单片机nrf51822,在移植stm32lcd的例程中发现程序报错,报错显示如下
.\Peripheral\inc\FONT.h(446): error: #144: a value of type "char [4]" cannot be used to initialize an entity of type "unsigned char [2]"
"???",0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0xFC,0x1F,0x84,0x10,0x84,0x10,0x84,0x10,
.\Peripheral\inc\FONT.h(448): error: #144: a value of type "char [4]" cannot be used to initialize an entity of type "unsigned char [2]"
"???",0xF8,0x0F,0x08,0x08,0xF8,0x0F,0x08,0x08,0xF8,0x0F,0x80,0x00,0xFF,0x7F,0x00,0x00,
.\Peripheral\inc\FONT.h(450): error: #144: a value of type "char [4]" cannot be used to initialize an entity of type "unsigned char [2]"
"???",0x00,0x00,0xFE,0x3F,0x02,0x20,0xF2,0x27,0x02,0x20,0x02,0x20,0xFA,0x2F,0x22,0x21,
.\Peripheral\inc\FONT.h(452): error: #144: a value of type "char [4]" cannot be used to initialize an entity of type "unsigned char [2]"
"???",0x80,0x00,0x80,0x00,0x80,0x00,0xFC,0x1F,0x84,0x10,0x84,0x10,0x84,0x10,0xFC,0x1F,
.\Peripheral\inc\FONT.h(454): error: #144: a value of type "char [4]" cannot be used to initialize an entity of type "unsigned char [2]"
"???",0x00,0x00,0xFE,0x1F,0x00,0x08,0x00,0x04,0x00,0x02,0x80,0x01,0x80,0x00,0xFF,0x7F,
Peripheral\src\LCD.c: 0 warnings, 5 errors
报错位置代码是这样的
const typFNT_GB16 tfont16[]={
"中",0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0xFC,0x1F,0x84,0x10,0x84,0x10,0x84,0x10,
0x84,0x10,0x84,0x10,0xFC,0x1F,0x84,0x10,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,/*"中",0*/
"景",0xF8,0x0F,0x08,0x08,0xF8,0x0F,0x08,0x08,0xF8,0x0F,0x80,0x00,0xFF,0x7F,0x00,0x00,
0xF8,0x0F,0x08,0x08,0x08,0x08,0xF8,0x0F,0x80,0x00,0x84,0x10,0xA2,0x20,0x40,0x00,/*"景",1*/
"园",0x00,0x00,0xFE,0x3F,0x02,0x20,0xF2,0x27,0x02,0x20,0x02,0x20,0xFA,0x2F,0x22,0x21,
0x22,0x21,0x22,0x21,0x12,0x29,0x12,0x29,0x0A,0x2E,0x02,0x20,0xFE,0x3F,0x02,0x20,/*"园",2*/
"电",0x80,0x00,0x80,0x00,0x80,0x00,0xFC,0x1F,0x84,0x10,0x84,0x10,0x84,0x10,0xFC,0x1F,
0x84,0x10,0x84,0x10,0x84,0x10,0xFC,0x1F,0x84,0x50,0x80,0x40,0x80,0x40,0x00,0x7F,/*"电",3*/
"子",0x00,0x00,0xFE,0x1F,0x00,0x08,0x00,0x04,0x00,0x02,0x80,0x01,0x80,0x00,0xFF,0x7F,
0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0xA0,0x00,0x40,0x00,/*"子",4*/
最开始我以为是汉字导致的问题,将“中景园电子”几个字删除以后,程序不再报错,编译程序可以通过,然后我调用
LCD_ShowChinese(40,0,"中景园电子",RED,WHITE,16,0);
发现下载以后程序不能正常显示,但是调用LCD_ShowString(0,0 ,"A",GRED,BLUE ,16,0);可以正常显示字母。
百度查找很多地方,说是关于指针的问题,只是我没看懂,想问一下大佬们怎么改
以下是LCD_ShowChinese的具体内容,望大佬们指点
函数说明:显示汉字串
入口数据:x,y显示坐标
*s 要显示的汉字串
fc 字的颜色
bc 字的背景色
sizey 字号 可选 16 24 32
mode: 0非叠加模式 1叠加模式
返回值: 无
void LCD_ShowChinese(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
while(*s!=0)
if(sizey==12) LCD_ShowChinese12x12(x,y,s,fc,bc,sizey,mode);
else if(sizey==16) LCD_ShowChinese16x16(x,y,s,fc,bc,sizey,mode);
