查看: 2915|回复: 8
STC32G12K128单片机的CAN连续收发问题
回帖奖励 100 黑币 回复本帖可获得 10 黑币奖励! 每人限 1 次
ID:248705 发表于 2022-6-27 18:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如题,目前在STC32G单片机上做开发,要用到CAN总线,按照例程配置了一下,测试单次收发没有问题,但是连续收发单片机总会收多或收少,少的时候能少几十帧,多的时候也能多几十帧,应该是我的配置问题,求大佬指点哇,我的配置如下:
  1. #include "can.h"
  2. #include "config.h"
  3. #include "STC32G_NVIC.h"
  4. #define DBG_TAG "can"
  5. #include "debug.h"
  6. // can 设备句柄
  7. static can_t can1 = { 0 };
  8. static can_t can2 = { 0 };
  9. /* 初始化can设备 */
  10. void can_init(u8 channel, u8 port, u8 pin, u8 io_mux, u32 buad)
  11. {
  12.         can_t *can_dev;
  13.         u32 tmp_brp,tmp_tsg,buad_cal;
  14.         CAN_InitTypeDef        CAN_InitStructure;                                                //结构定义
  15.         GPIO_InitTypeDef        GPIO_InitStructure;                                        //结构定义
  16.         // update
  17.         if(channel == CAN1)
  18.         {
  19.                 can_dev = &can1;
  20.                 CAN1_SW(io_mux);
  21.         }
  22.         else if(channel == CAN2)
  23.         {
  24.                 can_dev = &can2;
  25.                 CAN2_SW(io_mux);
  26.         }
  27.         else
  28.         {
  29.                 return;
  30.         }
  31.         /*IO INIT*/
  32.         GPIO_InitStructure.Pin  = pin;        //指定要初始化的IO, GPIO_Pin_0 ~ GPIO_Pin_7
  33.         GPIO_InitStructure.Mode = GPIO_PullUp;                                                //指定IO的输入或输出方式,GPIO_PullUp,GPIO_HighZ,GPIO_OUT_OD,GPIO_OUT_PP
  34.         GPIO_Inilize(port,&GPIO_InitStructure);                                                //初始化
  35.
  36.         CAN_InitStructure.CAN_Enable = ENABLE;                                                //CAN功能使能   ENABLE或DISABLE
  37.         CAN_InitStructure.CAN_IMR = CAN_RIM | CAN_BEIM;                                //CAN中断寄存器         CAN_DOIM,CAN_BEIM,CAN_TIM,CAN_RIM,CAN_EPIM,CAN_EWIM,CAN_ALIM,CAN_ALLIM,DISABLE
  38.         CAN_InitStructure.CAN_SJW    = 3;                                                        //重新同步跳跃宽度  0~3
  39.         CAN_InitStructure.CAN_SAM    = 1;                                                        //总线电平采样次数  0:采样1次; 1:采样3次
  40.         //CAN总线波特率=Fclk/((1+(TSG1+1)+(TSG2+1))*(BRP+1)*2)
  41.         buad_cal = (MAIN_Fosc / buad) / 2;
  42.         if(buad_cal <= 0)
  43.         {
  44.                 return;
  45.         }
  46.         for(tmp_tsg = 1 + 2 + 1; tmp_tsg < 26; tmp_tsg ++)
  47.         {
  48.                 for(tmp_brp = 1; tmp_brp < 64; tmp_brp ++)
  49.                 {
  50.                         if(buad_cal < tmp_brp * tmp_tsg)
  51.                         {
  52.                                 break;
  53.                         }
  54.                         if(buad_cal == tmp_brp * tmp_tsg)
  55.                         {
  56.                                 break;
  57.                         }
  58.                 }
  59.                 if(buad_cal == tmp_brp * tmp_tsg)
  60.                 {
  61.                         break;
  62.                 }
  63.         }
  64.         if(tmp_tsg < 11)
  65.         {
  66.                 CAN_InitStructure.CAN_TSG1   = 0;                                //同步采样段1       0~15
  67.                 CAN_InitStructure.CAN_TSG2   = tmp_tsg - 3;                //同步采样段2       1~7 (TSG2 不能设置为0)
  68.         }
  69.         else if(tmp_tsg < 26)
  70.         {
  71.                 CAN_InitStructure.CAN_TSG1   = tmp_tsg - 10;        //(1 + 1 + 1 + CAN_TSG2)
  72.                 CAN_InitStructure.CAN_TSG2   = 7;                                //同步采样段2       1~7 (TSG2 不能设置为0)
  73.         }
  74.         CAN_InitStructure.CAN_BRP    = tmp_brp - 1;                        //波特率分频系数    0~63
  75.
