/* Includes--------------------------------------------------------------*/
//#include "sysconfig.h"
#include "stm32f10x.h"
//#include "bsp_SIIC.h"
#include "bsp_RX8025.h"
Private define-----------------------------------------------------------------------------*/
// 设备读写地址
#define RX8025_ADDR_READ 0x65
#define RX8025_ADDR_WRITE 0x64
// 设备寄存器地址
#define RX8025_ADDR_SECONDS 0x00
#define RX8025_ADDR_WEEK 0x30
#define RX8025_ADDR_DATES 0x40
#define RX8025_ADDR_MONTH 0x50
#define RX8025_ADDR_MINUTES 0x80
#define RX8025_ADDR_CONTROL1 0xE0
#define RX8025_ADDR_CONTROL2 0xF0
// 设备操作模式
#define RX8025_WRITE_MODE 0xF0
#define RX8025_READ_MODE 0xF0
#define RX8025_SIMP_READ_MODE 0x04
#define u8BAND(addr, u8num) ((addr & 0xF0000000)+0x2000000+((addr &0xFFFFF)<<5)+(u8num<<2))
#define MEM_ADDR(addr) *((volatile unsigned long *)(addr))
#define u8_ADDR(addr, u8num) MEM_ADDR(u8BAND(addr, u8num))
//IO口地址映射
#define GPIOA_ODR_Addr (GPIOA_BASE+12) //0x4001080C
#define GPIOB_ODR_Addr (GPIOB_BASE+12) //0x40010C0C
#define GPIOC_ODR_Addr (GPIOC_BASE+12) //0x4001100C
#define GPIOD_ODR_Addr (GPIOD_BASE+12) //0x4001140C
#define GPIOE_ODR_Addr (GPIOE_BASE+12) //0x4001180C
#define GPIOF_ODR_Addr (GPIOF_BASE+12) //0x40011A0C
#define GPIOG_ODR_Addr (GPIOG_BASE+12) //0x40011E0C
#define GPIOA_IDR_Addr (GPIOA_BASE+8) //0x40010808
#define GPIOB_IDR_Addr (GPIOB_BASE+8) //0x40010C08
#define GPIOC_IDR_Addr (GPIOC_BASE+8) //0x40011008
#define GPIOD_IDR_Addr (GPIOD_BASE+8) //0x40011408
#define GPIOE_IDR_Addr (GPIOE_BASE+8) //0x40011808
#define GPIOF_IDR_Addr (GPIOF_BASE+8) //0x40011A08
#define GPIOG_IDR_Addr (GPIOG_BASE+8) //0x40011E08
//IO口操作,只对单一的IO口!
//确保n的值小于16!
#define PAout(n) u8_ADDR(GPIOA_ODR_Addr,n) //输出
#define PAin(n) u8_ADDR(GPIOA_IDR_Addr,n) //输入
#define PBout(n) u8_ADDR(GPIOB_ODR_Addr,n) //输出
#define PBin(n) u8_ADDR(GPIOB_IDR_Addr,n) //输入
#define PCout(n) u8_ADDR(GPIOC_ODR_Addr,n) //输出
#define PCin(n) u8_ADDR(GPIOC_IDR_Addr,n) //输入
#define PDout(n) u8_ADDR(GPIOD_ODR_Addr,n) //输出
#define PDin(n) u8_ADDR(GPIOD_IDR_Addr,n) //输入
#define PEout(n) u8_ADDR(GPIOE_ODR_Addr,n) //输出
#define PEin(n) u8_ADDR(GPIOE_IDR_Addr,n) //输入
#define PFout(n) u8_ADDR(GPIOF_ODR_Addr,n) //输出
#define PFin(n) u8_ADDR(GPIOF_IDR_Addr,n) //输入
#define PGout(n) u8_ADDR(GPIOG_ODR_Addr,n) //输出
#define PGin(n) u8_ADDR(GPIOG_IDR_Addr,n) //输入
//Ex_NVIC_Config专用定义
#define GPIO_A 0
#define GPIO_B 1
#define GPIO_C 2
