查看: 1538|回复: 7
好想有人给我解释一下这个单片机程序代码啊,顶不住了
ID:1047868 发表于 2022-10-16 10:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
uchar ms=26,a,qiangda,flag2,xs=5,n=20;
sbit we1 = P2^1;
sbit we2 = P2^2;
sbit we3 = P2^3;
sbit we4 = P2^4;
sbit beep = P3^7;
sbit zhuchi = P3^6;
sbit S1 = P1^0;
sbit S2 = P1^1;
sbit S3 = P1^2;
sbit S4 = P1^3;
sbit S5 = P1^4;
sbit S6 = P1^5;
sbit Sa = P1^6;
sbit Sj = P1^7;
sbit L1=P3^5;
uchar code tab[]={ 0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
void delay(uint z);
void display();
void init();
void key();
        init();
                display();
                key();
   void timer1() interrupt 3
        TH1 = 0X4b;
        TL1 = 0Xfe;
        a++;
        if(a == 20 && qiangda == 1)
                a = 0;
                ms--;
                if(ms == 0 && qiangda == 1)
                        ms = 0;
                        TR1 = 0;
                        P0 = 0;
                    beep = 1;
                        qiangda = 0;
                        L1=1;
                        delay(20000);
                        L1=0;
        if(a == 20 && flag2 == 1)
                a = 0;
                ms--;
                if(ms == 0)
                        ms = 0;
                        TR1 = 0;
                        P0 = 0;
            beep = 1;
                        L1=1;
                        delay(20000);
                        L1=0;
   void delay(uint z)
        uchar x,y;
        for(x = z;x > 0;x--)
                for(y = 114;y > 0;y--);
   void display()
        we1 = 0;P0=tab[xs]; delay(1);we1 = 1;
        we2 = 0;P0=0x40;delay(1);we2 = 1;
        we3 = 0;P0=tab[ms/10];delay(1);we3 = 1;
        we4 = 0;P0=tab[ms%10];delay(1);we4 = 1;
   void key()
        if(zhuchi == 0)
                        delay(5);
                        if(zhuchi == 0)
                        TR1 = ~TR1;
                        ms=5;
                        xs=0;
                        qiangda = 1;
                        beep=0;delay(2000);beep=1;
                        while(!zhuchi);
        if(Sa == 0)
                        delay(10);
                if(Sa == 0)
                            n++;
                            ms=n;
                            if(n==30)
                             {n=4;}
                             display();
                            while(!Sa);
    if(Sj == 0)
                        delay(10);
                        if(Sj == 0)
                            n--;
                            ms=n;
                            if(n==5)
                             {n=31;}
                            display();
                            while(!Sj);
         if(qiangda == 1)
                        P1=0xff;
                        if(P1 != 0xff)
                                delay(5);
                                if(P1 != 0xff)
                            switch(P1)
                                          case 0xfe:{TR1=0;xs=1;TR1=1;flag2=1;qiangda = 0;beep = 0;delay(2000);beep = 1;ms = n;};break;
                                          case 0xfd:{TR1=0;xs=2;TR1=1;flag2=1;qiangda = 0;beep = 0;delay(2000);beep = 1;ms = n;};break;
                                          case 0xfb:{TR1=0;xs=3;TR1=1;flag2=1;qiangda = 0;beep = 0;delay(2000);beep = 1;ms = n;};break;
                                          case 0xf7:{TR1=0;xs=4;TR1=1;flag2=1;qiangda = 0;beep = 0;delay(2000);beep = 1;ms = n;};break;
                                          case 0xef:{TR1=0;xs=5;TR1=1;flag2=1;qiangda = 0;beep = 0;delay(2000);beep = 1;ms = n;};break;
