查看: 566|回复: 0
可燃气体检测传感器的程序
ID:1120726 发表于 2024-5-15 01:14 | 显示全部楼层 |阅读模式
基于stm32,使用SGP30 CO2和TVOC传感器的初始化和数据读取程序。SGP30是一款用于测量二氧化碳(CO2)和总挥发性有机化合物(TVOC)浓度的传感器。程序中定义了相关的IIC通信函数,如起始信号、停止信号、发送和接收字节等。此外,程序还包含了一个主函数,用于初始化SGP30传感器,并读取CO2和TVOC的数据。
#include "sgp30_CO2_TVOC.h"
#include "user_peripheral.h"
#include "delay.h"
#include "usart.h"
#if SGP30_CO2_TVOC_Pre
void SGP30_GPIO_Init(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  RCC_APB2PeriphClockCmd(SGP30_SCL_GPIO_CLK | SGP30_SDA_GPIO_SDA, ENABLE);
  GPIO_InitStructure.GPIO_Pin = SGP30_SCL_GPIO_PIN;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(SGP30_SCL_GPIO_PORT, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = SGP30_SDA_GPIO_PIN;
  GPIO_Init(SGP30_SDA_GPIO_PORT, &GPIO_InitStructure);
void SGP30_SDA_OUT(void)
void SGP30_SDA_IN(void)
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
void SGP30_IIC_Start(void)
  SGP30_SDA_OUT();
  SGP30_SDA = 1;
  SGP30_SCL = 1;
  delay_us(20);
  SGP30_SDA = 0;
  delay_us(20);
  SGP30_SCL = 0;
void SGP30_IIC_Stop(void)
  SGP30_SDA_OUT();
  SGP30_SCL = 0;
  SGP30_SDA = 0;
  delay_us(20);
  SGP30_SCL = 1;
  SGP30_SDA = 1;
  delay_us(20);
u8 SGP30_IIC_Wait_Ack(void)
  u8 ucErrTime = 0;
  SGP30_SDA_IN();
  SGP30_SDA = 1;
  delay_us(10);
  SGP30_SCL = 1;
  delay_us(10);
  while(SGP30_SDA_READ())
    ucErrTime++;
    if(ucErrTime > 250)
      SGP30_IIC_Stop();
      return 1;
  SGP30_SCL = 0;
  return 0;
void SGP30_IIC_Ack(void)
  SGP30_SCL = 0;
  SGP30_SDA_OUT();
  SGP30_SDA = 0;
  delay_us(20);
  SGP30_SCL = 1;
  delay_us(20);
  SGP30_SCL = 0;
void SGP30_IIC_NAck(void)
  SGP30_SCL = 0;
  SGP30_SDA_OUT();
  SGP30_SDA = 1;
  delay_us(20);
  SGP30_SCL = 1;
  delay_us(20);
  SGP30_SCL = 0;
void SGP30_IIC_Send_Byte(u8 txd)
  u8 t;
  SGP30_SDA_OUT();
  SGP30_SCL = 0;
  for(t = 0; t < 8; t++)
    if((txd & 0x80) >> 7)
      SGP30_SDA = 1;
      SGP30_SDA = 0;
    txd <<= 1;
    delay_us(20);
    SGP30_SCL = 1;
    delay_us(20);
    SGP30_SCL = 0;
    delay_us(20);
  delay_us(20);
u16 SGP30_IIC_Read_Byte(u8 ack)
  u8 i;
  u16 receive = 0;
  SGP30_SDA_IN();
  for(i = 0; i < 8; i++ )
    SGP30_SCL = 0;
    delay_us(20);
    SGP30_SCL = 1;
    receive <<= 1;
    if(SGP30_SDA_READ())
      receive++;
    delay_us(20);
  if (!ack)
    SGP30_IIC_NAck();
    SGP30_IIC_Ack();
  return receive;
void SGP30_Init(void)
  SGP30_GPIO_Init();
  SGP30_Write(0x20, 0x03);
void SGP30_Write(u8 a, u8 b)
  SGP30_IIC_Start();
  SGP30_IIC_Send_Byte(SGP30_write);
  SGP30_IIC_Wait_Ack();
  SGP30_IIC_Send_Byte(a);
  SGP30_IIC_Send_Byte(b);
  SGP30_IIC_Stop();
  delay_ms(100);
u32 SGP30_Read(void)
  u32 dat;
  u8 crc;
  SGP30_IIC_Start();
  SGP30_IIC_Send_Byte(SGP30_read);
  dat = SGP30_IIC_Read_Byte(1);
  dat <<= 8;
  dat += SGP30_IIC_Read_Byte(1);
  crc = SGP30_IIC_Read_Byte(1);
  crc = crc;
  dat <<= 8;
  dat <<= 8;
  dat += SGP30_IIC_Read_Byte(0);
  SGP30_IIC_Stop();
  return(dat);
u32 sgp30_dat;
u32 CO2Data,TVOCData;
void SGP30_Init_ALL(void)
  SGP30_Init();
        delay_ms(100);
        SGP30_Write(0x20,0x08);
        sgp30_dat = SGP30_Read();
        CO2Data = (sgp30_dat & 0xffff0000) >> 16;
        TVOCData = sgp30_dat & 0x0000ffff;
        while(CO2Data == 400 && TVOCData == 0)
                printf("?y?ú?ì2a?D...\r\n");
                OLED_ShowString(0,4,(u8*)"co2 init wait...",16);
                delay_ms(249);
                delay_ms(251);
        OLED_ShowString(0,4,(u8*)"co2 init ok...",16);
        delay_ms(500);
        OLED_Clear();
        printf("......OK.....\r\n");
#endif
这是一个什么程序