#define GPIO_D 3
#define GPIO_E 4
#define GPIO_F 5
#define GPIO_G 6
//IO操作函数
#define IIC_SCL PBout(15) //SCL
#define IIC_SDA PBout(14) //SDA
#define READ_SDA PBin(14) //输入SDA
void I2C_Configuration(void);
/* Private typedef----------------------------------------------------------------------------*/
// 寄存器结构
// CONTROL1,结构定义
typedef struct
u8 CT:3;
u8 TEST:1;
u8 nCLEN2:1;
u8 HOUR24:1;
u8 DALE:1;
u8 WALE:1;
}_RX8025_REG_CONTROL1_BITS;
typedef union
u8 byte;
_RX8025_REG_CONTROL1_BITS bits;
}_RX8025_REG_CONTROL1;
/* Private macro------------------------------------------------------------------------------*/
/* Private variables--------------------------------------------------------------------------*/
/* Private function prototypes----------------------------------------------------------------*/
/* Private functions--------------------------------------------------------------------------*/
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO ,ENABLE);
/* Configure I2C2 pins: PB15 -> SCL and PB14 -> SDA */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14 | GPIO_Pin_15;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
GPIO_Init(GPIOB, &GPIO_InitStructure);
void SDA_IN(void) //sda线输入 ,PA11
GPIO_InitTypeDef GPIO_InitStructure;//声明GPIO初始化结构体
// Configure I2C1 pins:SDA
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
void SDA_OUT(void) //sda线输出
// 延时总时间=cnt*16+24us
void delay(u16 cnt)
u8 i;
for(;cnt>0;cnt--)
for(i=0;i<100;i++);
//产生IIC起始信号
void IIC_Start(void)
SDA_OUT(); //sda线输出
IIC_SDA=1;
IIC_SCL=1;
delay(4);
IIC_SDA=0;//START:when CLK is high,DATA change form high to low
delay(4);
IIC_SCL=0;//钳住I2C总线,准备发送或接收数据
//产生IIC停止信号
void IIC_Stop(void)
SDA_OUT();//sda线输出
IIC_SCL=0;
IIC_SDA=0;//STOP:when CLK is high DATA change form low to high
delay(4);
IIC_SCL=1;
IIC_SDA=1;//发送I2C总线结束信号
delay(4);
//等待应答信号到来
//返回值:1,接收应答失败
// 0,接收应答成功
u8 IIC_Wait_Ack(void)
u8 ucErrTime=0;
SDA_IN(); //SDA设置为输入
IIC_SDA=1;delay(1);
IIC_SCL=1;delay(1);
while(READ_SDA)
ucErrTime++;
if(ucErrTime>250)
IIC_Stop();
return 1;
IIC_SCL=0;//时钟输出0
return 0;
//产生ACK应答
void IIC_ACK(void)
IIC_SCL=0;
SDA_OUT();
IIC_SDA=0;
delay(2);
IIC_SCL=1;
delay(2);
IIC_SCL=0;
//不产生ACK应答
void IIC_NAck(void)
IIC_SCL=0;
SDA_OUT();
IIC_SDA=1;
delay(2);
IIC_SCL=1;
delay(2);
IIC_SCL=0;
//IIC发送一个字节
//返回从机有无应答
//1,有应答
//0,无应答
u8 IIC_Send_Byte(u8 txd)
u8 t;
SDA_OUT();
IIC_SCL=0;//拉低时钟开始数据传输
for(t=0;t<8;t++)