  76.         CAN_InitStructure.CAN_ACR0    = 0x00;                                //总线验收代码寄存器 0~0xFF
  77.         CAN_InitStructure.CAN_ACR1    = 0x00;
  78.         CAN_InitStructure.CAN_ACR2    = 0x00;
  79.         CAN_InitStructure.CAN_ACR3    = 0x00;
  80.         CAN_InitStructure.CAN_AMR0    = 0xff;                                //总线验收屏蔽寄存器 0~0xFF
  81.         CAN_InitStructure.CAN_AMR1    = 0xff;
  82.         CAN_InitStructure.CAN_AMR2    = 0xff;
  83.         CAN_InitStructure.CAN_AMR3    = 0xff;
  84.         //CAN1 初始化
  85.         CAN_Inilize(channel,&CAN_InitStructure);
  86.         //中断使能
  87.         NVIC_CAN_Init(channel,ENABLE,Priority_0);
  88.         //
  89.         can_dev->buad = buad;
  90.         can_dev->channel = channel;
  91.         can_dev->queue.current = can_dev->queue.can_context_pool + 1;
  92.         can_dev->queue.tail = can_dev->queue.can_context_pool + 1;
  93.         memset(can_dev->queue.can_context_pool, 0, sizeof(can_dev->queue.can_context_pool));
  94.
  95.         LOG_I(DBG_TAG, "can_dev queue tail = 0x%p", can_dev->queue.tail);
  96.         LOG_I(DBG_TAG, "can_dev queue current = 0x%p", can_dev->queue.current);
  97.         LOG_I(DBG_TAG, "can_dev queue can_context_pool = 0x%p", can_dev->queue.can_context_pool);
  98.         LOG_I(DBG_TAG, "can_dev queue can_context_pool tail = 0x%p", can_dev->queue.can_context_pool + CAN_QUEUE_POOL_SIZE);
  99.         LOG_I(DBG_TAG, "can%d init success!", channel + 1);
  100. }
  101. /* 绑定命令表到某个can通道上 */
  102. void can_command_load(u8 channel, can_command_t *command_table)
  103. {
  104.         can_t *can_dev;
  105.         can_dev = channel == CAN1 ? &can1: &can2;
  106.         can_dev->command_table = command_table;
  107. }
  108. /* 查询队列中是否有元素 */
  109. bool can_queue_is_empty(u8 channel)
  110. {
  111.         can_t *can_dev;
  112.         can_dev = channel == CAN1 ? &can1: &can2;
  113.         if((can_dev->queue.current == can_dev->queue.tail) && (can_dev->queue.can_context_pool[0].cmd == 0x00))
  114.         {
  115.                 return TRUE;
  116.         }
  117.         LOG_D(DBG_TAG, "can_dev->queue.can_context_pool[0].cmd = 0x%p", can_dev->queue.can_context_pool[0].cmd);
  118.         LOG_D(DBG_TAG,         "can queue ptr tail = 0x%p can queue ptr current = 0x%p",
  119.                                         can_dev->queue.tail,
  120.                                         can_dev->queue.current);
  121.         return FALSE;
  122. }
  123. /* 吐出一个队列中的元素 */
  124. can_context_t can_queue_pop(u8 channel)
  125. {
  126.         can_t* can_dev;
  127.         can_context_t* context = NULL;
  128.         can_context_t ret = { 0 };
  129.         can_dev = channel == CAN1 ? &can1 : &can2;
  130.         // 存在紧急命令时优先吐出
  131.         if (can_dev->queue.can_context_pool[0].cmd != 0x00)
  132.         {
  133.                 context = &(can_dev->queue.can_context_pool[0]);
  134.         }
  135.         else
  136.         {
  137.                 context = can_dev->queue.current;
  138.                 // 准备下次pop
  139.                 if (can_dev->queue.current < can_dev->queue.tail)
  140.                 {
  141.                         can_dev->queue.current += 1;
  142.                 }
  143.                 // current,tail指针地址重叠
  144.                 else if (can_dev->queue.current == can_dev->queue.tail)
  145.                 {
  146.                         // 地址上有内容
  147.                         if (can_dev->queue.tail->cmd == 0x00)
  148.                         {
