查看: 812|回复: 0
stm32f407单片机通过并口驱动ad7606源程序
ID:444278 发表于 2024-5-31 08:19 | 显示全部楼层 |阅读模式
希望能帮到可以用到的小伙伴
  1. #include "adc7606.h"
  2. //AD_OS0 PG4
  3. #define OS0_1()                GPIOG->BSRRL = GPIO_Pin_4
  4. #define OS0_0()                GPIOG->BSRRH = GPIO_Pin_4
  5. //AD_OS1 PG3
  6. #define OS1_1()                GPIOG->BSRRL = GPIO_Pin_3
  7. #define OS1_0()                GPIOG->BSRRH = GPIO_Pin_3
  8. //AD_OS2 PG2
  9. #define OS2_1()                GPIOG->BSRRL = GPIO_Pin_2
  10. #define OS2_0()                GPIOG->BSRRH = GPIO_Pin_2
  11. //PD11 CNVTA
  12. //PB15 CNVTB TIM_CH3N/TIM8_CH3N/TIM12_CH2
  13. #define CONVSTA_1()        GPIOD->BSRRL = GPIO_Pin_11
  14. #define CONVSTA_0()        GPIOD->BSRRH = GPIO_Pin_11
  15. #define CONVSTB_1()        GPIOB->BSRRL = GPIO_Pin_15
  16. #define CONVSTB_0()        GPIOB->BSRRH = GPIO_Pin_15
  17. //PD12 RANGE
  18. #define RANGE_1()        GPIOD->BSRRL = GPIO_Pin_12
  19. #define RANGE_0()        GPIOD->BSRRH = GPIO_Pin_12
  20. //AD_RESET PB14
  21. #define RESET_1()        GPIOB->BSRRL = GPIO_Pin_14
  22. #define RESET_0()        GPIOB->BSRRH = GPIO_Pin_14
  23. //AD7606 FSMC总线地址,只能读,无需写
  24. #define AD7606_RESULT()        *(__IO uint16_t *)0x6C400000
  25. AD7606_VAR_T g_tAD7606;                //定义1个全局变量,保存一些参数
  26. static void AD7606_CtrlLinesConfig(void);
  27. static void AD7606_FSMCConfig(void);
  28. /*------------------------------------------------------------------------------------------------------------------------------
  29. *****-----功能介绍:AD7606初始化
  30. *****-----函数  名:AD7606_Init()
  31. *****-----入口参数:无
  32. *****-----返回  值:无
  33. *****-----备    注:
  34. ------------------------------------------------------------------------------------------------------------------------------*/
  35. void AD7606_Init(void)
  36. {
  37.         AD7606_CtrlLinesConfig();
  38.         AD7606_FSMCConfig();
  39.         AD7606_SetOS(AD_OS_NO);                //无过采样
  40.         AD7606_SetInputRange(0);        //0表示输入量程为正负5V, 1表示正负10V
  41.         AD7606_Reset();
  42.         CONVSTB_1();        //启动转换的GPIO平时设置为高
  43. }
  44. /*------------------------------------------------------------------------------------------------------------------------------
  45. *****-----功能介绍:配置AD7606控制口线,FSMC管脚设置为复用功能
  46. *****-----函数  名:AD7606_CtrlLinesConfig()
  47. *****-----入口参数:无
  48. *****-----返回  值:无
  49. *****-----备    注:
  50. ------------------------------------------------------------------------------------------------------------------------------*/
  51. static void AD7606_CtrlLinesConfig(void)
  52. {
  53.         GPIO_InitTypeDef GPIO_InitStructure;
  54.         RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC, ENABLE);/* 使能FSMC时钟 */
  55.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD | RCC_AHB1Periph_GPIOE | RCC_AHB1Periph_GPIOG, ENABLE);/* 使能 GPIO时钟 */
  56.         /* 设置 PD.00(D2), PD.01(D3), PD.04(NOE), PD.05(NWE), PD.08(D13), PD.09(D14),
  57.          PD.10(D15), PD.14(D0), PD.15(D1) 为复用推挽输出 */
  58.         GPIO_PinAFConfig(GPIOD, GPIO_PinSource0, GPIO_AF_FSMC);
  59.         GPIO_PinAFConfig(GPIOD, GPIO_PinSource1, GPIO_AF_FSMC);
  60.         GPIO_PinAFConfig(GPIOD, GPIO_PinSource4, GPIO_AF_FSMC);
  61.         GPIO_PinAFConfig(GPIOD, GPIO_PinSource5, GPIO_AF_FSMC);
  62.         GPIO_PinAFConfig(GPIOD, GPIO_PinSource8, GPIO_AF_FSMC);
