#include<reg52.h>
#include<intrins.h>
sbit RS = P2^0; //定义端口 lcd1602
sbit RW = P2^1;
sbit EN = P2^2;
sbit CS2 = P1^5; //0832接口定义
sbit CLK = P1^6;
sbit DIO = P1^7;
#define RS_CLR RS=0
#define RS_SET RS=1
#define RW_CLR RW=0
#define RW_SET RW=1
#define EN_CLR EN=0
#define EN_SET EN=1
#define DataPort P0
sbit led=P3^0;
sbit led1=P3^2;
sbit led2=P3^3;
sbit bee=P3^1; //蜂鸣器
sbit key1=P3^4; //4个按键
sbit key2=P3^5;
sbit key3=P3^6;
sbit key4=P3^7;
sbit key5=P1^0;
uchar h=75; //初始上限值
uchar l=50;
sbit motor=P3^2; //风扇
sbit xia=P3^3; //喷洒
uint i,d; //烟雾值检测
uint time=0;
unsigned long S;
uchar safe=10;
uchar dis1[6];
bit flag=0; //标志位
uint flag1;
bit flag2=0;
uchar flag3=0;
uchar re=0;
void delay_100us()
uchar j;
for(j=0;j<31;j++)
延时程序
void delay_ms(uint j)
uint i;
for(;j>0;j--)
for(i=0;i<113;i++)
写入命令函数
void LCD_Write_Com(uchar com)
delay_ms(5);
RS_CLR;
RW_CLR;
EN_SET;
DataPort=com;
_nop_();
EN_CLR;
写入数据函数
void LCD_Write_Data(uchar Data)
delay_ms(5);
RS_SET;
RW_CLR;
EN_SET;
DataPort= Data;
_nop_();
EN_CLR;
写入字符串函数
void LCD_Write_String(uchar x,uchar y,uchar *s)
if (y == 0)
LCD_Write_Com(0x80 + x); //表示第一行
LCD_Write_Com(0xC0 + x); //表示第二行
while (*s)
LCD_Write_Data( *s);
s ++;
写入慢速字符串函数
void LCD_Write_SlowString(uchar x,uchar y,uchar *s)
if (y == 0)
while (*s)
s ++;
delay_ms(200);
写入字符函数
void LCD_Write_Char(uchar x,uchar y,uchar Data)
if (y == 0)
LCD_Write_Data( Data);
初始化函数
void LCD_Init(void)
delay_ms(15);
LCD_Write_Com(0x38); /*显示模式设置*/
LCD_Write_Com(0x0c); /*显示开及光标设置 */
LCD_Write_Com(0x06); /*显示光标移动设置 */
LCD_Write_Com(0x01); /*显示清屏 */
void display() //显示处理子程序
dis1[3]=i/100; //提取安全值的十位数,赋值给dis1[12]
dis1[4]=i/10%10; //提取安全值的个位数,赋值给dis1[13]
dis1[5]=i%10; //提取安全值的个位数,赋值给dis1[13]
LCD_Write_Char(0,1,'Y'); //液晶显示数据
LCD_Write_Char(1,1,':');
LCD_Write_Char(2,1,dis1[3]+0x30);
LCD_Write_Char(3,1,dis1[4]+0x30);
LCD_Write_Char(4,1,dis1[5]+0x30);
LCD_Write_Char(9,1,'J'); //液晶显示
LCD_Write_Char(10,1,':');
LCD_Write_Char(11,1,d/100+0x30);
LCD_Write_Char(12,1,d/10%10+0x30);
LCD_Write_Char(13,1,d%10+0x30);
dis1[0]=h/100; //提取百位数,赋值给dis1[0]
dis1[1]=h/10%10; //提取十位数,赋值给dis1[1]
dis1[2]=h%10; //提取个位数,赋值给dis1[2]
LCD_Write_Char(8,0,dis1[0]+0x30);
LCD_Write_Char(9,0,dis1[1]+0x30);
LCD_Write_Char(10,0,dis1[2]+0x30);
delay_ms(1);
void key_process()
if(key1==0) //按键1
delay_ms(10);
if(key1==0)
while(!key1);
h++;
if(h>=85) h=85;
if(key2==0) //按键2
delay_ms(10);
if(key2==0)
while(!key2);
h--;
if(h<=65) h=65;
unsigned char A_D(bit flag)
unsigned char i,dat;
CS2=1; //一个转换周期开始
CLK=0; //为第一个脉冲作准备
CS2=0; //CS2置0,片选有效
DIO=1; //DIO置1,规定的起始信号
CLK=1; //第一个脉冲
CLK=0; //第一个脉冲的下降沿,此前DIO必须是高电平
DIO=1; //DIO置1, 通道选择信号
CLK=1; //第二个脉冲,第2、3个脉冲下沉之前,DI必须跟别输入两位数据用于选择通道,这里选通道CH0
CLK=0; //第二个脉冲下降沿
DIO=flag; //DI置0,选择通道0
CLK=1; //第三个脉冲
CLK=0; //第三个脉冲下降沿
DIO=1; //第三个脉冲下沉之后,输入端DIO失去作用,应置1
CLK=1; //第四个脉冲
for(i=0;i<8;i++) //高位在前
CLK=1; //第四个脉冲
CLK=0;
dat<<=1; //将下面储存的低位数据向右移
dat|=(unsigned char)DIO; //将输出数据DIO通过或运算储存在dat最低位
CS2=1; //片选无效
return dat; //将读书的数据返回
delay_ms(5); //延时5ms
LCD_Init(); //液晶1602初始化
TMOD=0x01;
ET0=1;
EA=0;
LCD_Write_String(0,0,"ZNTL ");
LCD_Write_String(6,0,"S: ");
LCD_Write_Char(15,0,re+0x30);
key_process(); //按键扫描
display(); //1602液晶显示
if(flag3==0)
i=A_D(0)/2;
d=A_D(1)/2;
flag3++;
if(flag3>=50) flag3=0; //自加3次再检测 (甲烷)
if(i>=h&&flag==0) motor=0;
else motor=1;
if(d>=50) bee=0; //报警
else bee=1;
if(key5==0) //红外检测不到
flag=1;
motor=1;
xia=1;
re=1;
while(!key5)
i=A_D(0)/2;
if(flag==1)
if(i>=h)
motor=0;
xia=1;
flag2=1;
if(i<h&&flag2==1)
xia=0;
motor=1;
flag1++;
if(flag1>=600)
flag1=0;
flag=0;
xia=1;
flag2=0;
re=0;
delay_ms(1);
