- #include <reg51.h>
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar time_data[7];
- uchar code write_add[7]={0x8c,0x8a,0x88,0x86,0x84,0x82,0x80}; //数据的地址
- uchar code read_add[7]={0x8d,0x8b,0x89,0x87,0x85,0x83,0x81};
- uchar code table1[]="C: 00|2000/00/00";
- uchar code table2[]="T: 00|00:00:00 0";
- uchar code table3[]=" "; //清屏内容
- uchar code table4[]=" Set Real Time ";
- uchar code table5[]=" Set Open Time ";
- uchar code table6[]=" Start Time: ";
- uchar code table7[]=" 00:00:00 ";
- uchar code table8[]=" End Time: ";
- uchar code table9[]="Date: 2000/00/00";
- uchar code table0[]="Time: 00:00:00 0";
- bit Adjust; //调节标志位,=1表示进入调节模式,=0是正常模式
- bit Auto_flg; //自动模式标志位,=1表示手动模式,=0是自动模式
- sbit rs=P2^7; //LCD1602
- // sbit rw=P1^1; //LCD1602
- sbit e=P2^6; //LCD1602
- sbit sck=P2^0; //时钟端口
- sbit io=P2^1; //时钟端口
- sbit rst=P2^2; //时钟端口
- sbit SELT =P1^6; //选择键
- sbit ENTER=P1^7; //确认键
- sbit UP =P3^0; //加键
- sbit DOWN =P3^1; //减键
- sbit MODE =P3^2; //切换按键接口
- sbit SWITCH=P3^3; //手动开关
- sbit AUTO_LED=P2^4; //自动模式灯接口
- sbit HAND_LED=P2^3; //手动灯接口
- sbit LAMP1=P3^4; //灯接口
- sbit LAMP2=P3^5; //灯接口
- sbit LAMP3=P3^6; //灯接口
- sbit LAMP4=P3^7; //灯接口
- sbit LIGHT1=P1^0; //光线检测端口
- sbit IN1=P1^1;
- sbit OUT1=P1^2;
- sbit DQ=P1^5; //温度数据口
- uchar Select_num; //选择按键按下次数
- uchar Enter_num; //确认按键按下次数
- uchar Switch_num; //手动开关按键按下次数
- float Year,Month,Day,Hour,Minute,Second; //时间设置值
- uchar Week;
- float Hour_H,Minute_H,Second_H; //设置开始时间
- float Hour_L,Minute_L,Second_L; //设置结束时间
- int Value1; //人数
- uchar IN1_flag=0;
- uchar OUT1_flag=0;
- uint Count; //T0定时器中断计数次数
- uchar Miao;
- int temperature; //全局变量 温度
- void read_rtc();
- /**************************************************LCD1602显示*******************************************************************/
- void delay1(uint z) //延时函数
- uint x,y;
- for(x=z;x>0;x--)
- for(y=10;y>0;y--);
- void init() //初始化函数
- uchar num;
- Year=17;
- Month=1;
- Day=1;
- Hour=15;
- Minute=30;
- Second=50;
- Week=1;
- Hour_H=22;
- Minute_H=0;
- Second_H=0;
- Hour_L=18;
- Minute_L=0;
- Second_L=0;
- e=0; // 时序表e初始为0
- write_com(0x38); //设置16*2显示,5*7点阵,8位数据接口
- write_com(0x0c); //设置光标
- write_com(0x06); //光标自动加1,光标输入方式
- write_com(0x01); //清屏
- write_com(0x80); //设置初始显示位置
- for(num=0;num<16;num++)
- write_date(table1[num]);
- delay1(5);
- write_com(0x80+0x40);
- write_date(table2[num]);
- delay1(5);
- void SetTime_dispaly(uchar add,uchar dat) //第一个:参数的地址,第二个:参数的内容
- uchar shi,ge;
- shi=dat/10; //把十位提取出来
- ge=dat%10; //把个位提取出来
- write_com(add); //要写的地址