  63.         GPIO_PinAFConfig(GPIOD, GPIO_PinSource9, GPIO_AF_FSMC);
  64.         GPIO_PinAFConfig(GPIOD, GPIO_PinSource10, GPIO_AF_FSMC);
  65.         GPIO_PinAFConfig(GPIOD, GPIO_PinSource14, GPIO_AF_FSMC);
  66.         GPIO_PinAFConfig(GPIOD, GPIO_PinSource15, GPIO_AF_FSMC);
  67.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 |
  68.        GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_14 |
  69.        GPIO_Pin_15;
  70.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  71.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  72.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  73.         GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
  74.         GPIO_Init(GPIOD, &GPIO_InitStructure);
  75.         /*
  76.                 PE.07(D4), PE.08(D5), PE.09(D6), PE.10(D7), PE.11(D8), PE.12(D9), PE.13(D10),
  77.                  PE.14(D11), PE.15(D12)
  78.         */
  79.         GPIO_PinAFConfig(GPIOE, GPIO_PinSource7 , GPIO_AF_FSMC);
  80.         GPIO_PinAFConfig(GPIOE, GPIO_PinSource8 , GPIO_AF_FSMC);
  81.         GPIO_PinAFConfig(GPIOE, GPIO_PinSource9 , GPIO_AF_FSMC);
  82.         GPIO_PinAFConfig(GPIOE, GPIO_PinSource10 , GPIO_AF_FSMC);
  83.         GPIO_PinAFConfig(GPIOE, GPIO_PinSource11 , GPIO_AF_FSMC);
  84.         GPIO_PinAFConfig(GPIOE, GPIO_PinSource12 , GPIO_AF_FSMC);
  85.         GPIO_PinAFConfig(GPIOE, GPIO_PinSource13 , GPIO_AF_FSMC);
  86.         GPIO_PinAFConfig(GPIOE, GPIO_PinSource14 , GPIO_AF_FSMC);
  87.         GPIO_PinAFConfig(GPIOE, GPIO_PinSource15 , GPIO_AF_FSMC);
  88.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 |
  89.        GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 |
  90.        GPIO_Pin_15;
  91.         GPIO_Init(GPIOE, &GPIO_InitStructure);
  92.         /* 设置 PG12  为复用推挽输出 */
  93.         GPIO_PinAFConfig(GPIOG, GPIO_PinSource12, GPIO_AF_FSMC);
  94.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  95.         GPIO_Init(GPIOG, &GPIO_InitStructure);
  96.         /*        配置几个控制用的GPIO
  97.                 PG4/DCMI_D0/AD7606_OS0                                        ---> AD7606_OS0                        OS2:OS0 选择数字滤波参数
  98.                 PG3/DCMI_D1/AD7606_OS1                 ---> AD7606_OS1
  99.                 PG2/DCMI_D2/AD7606_OS2                 ---> AD7606_OS2
  100.                 PD11/DCMI_D3/AD7606_CONVSTA     ---> AD7606_CONVSTA        启动ADC转换CH1-CH4
  101.                 PB15/DCMI_D3/AD7606_CONVSTB     ---> AD7606_CONVSTB        启动ADC转换CH5-CH8
  102.                 PD12/DCMI_D4/AD7606_RAGE        ---> AD7606_RAGE                输入模拟电压量程,正负5V或正负10V
  103.                 PB14/DCMI_D5/AD7606_RESET       ---> AD7606_RESET                复位
  104.                 PB13/DCMI_D6/AD7606_BUSY                                ---> AD7606_BUSY    转换结束的信号
  105.         */
  106.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);/* 使能 GPIO时钟 */
  107.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
  108.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  109.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  110.         GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
  111.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_3 | GPIO_Pin_2;
  112.         GPIO_Init(GPIOG, &GPIO_InitStructure);
  113.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12;
  114.         GPIO_Init(GPIOD, &GPIO_InitStructure);
  115.
