#include <reg51.h>
#include "intrins.h"
uchar zkb,pwm;
uchar RunMode;
sfr P1M1 = 0x91;
sfr P1M0 = 0x92;
sfr P3M1 = 0xb1;
sfr P3M0 = 0xb2;
//**********************************System Fuction*************************************************
void Delay1ms( uint count)
uint i,j;
for(i=0;i<count;i++)
for(j=0;j<120;j++);
uchar GetKey(void)
uchar KeyTemp,CheckValue,Key = 0x00;
CheckValue = P1&0x43;
if(CheckValue==0x43)
return 0x00;
Delay1ms(10);
KeyTemp = P1&0x43;
if(KeyTemp==CheckValue)
return 0x00;
if(!(CheckValue&0x01))
Key|=0x01;
if(!(CheckValue&0x02))
Key|=0x02;
if(!(CheckValue&0x40))
Key|=0x40;
return Key;
uint TimerCount,SystemSpeed,SystemSpeedIndex;
void InitialTimer0(void) //100us@11.0592MHZ
// AUXR &= 0x7F; //定时器时钟12T模式
TMOD = 0x00; //设置定时器模式
TL0 = 0xA4; //设置定时初始值
TH0 = 0xFF; //设置定时初始值
TR0 = 1; //定时器0开始计时
ET0=1;
EA=1;
uint code SpeedCode[]={ 1, 2, 3, 5, 8, 10, 14, 17, 20, 30,
40, 50, 60, 70, 80, 90, 100, 120, 140, 160,
180, 200, 300, 400, 500, 600, 700, 800, 900,1000};//30
void SetSpeed( uchar Speed)
SystemSpeed =SpeedCode[Speed];
void LEDShow( uint LEDStatus)
P3 = (LEDStatus&0xFF);
void InitialCPU(void)
RunMode = 0x00;
TimerCount = 0;
SystemSpeedIndex = 10;
P1 = 0xFF;
P3 = 0xFF;
Delay1ms(500);
P1 = 0xFF;
P3 = 0xFF;
SetSpeed(SystemSpeedIndex);
unsigned int LEDIndex = 0;
//bit LEDDirection = 1,LEDFlag = 1;
void Mode_0(void)
SystemSpeed=1;
if(pwm>zkb)
LEDShow(LEDIndex=0xff);
LEDShow(LEDIndex=0x00);
//Mode 1
void Mode_1(void)
LEDShow(0x80>>LEDIndex);
LEDIndex = (LEDIndex+1)%8;
void TimerEventRun(void)
if(RunMode==0x00)
Mode_0();
else if(RunMode ==0x01)
Mode_1();
void Timer0(void) interrupt 1 using 1
static uchar max=0;
if(++TimerCount>=SystemSpeed)
TimerCount = 0;
TimerEventRun();
pwm++; //震荡周期变量
if(pwm>200) //如果数值大于100
pwm=0; //周期归零
if(max==0){zkb++;} //MAX占空比渐加渐减标志位 默认max为0.每一周期占空比渐加
if(max==1){zkb--;} //MAX占空比渐加渐减标志位 如果max为1.每一周期占空比渐减
if(zkb==200){max=1;} //如果占空比的值为100 标志位MAX置为1.渐减
if(zkb==0){max=0;} //如果占空比的值为0 标志位MAX置为0.渐加
unsigned char MusicIndex = 0;
void KeyDispose(unsigned char Key)
if(Key&0x01)
LEDDirection = 1;
LEDIndex = 0;
LEDFlag = 1;
RunMode = (RunMode+1)%2;
if(Key&0x02)
if(SystemSpeedIndex>0)
--SystemSpeedIndex;
if(Key&0x40)
if(SystemSpeedIndex<28)
++SystemSpeedIndex;
main()
unsigned char Key;
P1M0 = 0x00;
P1M1 = 0x00;
P3M0 = 0x00;
P3M1 = 0x00;
InitialCPU();
InitialTimer0();
Key = GetKey();
if(Key!=0x00)
KeyDispose(Key);