                                          case 0xdf:{TR1=0;xs=6;TR1=1;flag2=1;qiangda = 0;beep = 0;delay(2000);beep = 1;ms = n;};break;
void init()
L1=0;
         a = 0;
ms = 5;
        beep = 1;
        TMOD = 0x10;
        TH1 = 0X4b;
        TL1 = 0Xfe;
         EA = 1;
        ET1 = 1;
        TR1 = 0;
ID:310441 发表于 2022-10-16 17:19 | 只看该作者
这个代码晃了一眼,应该是比较简单的代码。
有定时器,有“主持”,“抢答”等拼音,功能也很清晰。
建议新手学习不要偷懒,
认真的自己一行一行的加注释。
ID:137736 发表于 2022-10-16 17:50 | 只看该作者
一句注释也没有,差评
ID:401564 发表于 2022-10-16 18:08 | 只看该作者
这个只是一个简单的基础8051
并没有用到什么复杂的算法,甚至可以说是半点算法都没有
几乎没有难度可言
你觉得太难,那只是你基础没有打好而已
ID:491577 发表于 2022-10-17 10:14 | 只看该作者
楼主基础太差,到处是延时函数,定时器你以为是拿来看的吗?大于1ms的延时都是用定时器产生的。你的中断程序都用长延时函数不出错才怪。估计第一个中断程序还没有执行完,第二、三个中断又到了,永远都在中断中。
ID:842100 发表于 2022-10-17 15:01 | 只看该作者
你发的太乱了,帮你整理了一下,让你看的舒服容易理解,但是程序不能用。
#include <reg52.h>
sbit we1 = P2^1;
sbit we2 = P2^2;
sbit we3 = P2^3;
sbit we4 = P2^4;
sbit beep = P3^7;
sbit zhuchi = P3^6;
sbit S1 = P1^0;
sbit S2 = P1^1;
sbit S3 = P1^2;
sbit S4 = P1^3;
sbit S5 = P1^4;
sbit S6 = P1^5;
sbit Sa = P1^6;
sbit Sj = P1^7;
sbit L1=P3^5;
void delay(uint z);
void display();
void init();
void key();
       void init()
         L1=0;
         a = 0;
         ms = 5;
         beep = 1;
         TMOD = 0x10;
         TH1 = 0X4b;
         TL1 = 0Xfe;
         EA = 1;
         ET1 = 1;
         TR1 = 0;
                void display()
                void key()
                  if(zhuchi == 0)
                        delay(5);
                        if(zhuchi == 0)
                        TR1 = ~TR1;
                        ms=5;
                        xs=0;
                        qiangda = 1;
                        while(!zhuchi);
              if(Sa == 0)
                        delay(10);
                        if(Sa == 0)
                            beep=0;                            delay(2000);                            beep=1;
                            n++;
                            ms=n;
                            if(n==30)
                             {n=4;}
                             display();
                            while(!Sa);
              if(Sj == 0)
                        delay(10);
                        if(Sj == 0)
                            n--;
                            ms=n;
                            if(n==5)
                             {n=31;}
                            display();
                            while(!Sj);
            if(qiangda == 1)
                        P1=0xff;
                        if(P1 != 0xff)
                                delay(5);
                                if(P1 != 0xff)
                            switch(P1)
        TH1 = 0X4b;
        TL1 = 0Xfe;
        a++;
                a = 0;
                ms--;
                        ms = 0;
                        TR1 = 0;
                        P0 = 0;
                        beep = 1;
                        qiangda = 0;
                        L1=1;
                        delay(20000);
                        L1=0;
                a = 0;
                ms--;
                if(ms == 0)
                        ms = 0;
                        TR1 = 0;
                        P0 = 0;
            beep = 1;
                        L1=1;
                        delay(20000);
                        L1=0;
   void delay(uint z)
        uchar x,y;
   void display()
ID:584814 发表于 2022-10-17 16:21 | 只看该作者
四位数码管抢答器,主持人1坐席6,大概就是这。
如果连这个也要发帖求助的话,基本上可以绕开单片机这行了。
PS:真想必须有答案又不想自已动脑可上假货宝上买买买
ID:883242 发表于 2022-10-17 23:16 | 只看该作者
hhh402 发表于 2022-10-17 10:14
楼主基础太差,到处是延时函数,定时器你以为是拿来看的吗?大于1ms的延时都是用定时器产生的。你的中断程 ...
其实main函数初始化完毕后就撒手人寰,所有处理都在中断里面是很寻常的写法。