- write_date(0x30+shi); //十位的内容 1602字符库
- write_date(0x30+ge); //个位的内容 1602字符库
- void Week_dispaly(uchar add,uchar dat) //第一个:参数的地址,第二个:参数的内容
- if (dat == 0)
- write_date(0x30+7); //十位的内容 1602字符库
- else
- write_date(0x30+dat); //十位的内容 1602字符库
- void Date_dispaly(uchar add,uchar dat) //第一个:参数的地址,第二个:参数的内容
- uchar shi,ge;
- shi=dat/16; //把十位提取出来
- ge=dat%16; //把个位提取出来
- write_com(add+3); //要写的地址
- void LCD_Clean(uchar i) //液晶屏清除显示
- uchar num;
- if(i==1)
- for(num=0;num<16;num++) //显示第一行内容
- write_date(table3[num]);
- delay1(1);
- if(i==2)
- for(num=0;num<16;num++) //显示第二行内容
- delay1(1);
- void LCD_Display_String(unsigned char line,unsigned char *string)
- { //液晶屏显示内容,把要显示的内容写到对应的位置
- unsigned char i;
- unsigned char address=0;
- if(line==1)
- address=0x80; //0X80是第1行的第1个位置 ,0x81第2位
- else if(line==2)
- address=0x80+0x40; //0X80+0x40是第2行的第1个位置 ,0X80+0x40+1是第2行第2位
- for(i=0;i<16;i++)
- write_com(address);
- write_date(string[i]);
- address++;
- /**********************************DS1302时钟***************************************/
- void Time_Display(void)
- read_rtc();
- Date_dispaly(0x80+0x40+9,time_data[6]); //显示秒
- Date_dispaly(0x80+0x40+6,time_data[5]); //显示分
- Date_dispaly(0x80+0x40+3,time_data[4]); //显示时
- Date_dispaly(0x80+11,time_data[3]); //显示日
- Date_dispaly(0x80+8,time_data[2]); //显示月
- Week_dispaly(0x80+0x40+15,time_data[1]-1); //显示周
- Date_dispaly(0x80+5,time_data[0]); //显示年
- // Year/10*16+Year%10
- Hour=time_data[4]/16*10+time_data[4]%16;;
- Minute=time_data[5]/16*10+time_data[5]%16;;
- Second=time_data[6]/16*10+time_data[6]%16;;
- void write_ds1302_byte(uchar dat)
- uchar i;
- for(i=0;i<8;i++)
- sck=0;
- io=dat&0x01; //准备数据,从最低位开始
- dat=dat>>1;
- sck=1;
- void write_ds1302(uchar add,uchar dat)
- rst=0;
- _nop_(); //CPU原地踏步
- sck=0;
- _nop_();
- rst=1;
- _nop_();
- write_ds1302_byte(add); //传地址
- write_ds1302_byte(dat); //传数据
- rst=0; //不受其他影响
- _nop_();
- io=1; //释放
- sck=1;
- void set_rtc() //设置时间
- uchar i,j;
- for(i=0;i<7;i++) //转换BCD码
- j=time_data[i]/10;
- time_data[i]=time_data[i]%10;
- time_data[i]=time_data[i]+j*16;
- write_ds1302(0x8e,0x00); //去除写保护
- for(i=0;i<7;i++)
- write_ds1302(write_add[i],time_data[i]);
- write_ds1302(0x8e,0x80); //加写保护
- void read_rtc()
- uchar i;
- for(i=0;i<7;i++)
- time_data[i]=read_ds1302(read_add[i]); //最终读出来的数 16进制
- Year=time_data[0]/16*10+time_data[0]%16;
- Month=time_data[2]/16*10+time_data[2]%16;
- Day=time_data[3]/16*10+time_data[3]%16;
- Week=time_data[1]/16*10+time_data[1]%16-1;
- if (Week == 0)
- Week = 7;