else if(sizey==24) LCD_ShowChinese24x24(x,y,s,fc,bc,sizey,mode);
else if(sizey==32) LCD_ShowChinese32x32(x,y,s,fc,bc,sizey,mode);
else return;
s+=2;
x+=sizey;
函数说明:显示单个12x12汉字
入口数据:x,y显示坐标
*s 要显示的汉字
fc 字的颜色
bc 字的背景色
sizey 字号
mode: 0非叠加模式 1叠加模式
返回值: 无
void LCD_ShowChinese12x12(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
u8 i,j,m=0;
u16 k;
u16 HZnum;//汉字数目
u16 TypefaceNum;//一个字符所占字节大小
u16 x0=x;
TypefaceNum=(sizey/8+((sizey%8)?1:0))*sizey;
HZnum=sizeof(tfont12)/sizeof(typFNT_GB12); //统计汉字数目
for(k=0;k<HZnum;k++)
if((tfont12[k].Index[0]==*(s))&&(tfont12[k].Index[1]==*(s+1)))
LCD_Address_Set(x,y,x+sizey-1,y+sizey-1);
for(i=0;i<TypefaceNum;i++)
for(j=0;j<8;j++)
if(!mode)//非叠加方式
if(tfont12[k].Msk[ i]&(0x01<<j))LCD_WR_DATA(fc);
else LCD_WR_DATA(bc);
m++;
if(m%sizey==0)
m=0;
break;
else//叠加方式
if(tfont12[k].Msk[ i]&(0x01<<j)) LCD_DrawPoint(x,y,fc);//画一个点
x++;
if((x-x0)==sizey)
x=x0;
y++;
break;
continue; //查找到对应点阵字库立即退出,防止多个汉字重复取模带来影响
函数说明:显示单个16x16汉字
入口数据:x,y显示坐标
*s 要显示的汉字
fc 字的颜色
bc 字的背景色
sizey 字号
mode: 0非叠加模式 1叠加模式
返回值: 无
void LCD_ShowChinese16x16(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
u8 i,j,m=0;
u16 k;
u16 HZnum;//汉字数目
u16 x0=x;
HZnum=sizeof(tfont16)/sizeof(typFNT_GB16); //统计汉字数目
if ((tfont16[k].Index[0]==*(s))&&(tfont16[k].Index[1]==*(s+1)))
for(j=0;j<8;j++)
if(!mode)//非叠加方式
if(tfont16[k].Msk[ i]&(0x01<<j))LCD_WR_DATA(fc);[ i]
m++;
if(m%sizey==0)
m=0;
break;
else//叠加方式
if(tfont16[k].Msk[ i]&(0x01<<j)) LCD_DrawPoint(x,y,fc);//画一个点[ i]
x++;
if((x-x0)==sizey)
x=x0;
y++;
break;
函数说明:显示单个24x24汉字
入口数据:x,y显示坐标
*s 要显示的汉字
fc 字的颜色
bc 字的背景色
sizey 字号
mode: 0非叠加模式 1叠加模式
返回值: 无
void LCD_ShowChinese24x24(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
u8 i,j,m=0;
u16 k;
u16 HZnum;//汉字数目
u16 x0=x;
HZnum=sizeof(tfont24)/sizeof(typFNT_GB24); //统计汉字数目
if ((tfont24[k].Index[0]==*(s))&&(tfont24[k].Index[1]==*(s+1)))
for(j=0;j<8;j++)
if(!mode)//非叠加方式
if(tfont24[k].Msk[ i]&(0x01<<j))LCD_WR_DATA(fc);
m++;
if(m%sizey==0)
m=0;
break;
else//叠加方式
if(tfont24[k].Msk[ i]&(0x01<<j)) LCD_DrawPoint(x,y,fc);//画一个点
x++;
if((x-x0)==sizey)
x=x0;
y++;
break;
函数说明:显示单个32x32汉字
入口数据:x,y显示坐标
*s 要显示的汉字
fc 字的颜色
bc 字的背景色
sizey 字号
mode: 0非叠加模式 1叠加模式
返回值: 无
void LCD_ShowChinese32x32(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
u8 i,j,m=0;
u16 k;
u16 HZnum;//汉字数目
u16 x0=x;
HZnum=sizeof(tfont32)/sizeof(typFNT_GB32); //统计汉字数目
if ((tfont32[k].Index[0]==*(s))&&(tfont32[k].Index[1]==*(s+1)))
for(j=0;j<8;j++)
if(!mode)//非叠加方式
if(tfont32[k].Msk[ i]&(0x01<<j))LCD_WR_DATA(fc);
m++;
if(m%sizey==0)
m=0;
break;
else//叠加方式
if(tfont32[k].Msk[ i]&(0x01<<j)) LCD_DrawPoint(x,y,fc);//画一个点
x++;
if((x-x0)==sizey)
x=x0;
y++;
break;
