- // 把“位带地址+位序号”转换成别名地址的宏
- #define BITBAND(addr, bitnum) ((addr & 0xF0000000)+0x02000000+((addr & 0x000FFFFF)<<5)+(bitnum<<2))
- // 把一个地址转换成一个指针
- #define MEM_ADDR(addr) *((volatile unsigned long *)(addr))
- // 把位带别名区地址转换成指针
- #define BIT_ADDR(addr, bitnum) MEM_ADDR(BITBAND(addr, bitnum))
- // GPIO ODR 和 IDR 寄存器地址映射
- #define GPIOA_ODR_Addr (GPIOA_BASE+20)
- #define GPIOB_ODR_Addr (GPIOB_BASE+20)
- #define GPIOC_ODR_Addr (GPIOC_BASE+20)
- #define GPIOD_ODR_Addr (GPIOD_BASE+20)
- #define GPIOE_ODR_Addr (GPIOE_BASE+20)
- #define GPIOF_ODR_Addr (GPIOF_BASE+20)
- #define GPIOG_ODR_Addr (GPIOG_BASE+20)
- #define GPIOH_ODR_Addr (GPIOH_BASE+20)
- #define GPIOI_ODR_Addr (GPIOI_BASE+20)
- #define GPIOJ_ODR_Addr (GPIOJ_BASE+20)
- #define GPIOK_ODR_Addr (GPIOK_BASE+20)
- #define GPIOA_IDR_Addr (GPIOA_BASE+16)
- #define GPIOB_IDR_Addr (GPIOB_BASE+16)
- #define GPIOC_IDR_Addr (GPIOC_BASE+16)
- #define GPIOD_IDR_Addr (GPIOD_BASE+16)
- #define GPIOE_IDR_Addr (GPIOE_BASE+16)
- #define GPIOF_IDR_Addr (GPIOF_BASE+16)
- #define GPIOG_IDR_Addr (GPIOG_BASE+16)
- #define GPIOH_IDR_Addr (GPIOH_BASE+16)
- #define GPIOI_IDR_Addr (GPIOI_BASE+16)
- #define GPIOJ_IDR_Addr (GPIOJ_BASE+16)
- #define GPIOK_IDR_Addr (GPIOK_BASE+16)
- // 单独操作 GPIO的某一个IO口,n(0,1,2...16),n表示具体是哪一个IO口
- #define PAout(n) BIT_ADDR(GPIOA_ODR_Addr,n) //输出
- #define PAin(n) BIT_ADDR(GPIOA_IDR_Addr,n) //输入
- #define PBout(n) BIT_ADDR(GPIOB_ODR_Addr,n) //输出
- #define PBin(n) BIT_ADDR(GPIOB_IDR_Addr,n) //输入
- #define PCout(n) BIT_ADDR(GPIOC_ODR_Addr,n) //输出
- #define PCin(n) BIT_ADDR(GPIOC_IDR_Addr,n) //输入
- #define PDout(n) BIT_ADDR(GPIOD_ODR_Addr,n) //输出
- #define PDin(n) BIT_ADDR(GPIOD_IDR_Addr,n) //输入
- #define PEout(n) BIT_ADDR(GPIOE_ODR_Addr,n) //输出
- #define PEin(n) BIT_ADDR(GPIOE_IDR_Addr,n) //输入
- #define PFout(n) BIT_ADDR(GPIOF_ODR_Addr,n) //输出
- #define PFin(n) BIT_ADDR(GPIOF_IDR_Addr,n) //输入
- #define PGout(n) BIT_ADDR(GPIOG_ODR_Addr,n) //输出
- #define PGin(n) BIT_ADDR(GPIOG_IDR_Addr,n) //输入
- #define PHout(n) BIT_ADDR(GPIOH_ODR_Addr,n) //输出
- #define PHin(n) BIT_ADDR(GPIOH_IDR_Addr,n) //输入
- #define PIout(n) BIT_ADDR(GPIOI_ODR_Addr,n) //输出
- #define PIin(n) BIT_ADDR(GPIOI_IDR_Addr,n) //输入
- #define PJout(n) BIT_ADDR(GPIOJ_ODR_Addr,n) //输出
- #define PJin(n) BIT_ADDR(GPIOJ_IDR_Addr,n) //输入
- #define PKout(n) BIT_ADDR(GPIOK_ODR_Addr,n) //输出
- #define PKin(n) BIT_ADDR(GPIOK_IDR_Addr,n) //输入
复制代码 |