  149.                                 context = NULL;
  150.                         }
  151.                 }
  152.                 // current指针大于tail指针
  153.                 else
  154.                 {
  155.                         if (can_dev->queue.current < can_dev->queue.can_context_pool + CAN_QUEUE_POOL_SIZE)
  156.                         {
  157.                                 can_dev->queue.current += 1;
  158.                         }
  159.                         else
  160.                         {
  161.                                 can_dev->queue.current = can_dev->queue.can_context_pool + 1;
  162.                         }
  163.                 }
  164.         }
  165.         if (context)
  166.         {
  167.                 ret = *context;
  168.                 // 清空context为下次数据填充做准备
  169.                 memset(context, 0, sizeof(can_context_t));
  170.         }
  171.         return ret;
  172. }
  173. /* 向队列中压入元素 */
  174. bool can_queue_push(u8 channel, can_context_t* context)
  175. {
  176.         can_t* can_dev;
  177.         can_dev = channel == CAN1 ? &can1 : &can2;
  178.         // 优先写入紧急命令
  179.         if (context->cmd < 0x10)
  180.         {
  181.                 can_dev->queue.can_context_pool[0] = *context;
  182.                 return TRUE;
  183.         }
  184.         // tail指针向下偏移
  185.         if (can_dev->queue.tail <= can_dev->queue.can_context_pool + CAN_QUEUE_POOL_SIZE)
  186.         {
  187.                 if (can_dev->queue.tail + 1 == can_dev->queue.current)
  188.                 {
  189.                         // 地址上已有内容,返回队列已满
  190.                         if (can_dev->queue.tail->cmd)
  191.                         {
  192.                                 return FALSE;
  193.                         }
  194.                         else
  195.                         {
  196.                                 *(can_dev->queue.tail) = *context;
  197.                         }
  198.                 }
  199.                 // 只要不遇到current指针就总是移动
  200.                 else
  201.                 {
  202.                         *(can_dev->queue.tail) = *context;
  203.                         can_dev->queue.tail += 1;
  204.                 }
  205.         }
  206.         else
  207.         {
  208.                 if (can_dev->queue.current != can_dev->queue.can_context_pool + 1)
  209.                 {
  210.                         can_dev->queue.tail = can_dev->queue.can_context_pool + 1;
  211.                         *(can_dev->queue.tail) = *context;
  212.                 }
  213.                 if (can_dev->queue.tail > can_dev->queue.can_context_pool + CAN_QUEUE_POOL_SIZE)
  214.                 {
  215.                         return FALSE;
  216.                 }
  217.         }
  218.         return TRUE;
  219. }
  220. /* 通过命令号获取命令句柄 */
  221. can_command_t *can_command_get(u8 channel, u8 cmd)
  222. {
  223.         u8 find;
  224.         can_t *can_dev;
  225.         can_dev = channel == CAN1 ? &can1: &can2;
  226.         for(find = 0; can_dev->command_table[find].type != CAN_COMMAND_END; find ++)
  227.         {
  228.                 if(can_dev->command_table[find].cmd == cmd)
  229.                         break;
  230.         }
  231.         return &(can_dev->command_table[find]);
  232. }
  233. /* 发送标准帧 */
  234. void can_send_standard_frame(u8 channel, u16 up_id, u8 *pdat)
  235. {
  236.         u16 CanID;
  237.         can_t *can_dev;
  238.         can_dev = channel == CAN1 ? &can1: &can2;
  239.
