查看: 1371|回复: 11
单片机简易时钟程序错误
这是什么原因啊?
  1. #include<reg51.h>
  2. #include<intrins.h>
  3. #define uint unsigned int
  5. void Delayms(uint x);
  6. sbit L=P2^0;
  7. sbit LA=P2^1;
  8. sbit LB=P2^2;
  9. void Display();
  10. sbit key1=P3^3;
  11. sbit key2=P3^4;
  12. sbit key3=P3^5;
  13. /*位码*/uchar tablew[]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07};
  14. /*位选*/uchar shu[8]={0};
  15. /*共阴极*/
  16. uchar table6[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  17. uint aa,bb,cc,dd;
  18. void main()
  19. {
  20. TMOD=0x01;//设置工作方式
  21. TH0=0x3c;//设置定时器高八位
  22. TL0=0xb0;//设置定时器低八位
  23. ET0=1;//打开定时器T0的中断开关
  24. TR0=1;//启动定时器T0工作
  25. EA=0;//打开总中断开关
  26. while(1)
  27.         {
  28.      uchar mshi,mge,fshi,fge,sshi,sge;
  29.      if(key1==0)
  30.      {
  31.                 EA=1;
  32.      }
  33.      else if(key2==0)
  34.          {
  35.           EA=0;
  36.          }
  37.      else if(key3==0)
  38.      {
  39.       bb=0;cc=0;dd=0;
  40.       }
  41.       else;
  42. mshi=bb/10;
  43. mge=bb%10;
  44. if(bb>59)
  45. {
  46. bb=0;
  47. cc++;
  48. }
  49. fshi=cc/10;
  50. fge=cc%10;
  51. if(cc>59)
  52. {
  53. cc=0;
  54. dd++;
  55. }
  56. sshi=dd/10;
  57. sge=dd%10;
  58. if(dd>23)
  59. {
  60. dd=0;
  61. }
  62. shu[7]=table6[mge];
  63. shu[6]=table6[mshi];
  64. shu[5]=0x40;
  65. shu[4]=table6[fge];
  66. shu[3]=table6[fshi];
  67. shu[2]=0x40;
  68. shu[1]=table6[sge];
  69. shu[0]=table6[sshi];
  70. Display();
  71. }
  72. }
  73. void int0_0() interrupt 1
  74. {
  75. TH0=0x3C;
  76. TL0=0xb0;
  77. aa++;//1ms加一次
  78. if(aa>1000)
  79. {
  80. aa=0;
  81. bb++;//1S加一次
  82. }
  83. }
  84. void Display()
  85. {
  86. uint i;
  87. for(i=0;i<8;i++)
  88. {
  89. P2=tablew[i];
  90. P0=shu[i];
  91. Delayms(1);
  92. }
  93. }
  94. void Delayms(uint x)
  95. {
  96. uchar j;
  97. while(x--)
  98.         {
  99.                 for(j=0;j<125;j++);
  100.         }
  101. }
ID:213173 发表于 2023-7-4 08:08 | 只看该作者
数码管位驱动代码与硬件不符及其他变量声明处理不当。给你改了。
  5. sbit L=P2^0;
  6. sbit LA=P2^1;
  7. sbit LB=P2^2;
  8. void Display();
  9. sbit key1=P3^3;
  10. sbit key2=P3^4;
  11. sbit key3=P3^5;
  12. /*位码*///uchar tablew[]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07};
  13. /*位选*/uchar shu[8]={0,0,0x40,0,0,0x40,0,0};
  14. /*共阴极*/
  15. uchar table6[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  16. uchar Key_value,flag;
  17. uint  Time;
  18. char  shi,fen,sec;
  19. uchar num,latch;
  20. void main()
  21. {
  22.         TMOD=0x01;//设置工作方式
  23.         TH0=0xF8;//设置定时器高八位@12MHz 2ms
  24.         TL0=0x30;//设置定时器低八位@12MHz 2ms
  25.         ET0=1;//打开定时器T0的中断开关
  26.         TR0=1;//启动定时器T0工作
  27.         EA=1;//打开总中断开关
  28.         while(1)
  29.         {
  30.                 if(flag==1)//周期2ms
  31.                 {
  32.                         flag=0;//清中断标志
  33.                         //按键扫描
  34.                         if(!key1||!key2||!key3)
  35.                         {
  36.                                 if(++num>=10 && latch==0)//消抖
  37.                                 {
  38.                                         latch=1; //锁存
  39.                                         if(!key1)//设置
  40.                                         {
  41.                                                 Key_value=++Key_value%4;
  42.                                         }
  43.                                         if(!key2)//增加
  44.                                         {
  45.                                                 if(Key_value==1)shi=++shi%24;
  46.                                                 if(Key_value==2)fen=++fen%60;
  47.                                                 if(Key_value==3)sec=++sec%60;
  48.                                         }
  49.                                         if(!key3)//减小
  50.                                         {
  51.                                                 if(Key_value==1){if(--shi<0)shi=23;}
