参考了宋雪松老师的教学例程 ,源程序只能计算加法 ,本程序稍作修改后 可进行加法和减法计算
#include <reg52.h>
#include <intrins.h>
uchar code table[16]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71}; //共阴字形码
uchar code keycodemap[4][4]={
{ 0x31, 0x32, 0x33, 0x26 }, //数字键1、数字键2、数字键3、向上键
{ 0x34, 0x35, 0x36, 0x25 }, //数字键4、数字键5、数字键6、向左键
{ 0x37, 0x38, 0x39, 0x28 }, //数字键7、数字键8、数字键9、向下键
{ 0x30, 0x1B, 0x0D, 0x27 }}; //数字键0、ESC键、 回车键、 向右键};
uchar keysta[4][4]={{1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}}; //全局变量 记录四个键的状态 0按下 1弹起 当keysta反正变化时 说有按键动作 1变0 按下 0变1 弹起
uchar Ledbuf[6]={0X3F,0X00,0X00,0X00,0X00,0X00}; //数码管显示缓冲区,第0位为最低位(个位) ,第5位为符号位
long result=0;
long adden=0;
sbit keyin0=P1^0;
sbit keyin1=P1^1;
sbit keyin2=P1^2;
sbit keyin3=P1^3;
sbit keyout0=P1^4;
sbit keyout1=P1^5;
sbit keyout2=P1^6;
sbit keyout3=P1^7;
void InitTimer1(void) //定时1ms
TMOD = 0x10;
TH1 = 0xFC;
TL1 = 0x18;
EA = 1;
ET1 = 1;
TR1 = 1;
void shownumber(long num)
static uchar buf[5]={0,0,0,0,0};
char i;
if(num<0) //负数为补码 取反加1得到原码
{ num=~num;
num++;
Ledbuf[5]=0x40;
Ledbuf[5]=0x00;
for(i=0;i<5;i++)
{buf[ i]=num%10;
num=num/10; }
for (i=4; i>=1; i--) //从最高位起,遇到0转换为空格,遇到非0则退出循环
if (buf[ i] == 0)
Ledbuf[ i] = 0x00;
break;
for( ;i>=0;i--)
{Ledbuf[ i]=table[buf[ i]];}
void keyaction(uchar keycode)
long temp;
static uchar yunsuanfuhao=0;
if((keycode>=0x30)&&(keycode<=0x39)) //按下数字键
temp=adden;
adden=(adden<<3)+(adden<<1)+keycode-0x30;
if(adden>99999) adden=temp;
shownumber(adden);
else if(keycode==0x26) //加号键
yunsuanfuhao=1;
result=result+adden;
adden=0;
shownumber(adden);
else if(keycode==0x25) //减号键
yunsuanfuhao=2;
adden=0;
shownumber(adden);
else if(keycode==0x0d) // 等号键
if(yunsuanfuhao==1) //加法
{ result=result+adden;
adden=0;
else if(yunsuanfuhao==2) //减法
{ result=result-adden;
adden=0;
shownumber(result);
// result=0;
else if (keycode==0x1b) //清零键
result=0;
adden=0;
shownumber(result);
void keydriver()
uchar i,j; //i行 j列
static uchar backup[4][4]={{1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}};
for(i=0;i<4;i++)
for(j=0;j<4;j++)
if((backup[ i][j])!=(keysta[ i][j]))
backup[ i][j]=keysta[ i][j] ;
if(keysta[ i][j]==1)
keyaction(keycodemap[ i][j]);
void keyscan()
static uchar buf[4][4]={{0xff,0xff,0xff,0xff},{0xff,0xff,0xff,0xff},{0xff,0xff,0xff,0xff},{0xff,0xff,0xff,0xff}};
static uchar hang=0;
uchar i;
buf[hang][0]=((buf[hang][0])<<1)|((uchar) keyin0); //按行进行按键值的读取 读该行共4个键的键值 进入buf[hang][0-3]
buf[hang][1]=((buf[hang][1])<<1)|((uchar) keyin1);
buf[hang][2]=((buf[hang][2])<<1)|((uchar) keyin2);
buf[hang][3]=((buf[hang][3])<<1)|((uchar) keyin3);
for(i=0;i<4;i++) //判断该按键是否按下 即keysta是否为0 经16ms后读取buf[hang][0-3]的低4位值 观察是否为0X0F 或0X00
if (((buf[hang][ i])&0x0f )== 0x0f) keysta[hang][ i]=1;
else if (((buf[hang][ i])&0x0f )== 0x00) keysta[hang][ i]=0;
hang++;
if(hang>=4) hang=0;
switch(hang) //按行扫描,选取第i行,该行线输出低电平
case 0:keyout3=1;keyout0=0;break; // P1=0B1110 1111;
case 1:keyout0=1;keyout1=0;break; // P1=0b1101 1111;
case 2:keyout1=1;keyout2=0;break;//P1=0b1011 1111;
case 3:keyout2=1;keyout3=0;break;//P1=0b0111 1111;
default: break;
void ledscan()
static uchar i=0;
P2=~(0X01<<i);
P0=Ledbuf[5-i];
i++;
if(i>=6) i=0;
InitTimer1();
keydriver();
void timer1(void) interrupt 3
TH1 = 0xFC;
TL1 = 0x18;
keyscan();
ledscan();