  240.         CANSEL = channel;
  241.         CanID = up_id << 5;
  242.
  243.         CANAR = TX_BUF0;CANDR = 0x08;
  244.         CANAR = TX_BUF1;CANDR = CanID >> 8;
  245.         CANAR = TX_BUF2;CANDR = CanID;
  246.         CANAR = TX_BUF3;CANDR = pdat[0];
  247.         CANAR = TX_BUF0;CANDR = pdat[1];
  248.         CANAR = TX_BUF1;CANDR = pdat[2];
  249.         CANAR = TX_BUF2;CANDR = pdat[3];
  250.         CANAR = TX_BUF3;CANDR = pdat[4];
  251.         CANAR = TX_BUF0;CANDR = pdat[5];
  252.         CANAR = TX_BUF1;CANDR = pdat[6];
  253.         CANAR = TX_BUF2;CANDR = pdat[7];
  254.         CANAR = TX_BUF3;CANDR = 0x00;
  255.         CANAR = CMR;CANDR = 0x04;
  256.         // 等待can发送完成
  257.         CANAR = SR;while(CANDR & 0x04);
  258. }
  259. /* can接收中断 */
  260. void CAN1_ISR_Handler (void) interrupt CAN1_VECTOR
  261. {
  262.         u8 isr;
  263.         u8 store;
  264.         u8 arTemp;
  265.         can_context_t cont;
  266.         arTemp = CANAR;                                                     //先CANAR现场保存,避免主循环里写完 CANAR 后产生中断,在中断里修改了 CANAR 内容
  267.         store = AUXR2;                                                      //后AUXR2现场保存
  268.
  269.         AUXR2 &= ~0x08;        //选择CAN1模块
  270.         isr = CanReadReg(ISR);
  271.         CANAR = ISR;
  272.         CANDR = isr;                                                             //写1清除标志位
  273.         if((isr & 0x08) == 0x08)                                          //RI
  274.         {
  275.                 // 存储接收到的数据
  276.                 cont.upid = CanReadStandardFrame(&(cont.cmd));
  277.                 can_queue_push(CAN1, &cont);
  278.                 // 清除中断标志
  279.                 CANAR = ISR;
  280.                 CANDR |= 0x08;
  281.         }
  282.         if((isr & 0x20) == 0x20)                                          //EWI
  283.         {
  284.                 CANAR = MR;
  285.                 CANDR &= ~0x04;                                                  //清除 Reset Mode, 从BUS-OFF状态退出
  286.                 CANAR = ISR;
  287.                 CANDR |= 0x20;                                                    //CLR FLAG
  288.         }
  289.         AUXR2 = store;                                                             //先AUXR2现场恢复
  290.         CANAR = arTemp;                                                            //后CANAR现场恢复
  291. }
收藏收藏1 分享淘帖 顶 踩
ID:248705 发表于 2022-6-28 10:17 | 只看该作者
难道是不能在中断中做readFifo的操作?
ID:961114 发表于 2022-6-28 16:25 | 只看该作者
http://www.stcmcudata.com/STC8F-DATASHEET/STC32G-SOFTWARE-LIB.zip        库也更新了,如果还是不行  请找陈工
ID:961114 发表于 2022-6-28 16:41 | 只看该作者
http://www.stcmcudata.com/OpenSo ... DIP64-DEMO-CODE.ZIP            这里面是 普通的 C 语言直接操作 SFR的程序
ID:248705 发表于 2022-6-28 17:10 | 只看该作者
STC庄伟 发表于 2022-6-28 16:25
http://www.stcmcudata.com/STC8F-DATASHEET/STC32G-SOFTWARE-LIB.zip        库也更新了,如果还是不行   ...