  116.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
  117.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  118. }
  119. /*------------------------------------------------------------------------------------------------------------------------------
  120. *****-----功能介绍:配置FSMC并口访问时序
  121. *****-----函数  名:AD7606_FSMCConfig()
  122. *****-----入口参数:无
  123. *****-----返回  值:无
  124. *****-----备    注:
  125. ------------------------------------------------------------------------------------------------------------------------------*/
  126. static void AD7606_FSMCConfig(void)
  127. {
  128.         FSMC_NORSRAMInitTypeDef  init;
  129.         FSMC_NORSRAMTimingInitTypeDef  timing;
  130.         /*
  131.                 AD7606规格书要求(3.3V时):RD读信号低电平脉冲宽度最短21ns,高电平脉冲最短宽度15ns。
  132.                 按照如下配置 读数均正常。为了和同BANK的LCD配置相同,选择3-0-6-1-0-0
  133.                 3-0-5-1-0-0  : RD高持续75ns, 低电平持续50ns.  1us以内可读取8路样本数据到内存。
  134.                 1-0-1-1-0-0  : RD高75ns,低电平执行12ns左右,下降沿差不多也12ns.  数据读取正确。
  135.         */
  136.         /* FSMC_Bank1_NORSRAM4 configuration */
  137.         timing.FSMC_AddressSetupTime = 3;
  138.         timing.FSMC_AddressHoldTime = 0;
  139.         timing.FSMC_DataSetupTime = 6;
  140.         timing.FSMC_BusTurnAroundDuration = 1;
  141.         timing.FSMC_CLKDivision = 0;
  142.         timing.FSMC_DataLatency = 0;
  143.         timing.FSMC_AccessMode = FSMC_AccessMode_A;
  144.         /*
  145.          LCD configured as follow:
  146.             - Data/Address MUX = Disable
  147.             - Memory Type = SRAM
  148.             - Data Width = 16bit
  149.             - Write Operation = Enable
  150.             - Extended Mode = Enable
  151.             - Asynchronous Wait = Disable
  152.         */
  153.         init.FSMC_Bank = FSMC_Bank1_NORSRAM4;
  154.         init.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
  155.         init.FSMC_MemoryType = FSMC_MemoryType_SRAM;
  156.         init.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
  157.         init.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
  158.         init.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;
  159.         init.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
  160.         init.FSMC_WrapMode = FSMC_WrapMode_Disable;
  161.         init.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
  162.         init.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
  163.         init.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
  164.         init.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
  165.         init.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
  166.         init.FSMC_ReadWriteTimingStruct = &timing;
  167.         init.FSMC_WriteTimingStruct = &timing;
  168.         FSMC_NORSRAMInit(&init);
  169.         /* - BANK 1 (of NOR/SRAM Bank 1~4) is enabled */
  170.         FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM4, ENABLE);
  171. }
  172. /*------------------------------------------------------------------------------------------------------------------------------
  173. *****-----功能介绍:配置AD7606数字滤波器,也就设置过采样倍率。
  174. *****-----函数  名:AD7606_SetOS()
  175. *****-----入口参数: _ucOS : 过采样倍率
  176. *****-----返回  值:无
  177. *****-----备    注:
  178.        通过设置 AD7606_OS0、OS1、OS2口线的电平组合状态决定过采样倍率。
  179.        启动AD转换之后,AD7606内部自动实现剩余样本的采集,然后求平均值输出。
  180.        过采样倍率越高,转换时间越长。
  181.        无过采样时,AD转换时间 4us;
  182.        2倍过采样时 = 8.7us;
  183.        4倍过采样时 = 16us
  184.        64倍过采样时 = 286us
  185. ------------------------------------------------------------------------------------------------------------------------------*/
  186. void AD7606_SetOS(AD7606_OS_E _ucOS)
  187. {
  188.         g_tAD7606.ucOS = _ucOS;
  189.         switch (_ucOS)
  190.         {
  191.                 case AD_OS_X2:
  192.                         OS2_0();
  193.                         OS1_0();
  194.                         OS0_1();
  195.                         break;
  196.                 case AD_OS_X4:
  197.                         OS2_0();
  198.                         OS1_1();
  199.                         OS0_0();
  200.                         break;
  201.                 case AD_OS_X8:
  202.                         OS2_0();
  203.                         OS1_1();
  204.                         OS0_1();