  52.                                                 if(Key_value==2){if(--fen<0)fen=59;}
  53.                                                 if(Key_value==3){if(--sec<0)sec=59;}
  54.                                         }
  55.                                 }
  56.                         }
  57.                         else //松手
  58.                         {
  59.                                 num=0;   //清0
  60.                                 latch=0; //清0
  61.                         }
  62.                         //计时
  63.                         if(Key_value==0)//非设置状态
  64.                         {
  65.                                 if(++Time>=500)//秒
  66.                                 {
  67.                                         Time=0;
  68.                                         if(++sec>=60)//分
  69.                                         {
  70.                                                 sec=0;
  71.                                                 if(++fen>=60)//时
  72.                                                 {
  73.                                                         fen=0;
  74.                                                         shi=++shi%24;
  75.                                                 }
  76.                                         }
  77.                                 }
  78.                         }
  79.                         //数据处理
  80.                         shu[7]=table6[shi/10];
  81.                         if(Key_value==1)
  82.                                 shu[6]=table6[shi%10]|0x80;//加点
  83.                         else shu[6]=table6[shi%10];
  84.                         shu[4]=table6[fen/10];
  85.                         if(Key_value==2)
  86.                                 shu[3]=table6[fen%10]|0x80;//加点
  87.                         else shu[3]=table6[fen%10];
  88.                         shu[1]=table6[sec/10];
  89.                         if(Key_value==3)
  90.                                 shu[0]=table6[sec%10]|0x80;//加点
  91.                         else shu[0]=table6[sec%10];
  92.                         //数码管动态显示
  93.                         Display();
  94.                 }
  95.         }
  96. }
  97. void int0_0() interrupt 1
  98. {
  99.         TH0=0xf8;//@12MHz 2ms
  100.         TL0=0x30;//@12MHz 2ms
  101.         flag=1;//中断标志
  102. }
  103. void Display()
  104. {
  105.         static uchar i;
  106.         P0=0x00;//段消隐
  107.         P2&=0xf8;//清位码
  108.         P2|=~i;//送位码
  109.         P0=shu[i];//送段码
  110.         i=++i%8;//循环计数
  111. }
ID:1080935 发表于 2023-7-4 08:19 | 只看该作者
仿真中数码管需要消隐处理,就是送段码前全部熄灭,送完段码打开对应的管子。
ID:332444 发表于 2023-7-4 08:49 | 只看该作者
变量声明写在主循环外,按键要有消抖,数码管要消隐,如果P2送位值那么就不用定义去138的3个引脚.
ID:140489 发表于 2023-7-4 09:04 | 只看该作者
TR0=1;//启动定时器T0工作
EA=0;//打开总中断开关
EA=1;//才能 打开总中断开关
ID:161164 发表于 2023-7-4 09:15 | 只看该作者
缺了一个HC138芯片
把P20~P22的3位信号转为8位位选信号
ID:712097 发表于 2023-7-4 11:44 | 只看该作者
问题比较多,大概列出来:
1、位码错误2、送段码前没有清零
3、共阴数码管需要加驱动,单片机IO负载能力不足
4、段码加了245IC就不用上拉电阻。
5、我贴出来的代码随便写的,好多可以精简,请自行优化。
  6. sbit L=P2^0;
  7. sbit LA=P2^1;
  8. sbit LB=P2^2;
  9. void Display();
  10. sbit key1=P3^3;
  11. sbit key2=P3^4;
  12. sbit key3=P3^5;
  13. /*位码*/uchar tablew[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
  14. uint mshi,mge,fshi,fge,sshi,sge;
  15. /*共阴极*/
  16. uchar table6[11]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40 };
  17. //{0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  18. uint aa,bb,cc,dd;
  19. //void Timer0_Init(void)                //1毫秒@12.000MHz
  20. //{
  21. //        //AUXR |= 0x80;                        //定时器时钟1T模式
  22. //        TMOD = 0x01;                        //设置定时器模式
  23. //        TL0 = (65536-1000)&0xFF;                        //设置定时初始值
  24. //        TH0 = (65536-1000)>>8;                                //设置定时初始值
  25. //        IE=0x82;
  26. //        TR0=1;
  27. //        EA=1;
  28. //}
  29. void main()
  30. {
  31.