谢谢!,我研究一下
ID:248705 发表于 2022-6-29 09:12 | 只看该作者
问题解决了,后面发现是TSG1,TSG2,BRP三个寄存器配置问题(自己写的算法分配了三个寄存器的值,虽然能通信,但是可能并不合理)
ID:248705 发表于 2022-6-29 09:15 | 只看该作者
STC庄伟 发表于 2022-6-28 16:41
http://www.stcmcudata.com/OpenSource/STC32G12K128-LQFP64-DIP64-DEMO-CODE.ZIP            这里面是 普 ...
感谢!
ID:1111967 发表于 2024-9-19 09:23 | 只看该作者
#include "STC32G.h"
#include "intrins.h"
typedef         unsigned char        u8;
typedef         unsigned int        u16;
typedef         unsigned long        u32;
#define MAIN_Fosc        24000000UL
/****************************** 用户定义宏 ***********************************/
#define TSG1    2                //0~15
#define TSG2    1                //1~7 (TSG2 不能设置为0)
#define BRP     3                //0~63
//24000000/((1+3+2)*4*2)=500KHz
#define SJW     1                //重新同步跳跃宽度
//总线波特率100KHz以上设置为 0; 100KHz以下设置为 1
#define SAM     0                //总线电平采样次数: 0:采样1次; 1:采样3次
/*************  本地常量声明    **************/
#define Timer0_Reload   (65536UL -(MAIN_Fosc / 1000))       //Timer 0 中断频率, 1000次/秒
#define        STANDARD_FRAME   0     //帧格式:标准帧
#define        EXTENDED_FRAME   1     //帧格式:扩展帧
/*************  本地变量声明    **************/
typedef struct
        u8        DLC:4;          //数据长度, bit0~bit3
        u8        :2;             //空数据, bit4~bit5
        u8        RTR:1;          //帧类型, bit6
        u8        FF:1;           //帧格式, bit7
        u32        ID;             //CAN ID
        u8        DataBuffer[8];  //数据缓存
}CAN_DataDef;
CAN_DataDef CAN1_Tx;
CAN_DataDef CAN1_Rx[8];
bit B_CanRead;      //CAN 收到数据标志
bit B_1ms;          //1ms标志
u16 msecond;
/*************  本地函数声明    **************/
void CANInit();
u8 CanReadReg(u8 addr);
u8 CanReadMsg(CAN_DataDef *CAN);
void CanSendMsg(CAN_DataDef *CAN);
/********************* 主函数 *************************/
void main(void)
        u8 sr,i,n;
    WTST = 0;  //设置程序指令延时参数,赋值为0可将CPU执行指令的速度设置为最快
    EAXFR = 1; //扩展寄存器(XFR)访问使能
    CKCON = 0; //提高访问XRAM速度
    P0M1 = 0x30;   P0M0 = 0x30;   //设置P0.4、P0.5为漏极开路(实验箱加了上拉电阻到3.3V)
    P1M1 = 0x32;   P1M0 = 0x32;   //设置P1.1、P1.4、P1.5为漏极开路(实验箱加了上拉电阻到3.3V), P1.1在PWM当DAC电路通过电阻串联到P2.3
    P2M1 = 0x3c;   P2M0 = 0x3c;   //设置P2.2~P2.5为漏极开路(实验箱加了上拉电阻到3.3V)
    P3M1 = 0x50;   P3M0 = 0x50;   //设置P3.4、P3.6为漏极开路(实验箱加了上拉电阻到3.3V)
    P4M1 = 0x3c;   P4M0 = 0x3c;   //设置P4.2~P4.5为漏极开路(实验箱加了上拉电阻到3.3V)