- /*************************************************按键****************************************************************/
- void Keyscan(void)
- if(SELT==0)
- delay1(2);
- if(SELT==0)
- while(!SELT);
- Select_num++; //选择键按下一次
- Adjust=1; //进入调节模式
- if(Select_num==1)
- LCD_Clean(1);
- LCD_Clean(2);
- LCD_Display_String(1,table4);
- LCD_Display_String(2,table5);
- write_com(0x80+0); //写 >>
- write_date(0x3e);
- write_com(0x80+1); //写 >>
- write_date(0x3e);
- Enter_num=0;
- if(Select_num==2)
- LCD_Clean(1);
- LCD_Clean(2);
- write_com(0x80+0x40+0); //写 >>
- write_date(0x3e);
- write_com(0x80+0x40+1); //写 >>
- write_date(0x3e);
- Enter_num=0;
- if(Select_num==3)
- LCD_Clean(1);
- LCD_Clean(2);
- LCD_Display_String(1,table1);
- LCD_Display_String(2,table2);
- Select_num=0;
- Enter_num=0;
- Adjust=0;
- write_com(0x0c); //光标不再闪烁
- Enter_num=0;
- if(ENTER==0)
- delay1(2);
- if(ENTER==0)
- while(!ENTER);
- Enter_num++;
- if(Select_num==1) //设置实时时间
- if(Enter_num==1)
- LCD_Clean(1);
- LCD_Clean(2);
- LCD_Display_String(1,table9);
- LCD_Display_String(2,table0);
- SetTime_dispaly(0x80+8,Year);
- SetTime_dispaly(0x80+11,Month);
- SetTime_dispaly(0x80+14,Day);
- SetTime_dispaly(0x80+0x40+6,Hour);
- SetTime_dispaly(0x80+0x40+9,Minute);
- SetTime_dispaly(0x80+0x40+12,Second);
- Week_dispaly(0x80+0x40+15,Week);
- write_com(0x80+8); //光标闪烁地址,停留在年的位置上
- write_com(0x0f); //光标闪烁
- if(Enter_num==2)
- write_com(0x80+11); //光标闪烁地址,停留在月的位置上
- if(Enter_num==3)
- write_com(0x80+14); //光标闪烁地址,停留在日的位置上
- if(Enter_num==4)
- write_com(0x80+0x40+6); //光标闪烁地址,停留在时的位置上
- if(Enter_num==5)
- write_com(0x80+0x40+9); //光标闪烁地址,停留在分的位置上
- if(Enter_num==6)
- write_com(0x80+0x40+12); //光标闪烁地址,停留在秒的位置上
- if(Enter_num==7)
- write_com(0x80+0x40+15); //光标闪烁地址,停留在星期的位置上
- if(Enter_num==8)
- Enter_num=0;
- LCD_Clean(1);
- LCD_Clean(2);
- time_data[0]=Year;///10*16+Year%10;
- time_data[1]=Week+1;///10*16+Week%10;
- time_data[2]=Month;///10*16+Month%10;
- time_data[3]=Day;///10*16+Day%10;
- time_data[4]=Hour;///10*16+Hour%10;
- time_data[5]=Minute;///10*16+Minute%10;
- time_data[6]=Second;///10*16+Second%10;
- set_rtc(); //设置时间
- Select_num=0;
- Adjust=0;
- if(Select_num==2) //设置开关锁时间
- if(Enter_num==1)
- LCD_Clean(1);
- LCD_Clean(2);
- LCD_Display_String(1,table6);
- LCD_Display_String(2,table7);
- SetTime_dispaly(0x80+0x40+4,Hour_L);
- SetTime_dispaly(0x80+0x40+7,Minute_L);
- SetTime_dispaly(0x80+0x40+10,Second_L);
- write_com(0x80+0x40+4); //光标闪烁地址,停留在时的位置上
- if(Enter_num==2)
- write_com(0x80+0x40+7); //光标闪烁地址,停留在分的位置上
- if(Enter_num==3)
- write_com(0x80+0x40+10); //光标闪烁地址,停留在秒的位置上