IIC_SDA=(txd&0x80)>>7;
txd<<=1;
delay(2); //对TEA5767这三个延时都是必须的
IIC_SCL=1;
delay(2);
IIC_SCL=0;
delay(2);
t=IIC_Wait_Ack();
return (t);
//读1个字节,ack=1时,发送ACK,ack=0,发送nACK
u8 IIC_Read_Byte(u8 ack)
u8 i,receive=0;
SDA_IN();//SDA设置为输入
for(i=0;i<8;i++ )
IIC_SCL=0;
delay(2);
IIC_SCL=1;
receive<<=1;
if(READ_SDA)receive++;
delay(1);
if (!ack)
IIC_NAck();//发送nACK
IIC_ACK(); //发送ACK
return receive;
void RX8025Write(u8 addr,u8 *pData,u8 len)
u8 i;
IIC_Start();
if(IIC_Send_Byte(RX8025_ADDR_WRITE)==1)
IIC_Stop();
return;
if(IIC_Send_Byte(addr)==1)
IIC_Stop();
return;
for(i=0;i<len;i++)
if(IIC_Send_Byte(pData)==1)
IIC_Stop();
return;
IIC_Stop();
void RX8025Read(u8 addr,u8 *pData,u8 len)
u8 i;
IIC_Start();
IIC_Stop();
return;
IIC_Stop();
return;
IIC_Start();
if(IIC_Send_Byte(RX8025_ADDR_READ)==1)
IIC_Stop();
return;
for(i=0;i<len-1;i++)
pData = IIC_Read_Byte(1);
// IIC_ACK();
pData = IIC_Read_Byte(0);
// IIC_NAck();
IIC_Stop();
* Function : BSP_RX8025Write
* Description : 向时钟芯片写数据
* Input :
* Output :
* Note(s) :
* Contributor : 081218 andydriver
void BSP_RX8025Write(u8 *pData,u8 len)
RX8025Write((RX8025_ADDR_SECONDS&RX8025_WRITE_MODE),pData,len);
* Function : BSP_RX8025Read
* Description : 从时钟芯片读取数据
* Input :
* Output :
* Note(s) :
void BSP_RX8025Read(u8 *pData,u8 len)
RX8025Read((RX8025_ADDR_SECONDS&RX8025_READ_MODE),pData,len);
* Function : BSP_RX8025ControlINTA
* Description : 控制芯片的INTA脚状态
* Input : state:状态(_BSPRX8025_INTAOUT)
BSPRX8025_INTAOUT_HIZ:高阻
BSPRX8025_INTAOUT_LOW:输出低
BSPRX8025_INTAOUT_2HZ:输出2Hz(50%)的脉冲
BSPRX8025_INTAOUT_1HZ:输出1Hz(50%)的脉冲
BSPRX8025_INTAOUT_SEC:每秒的第0秒翻转?还是脉冲?
BSPRX8025_INTAOUT_MIN:每分的第0秒翻转?还是脉冲?
BSPRX8025_INTAOUT_HOUR:每时的第0秒翻转?还是脉冲?
BSPRX8025_INTAOUT_MONTH:每月的第0秒翻转?还是脉冲?
* Output :
* Note(s) :
//void BSP_RX8025ControlINTA(_BSPRX8025_INTAOUT state)
// _RX8025_REG_CONTROL1 data;
// RX8025Read((RX8025_ADDR_CONTROL1&RX8025_READ_MODE),(u8 *)(&data),1);
// data.bits.CT = state; // INTA输出1Hz方波
// RX8025Write((RX8025_ADDR_CONTROL1&RX8025_WRITE_MODE),(u8 *)(&data),1);
* Function : BSP_RX8025Init
* Description : RX8025初始化
* Input :
* Output :
* Note(s) :
* Contributor : 081210 andydriver
void BSP_RX8025Init(void)
u8 buf[16];
u8 i;
// iic_init();
RX8025Read((RX8025_ADDR_SECONDS&RX8025_READ_MODE),buf,8);
buf[0] = 0x20;
RX8025Write((RX8025_ADDR_CONTROL1&RX8025_WRITE_MODE),buf,1); //24小时制
RX8025Read((RX8025_ADDR_SECONDS&RX8025_READ_MODE),buf,16);
i++;