    P5M1 = 0x0c;   P5M0 = 0x0c;   //设置P5.2、P5.3为漏极开路(实验箱加了上拉电阻到3.3V)
    P6M1 = 0xff;   P6M0 = 0xff;   //设置为漏极开路(实验箱加了上拉电阻到3.3V)
    P7M1 = 0x00;   P7M0 = 0x00;   //设置为准双向口
        AUXR = 0x80;    //Timer0 set as 1T, 16 bits timer auto-reload,
        TH0 = (u8)(Timer0_Reload / 256);
        TL0 = (u8)(Timer0_Reload % 256);
        ET0 = 1;    //Timer0 interrupt enable
        TR0 = 1;    //Tiner0 run
        CANInit();
        EA = 1;                 //打开总中断
        CAN1_Tx.FF = EXTENDED_FRAME;    //扩展帧
        CAN1_Tx.RTR = 0;                //0:数据帧,1:远程帧
        CAN1_Tx.DLC = 0x08;             //数据长度
        CAN1_Tx.ID = 0x01234567;        //CAN ID
        CAN1_Tx.DataBuffer[0] = 0x21;   //数据内容
        CAN1_Tx.DataBuffer[1] = 0x22;
        CAN1_Tx.DataBuffer[2] = 0x23;
        CAN1_Tx.DataBuffer[3] = 0x24;
        CAN1_Tx.DataBuffer[4] = 0x25;
        CAN1_Tx.DataBuffer[5] = 0x26;
        CAN1_Tx.DataBuffer[6] = 0x27;
        CAN1_Tx.DataBuffer[7] = 0x28;
                if(B_1ms)   //1ms到
                        B_1ms = 0;
                        if(++msecond >= 1000)   //1秒到
                                msecond = 0;
                                sr = CanReadReg(SR);
                                if(sr & 0x01)                //判断是否有 BS:BUS-OFF状态
                                        CANAR = MR;
                    CanSendMsg(&CAN1_Tx);   //发送一帧数据
                if(B_CanRead)
                        B_CanRead = 0;
            n = CanReadMsg(CAN1_Rx);    //读取接收内容
            if(n>0)
                for(i=0;i<n;i++)
                    CanSendMsg(&CAN1_Rx[i]);  //CAN总线原样返回
/********************** Timer0 1ms中断函数 ************************/
void timer0 (void) interrupt 1
    B_1ms = 1;      //1ms标志
// 函数: u8 ReadReg(u8 addr)
// 描述: CAN功能寄存器读取函数。
// 参数: CAN功能寄存器地址.
// 返回: CAN功能寄存器数据.
// 版本: VER1.0
// 日期: 2020-11-16
// 备注:
        u8 dat;
        CANAR = addr;
        dat = CANDR;
        return dat;
// 函数: void WriteReg(u8 addr, u8 dat)
// 描述: CAN功能寄存器配置函数。
// 参数: CAN功能寄存器地址, CAN功能寄存器数据.
// 返回: none.
// 版本: VER1.0
// 日期: 2020-11-16
// 备注:
void CanWriteReg(u8 addr, u8 dat)
        CANAR = addr;
        CANDR = dat;
// 函数: void CanReadFifo(CAN_DataDef *CANx)
// 描述: 读取CAN缓冲区数据函数。
// 参数: *CANx: 存放CAN总线读取数据.
// 返回: none.