- if(Enter_num==4)
- LCD_Clean(1);
- LCD_Clean(2);
- LCD_Display_String(1,table8);
- SetTime_dispaly(0x80+0x40+4,Hour_H);
- SetTime_dispaly(0x80+0x40+7,Minute_H);
- SetTime_dispaly(0x80+0x40+10,Second_H);
- if(Enter_num==5)
- if(Enter_num==6)
- if(Enter_num==7)
- Enter_num=0;
- LCD_Clean(1);
- LCD_Clean(2);
- Select_num=0;
- Adjust=0;
- if(MODE==0) //切换按键按下
- delay1(2); //消抖
- if(MODE==0)
- while(!MODE); //按键释放
- Auto_flg=~Auto_flg; //模式切换
- if(Auto_flg==0) //自动模式
- AUTO_LED=0; //自动灯亮
- HAND_LED=1;
- if(Auto_flg==1) //手动模式
- AUTO_LED=1;
- HAND_LED=0; //手动灯亮
- LAMP1=1; //关灯
- LAMP2=1;
- LAMP3=1;
- LAMP4=1;
- if(SWITCH==0) //灯开关按键按下
- delay1(2); //消抖
- if(SWITCH==0)
- while(!SWITCH); //按键释放
- Switch_num++; //按下次数增加
- if(Switch_num==1) //按下一次,开一盏灯
- LAMP1=0;
- LAMP2=1;
- LAMP3=1;
- LAMP4=1;
- if(Switch_num==2) //按下二次,开二盏灯
- LAMP1=0;
- LAMP2=0;
- LAMP3=1;
- LAMP4=1;
- if(Switch_num==3) //按下3次,开3盏灯
- LAMP1=0;
- LAMP2=0;
- LAMP3=0;
- LAMP4=1;
- if(Switch_num==4) //按下4次,开4盏灯
- LAMP1=0;
- LAMP2=0;
- LAMP3=0;
- LAMP4=0;
- if(Switch_num==5) //按下5次,开0盏灯
- LAMP1=1;
- LAMP2=1;
- LAMP3=1;
- LAMP4=1;
- Switch_num=0; //次数清除
- void Open(void)
- float Now;
- float Set_L,Set_H;
- Now=Hour+Minute/60+Second/3600; //把实时时间化成小时为单位
- Set_L=Hour_L+Minute_L/60+Second_L/3600; //把设置下限时间化成小时为单位
- Set_H=Hour_H+Minute_H/60+Second_H/3600; //把设置上限时间化成小时为单位
- if((Now>=Set_L)&(Now<=Set_H)) //实时时间在上下限时间范围内
- if(LIGHT1==0) //光线不足
- if(Value1==0)
- LAMP1=1; //全灭
- LAMP2=1;
- LAMP3=1;
- LAMP4=1;
- if((Value1>0)&(Value1<10))
- LAMP1=0; //亮一个灯
- LAMP2=1;
- LAMP3=1;
- LAMP4=1;
- if((Value1>=10)&(Value1<20))
- LAMP1=0; //亮二个灯
- LAMP2=0;
- LAMP3=1;
- LAMP4=1;
- if((Value1>=20)&(Value1<30))
- LAMP1=0; //亮三个灯
- LAMP2=0;
- LAMP3=0;
- LAMP4=1;
- if(Value1>=30)
- LAMP1=0; //亮四个灯
- LAMP2=0;
- LAMP3=0;
- LAMP4=0;
- if(LIGHT1==1) //光线强烈
- LAMP1=1; //全灭
- LAMP2=1;
- LAMP3=1;
- LAMP4=1;
- if((Now<Set_L)|(Now>Set_H)) //实时时间不在范围内
- LAMP1=1; //全灭
- LAMP2=1;
- LAMP3=1;
- LAMP4=1;
- void Count_Value(void)
- SetTime_dispaly(0x80+3,Value1);
- if(IN1==0)
- delay1(1);
- if(IN1==0)
- while(!IN1);
- if(OUT1_flag==0)
- IN1_flag=1;
- TR0=1; //开启定时器 防止误触发
- if(OUT1_flag==1)
- Value1++; //人数增加
- if(Value1>=99) //如果人数计数到99,变为最大99
- Value1=99;
- OUT1_flag=0; //清零
- IN1_flag=0;
- TR0=0; //关闭定时器
- Count=0;
- Miao=0;
- if(OUT1==0)
- delay1(1);
- if(OUT1==0)
- while(!OUT1);
- if(IN1_flag==0)
- OUT1_flag=1;
- if(IN1_flag==1)
- Value1--; //人数减少
- if(Value1<0) //如果人数计数小于0,变为最小0
- Value1=0;
- IN1_flag=0; //清零
- OUT1_flag=0;
- TR0=0; //关闭定时器
- Count=0;
- Miao=0;
