查看: 492|回复: 1
这个AD转换的配置是可以直接在单片机上用的吗?
ID:1074103 发表于 2023-12-8 13:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
拜托各位大佬指导指导,下周就要去拿元件了
/* --- STC MCU International Limited -------------------------------*/
/* --- STC 1T Series MCU RC Demo -----------------------------------*/
/* If you want to use the program or the program referenced in the  */
/* article, please specify in which data and procedures from STC    */
#include        "adc.h"
ADC初始化程序
void        ADC_Inilize(ADC_InitTypeDef *ADCx)
        P1ASF = ADCx->ADC_Px;
        ADC_CONTR = (ADC_CONTR & ~ADC_90T) | ADCx->ADC_Speed;
        if(ADCx->ADC_Power == ENABLE)        ADC_CONTR |= 0x80;
        else                                                        ADC_CONTR &= 0x7F;
        if(ADCx->ADC_AdjResult == ADC_RES_H2L8)        PCON2 |=  (1<<5);
        else        PCON2 &= ~(1<<5);
        if(ADCx->ADC_Interrupt == ENABLE)        EADC = 1;                        //                ENABLE,DISABLE
        else        EADC = 0;
        if(ADCx->ADC_Polity == PolityHigh)        PADC = 1;
        else        PADC = 0;
ADC电源控制程序
void        ADC_PowerControl(u8 pwr)
        if(pwr == ENABLE)        ADC_CONTR |= 0x80;
        else                                ADC_CONTR &= 0x7f;
查询法读一次ADC结果
u16        Get_ADC10bitResult(u8 channel)        //channel = 0~7
        u16        adc;
        u8        i;
        if(channel > ADC_CH7)        return        1024;
        ADC_RES = 0;
        ADC_RESL = 0;
        ADC_CONTR = (ADC_CONTR & 0xe0) | ADC_START | channel;
        NOP(4);
        for(i=0; i<250; i++)
                if(ADC_CONTR & ADC_FLAG)
                        ADC_CONTR &= ~ADC_FLAG;
                        if(PCON2 &  (1<<5))
                                adc = (u16)(ADC_RES & 3);
                                adc = (adc << 8) | ADC_RESL;
                                adc = (u16)ADC_RES;
                                adc = (adc << 2) | (ADC_RESL & 3);
                        return        adc;
        return        1024;        //´íÎó,·µ»Ø1024,µ÷ÓõijÌÐòÅжÏ
ADC中断函数
用ad设计原理图的时候,不用另外画一个单独的ad转换模块,拜托拜托了
void ADC_int (void) interrupt ADC_VECTOR
配置ADC
void        ADC_config(void)
        ADC_InitTypeDef                ADC_InitStructure;
        ADC_InitStructure.ADC_Px        = ADC_P10;
        ADC_InitStructure.ADC_Speed     = ADC_360T;                        //                        ADC_90T,ADC_180T,ADC_360T,ADC_540T
        ADC_InitStructure.ADC_Power     = ENABLE;                        //        ENABLE,DISABLE
        ADC_InitStructure.ADC_AdjResult = ADC_RES_H8L2;                //        ADC_RES_H2L8,ADC_RES_H8L2
        ADC_InitStructure.ADC_Polity    = PolityLow;                //        PolityHigh,PolityLow
        ADC_InitStructure.ADC_Interrupt = DISABLE;                        //                ENABLE,DISABLE
        ADC_Inilize(&ADC_InitStructure);                                        //
        ADC_PowerControl(ENABLE);                                                        / ENABLE或DISABLE
ID:883242 发表于 2023-12-8 20:26 | 只看该作者
你这个明显是单片机内部集成ADC,你怎么老是想着外接?