// 版本: VER2.0
// 日期: 2023-01-31
// 备注:
void CanReadFifo(CAN_DataDef *CAN)
    u8 i;
    u8 pdat[5];
    u8 RX_Index=0;
    pdat[0] = CanReadReg((u8)(RX_BUF0 + (RX_Index++&3)));
    if(pdat[0] & 0x80)  //判断是标准帧还是扩展帧
        pdat[1] = CanReadReg((u8)(RX_BUF0 + (RX_Index++&3)));   //扩展帧ID占4个字节
        pdat[2] = CanReadReg((u8)(RX_BUF0 + (RX_Index++&3)));
        pdat[3] = CanReadReg((u8)(RX_BUF0 + (RX_Index++&3)));
        pdat[4] = CanReadReg((u8)(RX_BUF0 + (RX_Index++&3)));
        CAN->ID = (((u32)pdat[1] << 24) + ((u32)pdat[2] << 16) + ((u32)pdat[3] << 8) + pdat[4]) >> 3;
        pdat[1] = CanReadReg((u8)(RX_BUF0 + (RX_Index++&3)));   //标准帧ID占2个字节
        CAN->ID = ((pdat[1] << 8) + pdat[2]) >> 5;
    CAN->FF = pdat[0] >> 7;     //帧格式
    CAN->RTR = pdat[0] >> 6;    //帧类型
    CAN->DLC = pdat[0];         //数据长度
    for(i=0;((i<CAN->DLC) && (i<8));i++)        //读取数据长度为len,最多不超过8
        CAN->DataBuffer[i] = CanReadReg((u8)(RX_BUF0 + (RX_Index++&3)));   //读取有效数据
    while(RX_Index&3)   //判断已读数据长度是否4的整数倍
        CanReadReg((u8)(RX_BUF0 + (RX_Index++&3)));  //读取填充数据,一帧数据占据4的整数倍缓冲区空间,不足补0
// 函数: u8 CanReadMsg(void)
// 描述: CAN接收数据函数。
// 参数: *CANx: 存放CAN总线读取数据..
// 返回: 帧个数.
// 版本: VER2.0
// 日期: 2023-01-31
// 备注:
    u8 i;
    u8 n=0;
    do{
        CanReadFifo(&CAN[n++]);  //读取接收缓冲区数据
        i = CanReadReg(SR);
    }while(i&0x80);     //判断接收缓冲区里是否还有数据,有的话继续读取
    return n;   //返回帧个数
// 函数: void CanSendMsg(CAN_DataDef *CAN)
// 描述: CAN发送标准帧函数。
// 参数: *CANx: 存放CAN总线发送数据..
// 返回: none.
// 版本: VER1.0
// 日期: 2020-11-19
// 备注:
        u32 CanID;
    u8 RX_Index,i;
    if(CAN->FF)     //判断是否扩展帧
        CanID = CAN->ID << 3;
        CanWriteReg(TX_BUF0,CAN->DLC|((u8)CAN->RTR<<6)|0x80);        //bit7: 标准帧(0)/扩展帧(1), bit6: 数据帧(0)/远程帧(1), bit3~bit0: 数据长度(DLC)
        CanWriteReg(TX_BUF1,(u8)(CanID>>24));
        CanWriteReg(TX_BUF2,(u8)(CanID>>16));
        CanWriteReg(TX_BUF3,(u8)(CanID>>8));
        CanWriteReg(TX_BUF0,(u8)CanID);
        RX_Index = 1;
        for(i=0;((i<CAN->DLC) && (i<8));i++)        //数据长度为DLC,最多不超过8
            CanWriteReg((u8)(TX_BUF0 + (RX_Index++&3)),CAN->DataBuffer[i]);   //写入有效数据
            CanWriteReg((u8)(TX_BUF0 + (RX_Index++&3)),0x00);  //写入填充数据,一帧数据占据4的整数倍缓冲区空间,不足补0
    else    //发送标准帧
        CanID = (u16)(CAN->ID << 5);
        CanWriteReg(TX_BUF0,CAN->DLC|((u8)CAN->RTR<<6));  //bit7: 标准帧(0)/扩展帧(1), bit6: 数据帧(0)/远程帧(1), bit3~bit0: 数据长度(DLC)
        CanWriteReg(TX_BUF1,(u8)(CanID>>8));
        CanWriteReg(TX_BUF2,(u8)CanID);
        RX_Index = 3;
        CanWriteReg(CMR ,0x04);                //发起一次帧传输
// 函数: void CANSetBaudrate()
// 描述: CAN总线波特率设置函数。
// 参数: none.
