void ADXL345_SendACK(bit ack);
- bit ADXL345_RecvACK();
- void ADXL345_SendByte(unsigned char dat);
- unsigned char ADXL345_RecvByte();
- void Send(unsigned char CMD);
- void UartInit();
- void Data_Process();
- void direction_judge();
- bit flag;
- unsigned char CMD1,CMD2;
- //******主程序********
- void main()
- Delay50ms();
- UartInit();
- Init_ADXL345(); //初始化ADXL345
- while(1) //循环
- Multiple_Read_ADXL345(); //连续读出数据,存储在BUF中
- Data_Process();
- direction_judge();
- Delay50ms();
- 起始信号
- SDA = 1; //拉高数据线
- SCL = 1; //拉高时钟线
- Delay5us(); //延时
- SDA = 0; //产生下降沿
- Delay5us(); //延时
- SCL = 0; //拉低时钟线
- 停止信号
- SDA = 0; //拉低数据线
- SCL = 1; //拉高时钟线
- Delay5us(); //延时
- SDA = 1; //产生上升沿
- Delay5us(); //延时
- 发送应答信号
- 入口参数:ack (0:ACK 1:NAK)
- SDA = ack; //写应答信号
- SCL = 1; //拉高时钟线
- Delay5us(); //延时
- SCL = 0; //拉低时钟线
- Delay5us(); //延时
- 接收应答信号
- SCL = 1; //拉高时钟线
- Delay5us(); //延时
- flag = SDA; //读应答信号
- SCL = 0; //拉低时钟线
- Delay5us(); //延时
- return flag;
- 向IIC总线发送一个字节数据
- unsigned char i;
- for (i=0; i<8; i++) //8位计数器
- SDA=dat&0x80;
- SCL = 1; //拉高时钟线
- Delay5us(); //延时
- SCL = 0; //拉低时钟线
- Delay5us(); //延时
- dat <<= 1;
- ADXL345_RecvACK();
- //从IIC总线接收一个字节数据
- unsigned char i;
- unsigned char dat = 0;
- SDA = 1; //使能内部上拉,准备读取数据,
- dat <<= 1;
- SCL = 1; //拉高时钟线
- Delay5us(); //延时
- dat |= SDA; //读数据
- SCL = 0; //拉低时钟线
- Delay5us(); //延时
- return dat;
- //******单字节写入*******************************************
- ADXL345_Start(); //起始信号
- ADXL345_SendByte(0xA6); //发送设备地址
- ADXL345_SendByte(REG_Address); //内部寄存器地址
- ADXL345_SendByte(REG_data); //内部寄存器数据
- ADXL345_Stop(); //发送停止信号
- //连续读出ADXL345内部加速度数据,地址范围0x32~0x37
- void Multiple_read_ADXL345(void)
- unsigned char i;
- ADXL345_SendByte(0xA6); //发送设备地址+写信号
- ADXL345_SendByte(0x32); //发送存储单元地址,从0x32开始
- ADXL345_SendByte(0xA7); //发送设备地址+读信号
- for (i=0; i<6; i++) //连续读取6个地址数据,存储中BUF
- BUF[i] = ADXL345_RecvByte(); //BUF[0]存储0x32地址中的数据
- if (i == 5){ADXL345_SendACK(1);}//最后一个数据需要回NOACK
- else ADXL345_SendACK(0); //回应ACK
- ADXL345_Stop(); //停止信号
- Delay5ms();
- //初始化ADXL345,根据需要请参考pdf进行修改************************
- void Init_ADXL345()
- Single_Write_ADXL345(0x31,0x0B); //测量范围,正负16g,13位模式
- Single_Write_ADXL345(0x2C,0x08); //速率设定为12.5 参考pdf13页
- Single_Write_ADXL345(0x2D,0x08); //选择电源模式 参考pdf24页
- Single_Write_ADXL345(0x2E,0x80); //使能 DATA_READY 中断
- Single_Write_ADXL345(0x1E,0x00); //X 偏移量 根据测试传感器的状态写入pdf29页
- Single_Write_ADXL345(0x1F,0x00); //Y 偏移量 根据测试传感器的状态写入pdf29页
- Single_Write_ADXL345(0x20,0x05); //Z 偏移量 根据测试传感器的状态写入pdf29页
- void UartInit() //9600bps@11.0592MHz
- TMOD=0X20;
- TH1=0XFD;
- TL1=0XFD;
- TR1=1;
- SM0=0;
- SM1=1;
- EA=1;
- ES=1;
- void Send(unsigned char JIE)
- SBUF=JIE;
- while(!TI);
- TI=0;
- XYZ_data[0]=BUF[1]<<8|BUF[0];
- XYZ_data[1]=BUF[3]<<8|BUF[2];
- if(XYZ_data[0]<-350)CMD1='4';
- else if(XYZ_data[0]>350)CMD1='3';
- else CMD1='9';
- if(XYZ_data[1]<-350)CMD2='2';
- else if(XYZ_data[1]>350)CMD2='1';
- else CMD2='9';
- if(CMD1='2'|CMD1=='3')
- {Send(CMD1);}
- else Send(CMD2);
- void Delay50ms() //@11.0592MHz
- unsigned char i, j;
- i = 90;
- j = 163;
- do
- while (--j);
- } while (--i);
- void Delay5us() //@11.0592MHz
- void Delay5ms() //@11.0592MHz
- i = 9;
- j = 244;
- do
- while (--j);
- } while (--i);
复制代码 |