  32.
  33. TMOD=0x01;//设置工作方式
  34. TH0=0xFC;//设置定时器高八位
  35. TL0=0x18;//设置定时器低八位
  36. ET0=1;//打开定时器T0的中断开关
  37. TR0=1;//启动定时器T0工作
  38. EA=1;//打开总中断开关
  39.         //Timer0_Init();
  40. while(1)
  41. {
  42.
  43.      if(key1==0)
  44.      {
  45.                 EA=1;
  46.      }
  47.      else if(key2==0)
  48.          {
  49.           EA=0;
  50.          }
  51.      else if(key3==0)
  52.      {
  53.       bb=0;cc=0;dd=0;
  54.       }
  55. Display();
  56. }
  57. }
  58. void int0_0() interrupt 1
  59. {
  60. TH0=0xFC;
  61. TL0=0x18;
  62. aa++;//1ms加一次
  63. if(aa>1000)
  64. {
  65. aa=0;
  66. bb++;//1S加一次
  67. }
  68. mshi=bb/10;
  69. mge=bb%10;
  70. if(bb>59)
  71. {
  72. bb=0;
  73. cc++;
  74. }
  75. fshi=cc/10;
  76. fge=cc%10;
  77. if(cc>59)
  78. {
  79. cc=0;
  80. dd++;
  81. }
  82. sshi=dd/10;
  83. sge=dd%10;
  84. if(dd>23)
  85. {
  86. dd=0;
  87. }
  88. }
  89. void Display()
  90. {
  91. uchar i;
  92. for(i=0;i<8;i++)
  93. {
  94. P0=0x00;
  95. P2=tablew[7-i];///位码
  96. switch(i)
  97. {
  98.         case 0:
  99.                 P0=table6[mge];break;
  100.         case 1:
  101.                 P0=table6[mshi];break;
  102.         case 2:
  103.                 P0=table6[10];break;
  104.         case 3:
  105.                 P0=table6[fge];break;
  106.         case 4:
  107.                 P0=table6[fshi];break;
  108.         case 5:
  109.                 P0=table6[10];break;
  110.         case 6:
  111.                 P0=table6[sge];break;
  112.         case 7:
  113.                 P0=table6[sshi];break;
  114.         default:
  115.                 P0=0x00;
  116. }
  117.
  118. Delayms(1);
  119. }
  120. }
  121. void Delayms(uint x)
  122. {
  123. uchar j;
  124. while(x--)
  125.         {
  126.                 for(j=0;j<125;j++);
  127.         }
  128. }
admin + 50 回帖助人的奖励!
ID:1086252 发表于 2023-7-4 21:02 | 只看该作者
chxelc 发表于 2023-7-4 11:44
问题比较多,大概列出来:
1、位码错误2、送段码前没有清零
3、共阴数码管需要加驱动,单片机IO负载能力 ...
你好,谢谢你给我解答问题,就是这个程序为什么按钮不能实现三个按键,启动,停止,复位功能
ID:1086252 发表于 2023-7-4 21:03 | 只看该作者
你好,谢谢你的解答,请问三个按键启动,暂停,复位功能怎么实现呢
ID:1086252 发表于 2023-7-4 23:45 | 只看该作者
问题比较多,大概列出来:
1、位码错误2、送段码前没有清零
你好,谢谢你的回复,请问如何实现按键启动,暂停,复位功能
ID:712097 发表于 2023-7-5 07:58 | 只看该作者
参考我给你的代码,
把41行EA=1;注释掉,这样上电就不会自动走时了。
把第58行bb=0;cc=0;dd=0;后面加上一句EA=1;,这样复位后时间又继续可以走了。
经过上述改动,按键从上到下启动、暂停、复位都可以用了。
ID:213173 发表于 2023-7-5 09:55 | 只看该作者
按键启动,暂停,复位只适用于秒表或倒计时,一个按键即可。时钟必须有调时功能。