  205.                         break;
  206.                 case AD_OS_X16:
  207.                         OS2_1();
  208.                         OS1_0();
  209.                         OS0_0();
  210.                         break;
  211.                 case AD_OS_X32:
  212.                         OS2_1();
  213.                         OS1_0();
  214.                         OS0_1();
  215.                         break;
  216.                 case AD_OS_X64:
  217.                         OS2_1();
  218.                         OS1_1();
  219.                         OS0_0();
  220.                         break;
  221.                 case AD_OS_NO:
  222.                 default:
  223.                         g_tAD7606.ucOS = AD_OS_NO;
  224.                         OS2_0();
  225.                         OS1_0();
  226.                         OS0_0();
  227.                         break;
  228.         }
  229. }
  230. /*------------------------------------------------------------------------------------------------------------------------------
  231. *****-----功能介绍:配置AD7606模拟信号输入量程
  232. *****-----函数  名:AD7606_SetInputRange()
  233. *****-----入口参数:ucRange : 0 表示正负5V   1表示正负10V
  234. *****-----返回  值:无
  235. *****-----备    注:
  236. ------------------------------------------------------------------------------------------------------------------------------*/
  237. void AD7606_SetInputRange(uint8_t _ucRange)
  238. {
  239.         if (_ucRange == 0)
  240.         {
  241.                 g_tAD7606.ucRange = 0;
  242.                 RANGE_0();        /* 设置为正负5V */
  243.         }
  244.         else
  245.         {
  246.                 g_tAD7606.ucRange = 1;
  247.                 RANGE_1();        /* 设置为正负10V */
  248.         }
  249. }
  250. /*------------------------------------------------------------------------------------------------------------------------------
  251. *****-----功能介绍:硬件复位AD7606。复位之后恢复到正常工作状态
  252. *****-----函数  名:AD7606_Reset()
  253. *****-----入口参数:无
  254. *****-----返回  值:无
  255. *****-----备    注:
  256. ------------------------------------------------------------------------------------------------------------------------------*/
  257. void AD7606_Reset(void)
  258. {
  259.         RESET_0();        /* 退出复位状态 */
  260.         RESET_1();        /* 进入复位状态 */
  261.         RESET_1();        /* 仅用于延迟。 RESET复位高电平脉冲宽度最小50ns。 */
  262.         RESET_1();
  263.         RESET_1();
  264.         RESET_0();        /* 退出复位状态 */
  265. }
  266. /*------------------------------------------------------------------------------------------------------------------------------
  267. *****-----功能介绍:启动1次ADC转换
  268. *****-----函数  名:AD7606_StartConvst()
  269. *****-----入口参数:无
  270. *****-----返回  值:无
  271. *****-----备    注:
  272. ------------------------------------------------------------------------------------------------------------------------------*/
  273. void AD7606_StartConvst(void)
  274. {
  275.         /* page 7:  CONVST 高电平脉冲宽度和低电平脉冲宽度最短 25ns */
  276.         /* CONVST平时为高 */
  277.         CONVSTB_0();
  278.         CONVSTB_0();
  279.         CONVSTB_0();
  280.         CONVSTB_1();
  281. }
  282. /*------------------------------------------------------------------------------------------------------------------------------
  283. *****-----功能介绍:读取8路采样结果。结果存储在全局变量 g_tAD7606
  284. *****-----函数  名:AD7606_ReadNowAdc()
  285. *****-----入口参数:无
  286. *****-----返回  值:无
  287. *****-----备    注:
  288. ------------------------------------------------------------------------------------------------------------------------------*/
  289. void AD7606_ReadNowAdc(void)
  290. {
  291.         g_tAD7606.sNowAdc[0] = AD7606_RESULT();        /* 读第1路样本 */
  292.         g_tAD7606.sNowAdc[1] = AD7606_RESULT();        /* 读第2路样本 */
  293.         g_tAD7606.sNowAdc[2] = AD7606_RESULT();        /* 读第3路样本 */
  294.         g_tAD7606.sNowAdc[3] = AD7606_RESULT();        /* 读第4路样本 */
  295.         g_tAD7606.sNowAdc[4] = AD7606_RESULT();        /* 读第5路样本 */
  296.         g_tAD7606.sNowAdc[5] = AD7606_RESULT();        /* 读第6路样本 */
  297.         g_tAD7606.sNowAdc[6] = AD7606_RESULT();        /* 读第7路样本 */
  298.         g_tAD7606.sNowAdc[7] = AD7606_RESULT();        /* 读第8路样本 */
  299. }
原理图: 无
仿真: 无
代码: stm32f407+ad7606+8080并口+usart打印.7z (295.75 KB, 下载次数: 4)