- /****************************************温度************************************************************/
- void delay(uint y) //DS18B20延时函数(仿真用)
- while(y--);
- /*void delay(uint z) //DS18B20延时函数(实物用)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=1;y>0;y--);
- void write_byte(uint dat) //写一个字节
- uchar i;
- for(i=0;i<8;i++) //循环八次 共有八位
- DQ=0; //写零
- DQ=dat&0x01; //向总线写位数据,从最低位写起
- delay(4);
- DQ=1; //写一
- dat>>=1; //下次写作准备,移位数据
- delay(4);
- uchar read_byte(void) //读一个字节,返回值
- uchar i;
- uint value;
- DQ=0;
- value>>=1;
- DQ=1; //释放总线
- if(DQ)
- value|=0x80; //DQ=1,value取1
- delay(4);
- return value;
- void ds18b20_init() //初始化函数
- uint n;
- DQ=1;
- delay(8);
- DQ=0;
- delay(80); //低电平480——960us
- DQ=1; //总线释放
- delay(8); //等待50——100us
- n=DQ; //读取复位状态
- delay(4);
- int readtemperature() //读整数部分
- int a,b; //高八位,低八位
- ds18b20_init();
- write_byte(0xcc); //跳过rom匹配,跳过读序列号的操作,可节省操作时间
- write_byte(0x44); //启动温度检测
- delay(300); //测温度
- ds18b20_init(); //开始操作前需要复位
- write_byte(0xbe); //写读寄存器中温度值的命令
- a=read_byte(); //low 低位开始读取
- b=read_byte(); //high 高位开始读取
- b<<=8; //把高位左移八位
- b=b|a; //高八位与第八位进行或运算,得到总和
- if(b>=0) //如果温度大于等于0
- b=b*0.0625; //直接乘以0.0625
- write_com(0x80+0x40+2); //在LCD1602对应的位置不写内容
- write_date(0x20);
- else //温度小于0
- b=~b+1; //取反码再加一
- b=b*0.0625; //再运算
- write_com(0x80+0x40+2); //在LCD1602对应的位置写一个负号
- write_date(0x2d);
- return b; //返回b,此时以表示温度
- void temperature_dispaly(char add,char dat) //温度显示函数:第一个:参数的地址,第二个:参数的内容
- uchar shi,ge;
- shi=dat/10; //把温度的十位提取出来
- ge=dat%10; //把温度的个位提取出来
- write_com(0x80+0x40+add); //要写的地址
- /*****************************************定时器初始化和主函数***********************************************************/
- void T0_init(void)
- TMOD=0x11; //设置定时器0为工作方式1
- TH0=(65536-50000)/256; //50MS定时
- TL0=(65536-50000)%256;
- EA=1; //开定时器T0的中断 总中断
- ET0=1; //允许T0中断
- // TR0=1; //开启定时器
- void main()
- AUTO_LED=0; //默认自动模式
- temperature=readtemperature();
- init(); //液晶初始化
- T0_init(); //定时器初始化
- write_ds1302(0x80,0x00);
- delay1(8000);
- while(1)
- if(Adjust==0) //非调节模式下显示时间人数和温度
- temperature=readtemperature(); //读取温度
- temperature_dispaly(3,temperature); //显示温度
- Time_Display(); //显示时间
- Open(); //动作判断,根据光线和人数
- Count_Value(); //计算人数
- Keyscan(); //扫描键盘
- void Timer0() interrupt 1 //定时器T0中断函数
- TH1=0x3c; //赋初值=50ms
- TL1=0xb0; //TH0=3C,TL0=B0
- Count++; //每中断一次,Count加一,计数20次,表示1s的时间到
- if(Count>=20) //1s到
- Count=0;
- Miao++;
- if(Miao>=3) //3秒内无触发另一个,全部清零
- Miao=0;
- OUT1_flag=0; //清零
- IN1_flag=0;
- TR1=0; //关闭定时器
原理图: 无
仿真:
硬件.rar
(351.18 KB, 下载次数: 32)
