这个是.c文件
//进行对应引脚配置
void MCP_PORTInit(void) //进行MCP对应的引脚配置
GPIO_InitTypeDef GPIO_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);//进行对应引脚时钟开开启 打开对应的时钟
GPIO_InitStructure.GPIO_Pin = MCP_CLK|MCP_CS; //推挽输出
GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AF;
GPIO_InitStructure.GPIO_OType=GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd =GPIO_PuPd_NOPULL;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度为50MHz
GPIO_Init(MCP_PORT, &GPIO_InitStructure); //根据设定参数初始化
GPIO_SetBits(MCP_PORT,MCP_CS|MCP_CLK); //output high
GPIO_InitStructure.GPIO_Pin = MCP_DOUT;
GPIO_InitStructure.GPIO_Mode =GPIO_Mode_IN; //进行浮空输入
uint16_t MCP3201_getAD(void) //进行数据的获取
u8 i=0;
u16 resualt=0;
//Read_DOUT_High; //如果出现测一次测不出来的情况,加个对应的拉高即可
MCP_CLK_Low;//CLK进行低电平设置
MCP_CS_Low;//CS进行低电平设置启动数据转换
delay_us(3);
//进行数据的转换
MCP_CLK_High;//CLK=1
delay_us(3);
MCP_CLK_Low;//CLK=0
delay_us(3);
delay_us(3);
//数据转换结束
MCP_CLK_Low;//CLK=0
delay_us(3);
//获取数据转换的结果
delay_us(3);
for(i=0;i<12;i++)
MCP_CLK_Low;//CLK=0
delay_us(3);
delay_us(3);
if(Read_DOUT==1)
resualt|=0x0001<<(11-i);
//关闭对应的线
MCP_CLK_Low;//CLK=0
delay_us(3);
MCP_CS_High;//CS=1 //关闭对应3201
delay_us(3);
#ifdef DEBUG
printf("GetMCP3201Value =%u\r\n",(uint16_t)(result));
printf("Vot=%u\r\n",(uint16_t)(12.2*value));
#endif
return resualt;
这个是.h文件
//对应DOUT-->SPI_MISO
//对应CS-->SPI_CS
//对应DCLK->SPI_SCK
#define MCP_PORT GPIOB
#define MCP_CS GPIO_Pin_9
#define MCP_CLK GPIO_Pin_10
#define MCP_DOUT GPIO_Pin_14
//对应引脚线
#define MCP_CLK_High GPIO_SetBits(MCP_PORT,MCP_CLK)
#define MCP_CLK_Low GPIO_ResetBits(MCP_PORT,MCP_CLK)
#define MCP_CS_High GPIO_SetBits(MCP_PORT,MCP_CS)
#define MCP_CS_Low GPIO_ResetBits(MCP_PORT,MCP_CS)
#define Read_DOUT GPIO_ReadInputDataBit(MCP_PORT,MCP_DOUT) //进行对应数据的读取
#define Read_DOUT_High GPIO_SetBits(MCP_PORT,MCP_DOUT) //进行高电平设置
希望各位大哥大姐帮我看看这个时序哪里写的不对
