查看: 749|回复: 1
STM8单片机想用按键来控制PWM输出频率,现在写好后发现按键无反应,求大佬
ID:792289 发表于 2024-2-18 13:58 | 显示全部楼层 |阅读模式
#include "STM8S.h"
unsigned char  a=20;
signed long int  pwm_duty;
void delay_ms (int ms) //延时函数
for (int i=0; i<=ms; i++)
for (int j=0; j<120; j++); // Nop = Fosc/4
void KEY(void)
GPIO_DeInit(GPIOC);//D口默认状态
GPIO_Init(GPIOC, GPIO_PIN_5, GPIO_MODE_IN_FL_NO_IT);
GPIO_Init(GPIOC, GPIO_PIN_4, GPIO_MODE_IN_FL_NO_IT);
        if (GPIO_ReadInputPin(GPIOC,GPIO_PIN_5) == 0)        //加1按键有效
            delay_ms(20);
            //延时去抖 一般10-20ms
                while (GPIO_ReadInputPin(GPIOC,GPIO_PIN_5) == 0);
                if (a < 41)
                  a = a+1;
        if (GPIO_ReadInputPin(GPIOC,GPIO_PIN_4) == 0)        //减1按键有效
            delay_ms(20);
                while (GPIO_ReadInputPin(GPIOC,GPIO_PIN_4) == 0)
                if (a > 1)
                 a =a-1;
void PWM(void)
pwm_duty=2000000/a/30;
CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);//  有些硬件会自动八分频 导致后面的计算出现错误
CLK_HSICmd(ENABLE);    //打开内部的时钟函数
TIM2_DeInit(); //TIM2回复默认
GPIO_Init(GPIOD,GPIO_PIN_4,GPIO_MODE_OUT_PP_LOW_FAST);//设置 Timer2 D4口输出PWM模式
TIM2_OC1Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE,pwm_duty/2,TIM2_OCPOLARITY_HIGH);
TIM2_TimeBaseInit(TIM2_PRESCALER_8,pwm_duty);//16M晶振
TIM2_OC2PreloadConfig(ENABLE);
TIM2_Cmd(ENABLE);//启用Timer2定时器
void main(void)
  PWM();
  KEY();
#ifdef USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
代码如上,百思不得其解!求大佬帮忙看看
ID:69038 发表于 2024-2-20 12:02 | 显示全部楼层
流程不对,你按对键后a值没有反馈到PWM控制中去,a值变了还要pwm_duty才行。
好比你要请客,饭菜在灶台,老是不端上桌子,客人能吃到热乎的吗?