// 返回: none.
// 版本: VER1.0
// 日期: 2020-11-19
// 备注:
        CanWriteReg(BTR0,(SJW << 6) + BRP);
        CanWriteReg(BTR1,(SAM << 7) + (TSG2 << 4) + TSG1);
// 函数: void CANInit()
// 描述: CAN初始化函数。
// 参数: none.
// 返回: none.
// 版本: VER1.0
// 日期: 2020-11-19
// 备注:
void CANInit()
        CANEN = 1;          //CAN1模块使能
        CanWriteReg(MR  ,0x05);  //使能 Reset Mode, 采用单滤波设置
        CANSetBaudrate();        //设置波特率
        //设置过滤ID为:xxF8xxxx 的帧才接收
//        CanWriteReg(ACR0,0x07);                //总线验收代码寄存器
//        CanWriteReg(ACR1,0xc0);
//        CanWriteReg(ACR2,0x00);
//        CanWriteReg(ACR3,0x00);
//        CanWriteReg(AMR0,0xF8);                //总线验收屏蔽寄存器
//        CanWriteReg(AMR1,0x07);
//        CanWriteReg(AMR2,0xFF);
//        CanWriteReg(AMR3,0xFF);
        //取消过滤ID,所有帧都接收
        CanWriteReg(ACR0,0x00);                //总线验收代码寄存器
        CanWriteReg(ACR1,0x00);
        CanWriteReg(AMR0,0xFF);                //总线验收屏蔽寄存器
        CanWriteReg(AMR1,0xFF);
        CanWriteReg(IMR ,0xff);                //中断寄存器
        CanWriteReg(ISR ,0xff);                //清中断标志
        CanWriteReg(MR  ,0x01);                //退出 Reset Mode, 采用单滤波设置(设置过滤器后注意选择滤波模式)
//        CanWriteReg(MR  ,0x00);                //退出 Reset Mode, 采用双滤波设置(设置过滤器后注意选择滤波模式)
        P_SW1 = (P_SW1 & ~(3<<4)) | (0<<4); //端口切换(CAN_Rx,CAN_Tx) 0x00:P0.0,P0.1  0x10:P5.0,P5.1  0x20:P4.2,P4.5  0x30:P7.0,P7.1
        CANICR = 0x02;                //CAN中断使能
// 函数: void CANBUS_Interrupt(void) interrupt CAN1_VECTOR
// 描述: CAN总线中断函数。
// 参数: none.
// 返回: none.
// 版本: VER1.0
// 日期: 2020-11-19
// 备注:
        u8 isr;
        u8 arTemp;
        arTemp = CANAR;     //CANAR现场保存,避免主循环里写完 CANAR 后产生中断,在中断里修改了 CANAR 内容
        if((isr & 0x04) == 0x04)  //TI
                CANAR = ISR;
                CANDR = 0x04;    //CLR FLAG
                CANAR = ISR;
                CANDR = 0x08;    //CLR FLAG
                B_CanRead = 1;
        if((isr & 0x40) == 0x40)  //ALI
                CANAR = ISR;
                CANDR = 0x40;    //CLR FLAG
                CANAR = ISR;
                CANDR = 0x20;    //CLR FLAG
        if((isr & 0x10) == 0x10)  //EPI
                CANAR = ISR;
                CANDR = 0x10;    //CLR FLAG
        if((isr & 0x02) == 0x02)  //BEI
                CANAR = ISR;
                CANDR = 0x02;    //CLR FLAG
        if((isr & 0x01) == 0x01)  //DOI
                CANAR = ISR;
                CANDR = 0x01;    //CLR FLAG
        CANAR = arTemp;    //CANAR现场恢复
试试这个,感觉你的中断没配好
