- #include "remote.h"
- #include "delay.h"
- #include "usart.h"
- //红外遥控初始化
- //设置IO以及定时器4的输入捕获
- void Remote_Init(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- NVIC_InitTypeDef NVIC_InitStructure;
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_ICInitTypeDef TIM_ICInitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE); //使能PORTB时钟
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4,ENABLE); //TIM4 时钟使能
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PB9 输入
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //上拉输入
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- GPIO_SetBits(GPIOB,GPIO_Pin_9); //初始化GPIOB.9
- TIM_TimeBaseStructure.TIM_Period = 10000; //设定计数器自动重装值 最大10ms溢出
- TIM_TimeBaseStructure.TIM_Prescaler =(72-1); //预分频器,1M的计数频率,1us加1.
- TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割:TDTS = Tck_tim
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式
- TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure); //根据指定的参数初始化TIMx
- TIM_ICInitStructure.TIM_Channel = TIM_Channel_4; // 选择输入端 IC4映射到TI4上
- TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; //上升沿捕获
- TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
- TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; //配置输入分频,不分频
- TIM_ICInitStructure.TIM_ICFilter = 0x03;//IC4F=0011 配置输入滤波器 8个定时器时钟周期滤波
- TIM_ICInit(TIM4, &TIM_ICInitStructure);//初始化定时器输入捕获通道
- TIM_Cmd(TIM4,ENABLE ); //使能定时器4
- NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn; //TIM3中断
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; //先占优先级0级
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //从优先级3级
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
- NVIC_Init(&NVIC_InitStructure); //根据NVIC_InitStruct中指定的参数初始化外设NVIC寄存器
- TIM_ITConfig( TIM4,TIM_IT_Update|TIM_IT_CC4,ENABLE);//允许更新中断 ,允许CC4IE捕获中断
- //遥控器接收状态
- //[7]:收到了引导码标志
- //[6]:得到了一个按键的所有信息
- //[5]:保留
- //[4]:标记上升沿是否已经被捕获
- //[3:0]:溢出计时器
- u8 RmtSta=0;
- u16 Dval; //下降沿时计数器的值
- u32 RmtRec=0; //红外接收到的数据
- u8 RmtCnt=0; //按键按下的次数
- //定时器4中断服务程序
- void TIM4_IRQHandler(void)
- if(TIM_GetITStatus(TIM4,TIM_IT_Update)!=RESET)
- if(RmtSta&0x80) //上次有数据被接收到了
- RmtSta&=~0X10; //取消上升沿已经被捕获标记
- if((RmtSta&0X0F)==0X00)RmtSta|=1<<6; //标记已经完成一次按键的键值信息采集
- if((RmtSta&0X0F)<14)RmtSta++;
- else
- RmtSta&=~(1<<7); //清空引导标识
- RmtSta&=0XF0; //清空计数器
- if(TIM_GetITStatus(TIM4,TIM_IT_CC4)!=RESET)
- if(RDATA)//上升沿捕获
- TIM_OC4PolarityConfig(TIM4,TIM_ICPolarity_Falling); //CC4P=1 设置为下降沿捕获
- TIM_SetCounter(TIM4,0); //清空定时器值
- RmtSta|=0X10; //标记上升沿已经被捕获
- }else //下降沿捕获
- Dval=TIM_GetCapture4(TIM4); //读取CCR4也可以清CC4IF标志位
- TIM_OC4PolarityConfig(TIM4,TIM_ICPolarity_Rising); //CC4P=0 设置为上升沿捕获
- if(RmtSta&0X10) //完成一次高电平捕获
- if(RmtSta&0X80)//接收到了引导码
- if(Dval>300&&Dval<800) //560为标准值,560us
- RmtRec<<=1; //左移一位.
- RmtRec|=0; //接收到0
- }else if(Dval>1400&&Dval<1800) //1680为标准值,1680us
- RmtRec|=1; //接收到1
- }else if(Dval>2200&&Dval<2600) //得到按键键值增加的信息 2500为标准值2.5ms
- RmtCnt++; //按键次数增加1次
- RmtSta&=0XF0; //清空计时器
- }else if(Dval>4200&&Dval<4700) //4500为标准值4.5ms
- RmtSta|=1<<7; //标记成功接收到了引导码
- RmtCnt=0; //清除按键次数计数器
- RmtSta&=~(1<<4);
- TIM_ClearITPendingBit(TIM4,TIM_IT_Update|TIM_IT_CC4);
- //处理红外键盘
- //返回值:
- // 0,没有任何按键按下
- //其他,按下的按键键值.
- u8 Remote_Scan(void)
- u8 sta=0;
- u8 t1,t2;
- if(RmtSta&(1<<6))//得到一个按键的所有信息了
- t1=RmtRec>>24; //得到地址码
- t2=(RmtRec>>16)&0xff; //得到地址反码
- if((t1==(u8)~t2)&&t1==REMOTE_ID)//检验遥控识别码(ID)及地址
- t1=RmtRec>>8;
- t2=RmtRec;
- if(t1==(u8)~t2)sta=t1;//键值正确
- if((sta==0)||((RmtSta&0X80)==0))//按键数据错误/遥控已经没有按下了
- RmtSta&=~(1<<6);//清除接收到有效按键标识
- return sta;
- #include "led.h"
- #include "key.h"
- #include "sys.h"
- #include "lcd.h"
- int main(void)
- u8 key;
- u8 t=0;
- u8 *str=0;
- delay_init(); //延时函数初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置中断优先级分组为组2:2位抢占优先级,2位响应优先级
- uart_init(115200); //串口初始化为115200
- LED_Init(); //LED端口初始化
- LCD_Init();
- KEY_Init();
- Remote_Init(); //红外接收初始化
- POINT_COLOR=RED; //设置字体为红色
- LCD_ShowString(30,50,200,16,16,"WarShip STM32");
- LCD_ShowString(30,70,200,16,16,"REMOTE TEST");
- LCD_ShowString(30,90,200,16,16,"ATOM@ALIENTEK");
- LCD_ShowString(30,110,200,16,16,"2015/1/15");
- LCD_ShowString(30,130,200,16,16,"KEYVAL:");
- LCD_ShowString(30,150,200,16,16,"KEYCNT:");
- LCD_ShowString(30,170,200,16,16,"SYMBOL:");
- while(1)
- key=Remote_Scan();
- if(key)
- LCD_ShowNum(86,130,key,3,16); //显示键值
- LCD_ShowNum(86,150,RmtCnt,3,16); //显示按键次数
- switch(key)
- case 0:str="ERROR";break;
- case 162:str="POWER";break;
- case 98:str="UP";break;
- case 2:str="PLAY";break;
- case 226:str="ALIENTEK";break;
- case 194:str="RIGHT";break;
- case 34:str="LEFT";break;
- case 224:str="VOL-";break;
- case 168:str="DOWN";break;
- case 144:str="VOL+";break;
- case 104:str="1";break;
- case 152:str="2";break;
- case 176:str="3";break;
- case 48:str="4";break;
- case 24:str="5";break;
- case 122:str="6";break;
- case 16:str="7";break;
- case 56:str="8";break;
- case 90:str="9";break;
- case 66:str="0";break;
- case 82:str="DELETE";break;
- LCD_Fill(86,170,116+8*8,170+16,WHITE); //清楚之前的显示
- LCD_ShowString(86,170,200,16,16,str); //显示SYMBOL
- }else delay_ms(10);
- t++;
- if(t==20)
- t=0;
- LED0=!LED0;
Keil代码下载(只有代码不含其他任何资料,非原创):
红外遥控实验.7z
(225.98 KB, 下载次数: 47)
