查看: 10370|回复: 11
51单片机最小系统板 12864液晶无法显示 求解决
51单片机最小系统板 如图,写入程序后12864液晶无法显示,已经试过多次了。。唉。。
   付上程序,看看哪时不行了??
#include "reg52.h"
#include "intrins.h"
sbit io_LCD12864_RS = P2^3 ;
sbit io_LCD12864_RW = P2^4 ;
sbit io_LCD12864_EN = P2^5 ;
#define io_LCD12864_DATAPORT P0
#define SET_DATA    io_LCD12864_RS = 1 ;
#define SET_INC      io_LCD12864_RS = 0 ;
#define SET_READ   io_LCD12864_RW = 1 ;
#define SET_WRITE io_LCD12864_RW = 0 ;
#define SET_EN       io_LCD12864_EN = 1 ;
#define CLR_EN       io_LCD12864_EN = 0 ;
void v_Lcd12864CheckBusy_f( void )      //忙检测函数
        unsigned int nTimeOut = 0 ;
  SET_INC
  SET_READ
  CLR_EN
  SET_EN
  while( ( io_LCD12864_DATAPORT & 0x80 ) && ( ++nTimeOut != 0 ) ) ;
  CLR_EN
  SET_INC
  SET_READ
void v_Lcd12864SendCmd_f( unsigned char byCmd )     //发送命令
  v_Lcd12864CheckBusy_f() ;
        SET_INC
  SET_WRITE
  CLR_EN
  io_LCD12864_DATAPORT = byCmd ;
  _nop_();
  _nop_();
  SET_EN
  _nop_();
  _nop_();
  CLR_EN
  SET_READ
  SET_INC
void v_Lcd12864SendData_f( unsigned char byData ) //发送数据
        SET_DATA
  SET_WRITE
  CLR_EN
  io_LCD12864_DATAPORT = byData ;
  _nop_();
  _nop_();
  SET_EN
  _nop_();
  _nop_();
  CLR_EN
  SET_READ
  SET_INC
void v_DelayMs_f( unsigned int nDelay )          //延时
  unsigned int i ;
        for( ; nDelay > 0 ; nDelay-- )
          for( i = 125 ; i > 0 ; i-- ) ;
void v_Lcd12864Init_f( void )              //初始化
  v_Lcd12864SendCmd_f( 0x30 ) ;           //基本指令集
  v_DelayMs_f( 50 ) ;
  v_Lcd12864SendCmd_f( 0x01 ) ;           //清屏
  v_DelayMs_f( 50 ) ;
  v_Lcd12864SendCmd_f( 0x06 ) ;           //光标右移
  v_DelayMs_f( 50 ) ;
  v_Lcd12864SendCmd_f( 0x0c ) ;            //开显示
void v_Lcd12864SetAddress_f( unsigned char x, y )    //地址转换
  unsigned char byAddress ;
  switch( y )
    case 0 :  byAddress = 0x80 + x ;
      break;
    case 1 :  byAddress = 0x90 + x ;
      break ;
    case 2 :  byAddress = 0x88 + x ;
      break ;
    case 3 :       byAddress = 0x98 + x ;
      break ;
    default :
      break ;
  v_Lcd12864SendCmd_f( byAddress ) ;
void v_Lcd12864PutString_f( unsigned char x, unsigned char y, unsigned char *pData )
  v_Lcd12864SetAddress_f( x, y ) ;
  while( *pData != '\0' )
    v_Lcd12864SendData_f( *pData++ ) ;
void main( void )
  v_Lcd12864Init_f() ;
  v_Lcd12864PutString_f( 0,0, "快乐随行") ;
  v_Lcd12864PutString_f( 2,1, "分都不给") ;
  v_Lcd12864PutString_f( 0,2, "*LCD12864ST7920*") ;
  v_Lcd12864PutString_f( 0,3, "辛苦回答了半天") ;
  while( 1 ) ;
板子接口说明
板子接口说明
12864接口说明
12864接口说明
收藏收藏1 分享淘帖 顶 踩
ID:63094 发表于 2014-10-9 16:19 | 只看该作者
刚试了你的程序 也没显示出来 ,我也刚学 没法帮你改呵呵,简单的会改
ID:66729 发表于 2014-10-9 21:03 | 只看该作者
我换了其他的程序,,改了接口,现在可以显示了,,,唉开始以为LCD是坏的。。呵呵
ID:44262 发表于 2014-10-10 11:37 来自手机 | 只看该作者
能共享一下可用的程序吗?
ID:66729 发表于 2014-10-10 22:01 | 只看该作者
这个是我的板子上能正常显示的程序,你也可以改一下接口或者显示的字体。
//头文件:
#include <reg52.h>
/********IO引脚定义***********************************************************/
sbit LCD_RS=P2^3;//定义引脚
sbit LCD_RW=P2^4;
sbit LCD_E=P2^5;
sbit PSB =P2^6;                //PSB脚为12864-12系列的串、并通讯功能切换,使用8位并行接口,PSB=1
/********宏定义***********************************************************/
#define LCD_Data P0
#define Busy    0x80 //用于检测LCD状态字中的Busy标识
/********函数声明*************************************************************/
void WriteDataLCD(unsigned char WDLCD);
void WriteCommandLCD(unsigned char WCLCD,BuysC);
unsigned char ReadDataLCD(void);
unsigned char ReadStatusLCD(void);
void LCDInit(void);
void LCDClear(void);
void LCDFlash(void);
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
void Delay5Ms(void);
void Delay400Ms(void);
/********数据定义*************************************************************/
code unsigned char  uctech[] = {"5 1 单片机实验板"};
code unsigned char  net[] = {"lydz8.taobao.com"};
code unsigned char  mcu[] = {"自学单片机的首选"};
code unsigned char  qq[] = {"  QQ: 52927029  "};
/***********主函数开始********************************************************/
void main(void)
        Delay400Ms();         //启动等待,等LCD讲入工作状态
        LCDInit();                 //LCM初始化
        Delay5Ms();         //延时片刻(可不要)
        while(1){
                LCDClear();
                DisplayListChar(0,1,uctech);        //显示字库中的中文数字
                DisplayListChar(0,2,net);                //显示字库中的中文数字
                DisplayListChar(0,3,mcu);                //显示字库中的中文
                DisplayListChar(0,4,qq);                //显示字库中的中文数字
                Delay400Ms();
                Delay400Ms();
                Delay400Ms();
                Delay400Ms();
                LCDFlash();                                                //闪烁效果
/***********写数据********************************************************/
        ReadStatusLCD(); //检测忙
        LCD_RS = 1;
        LCD_RW = 0;
        LCD_Data = WDLCD;
        LCD_E = 1;
        LCD_E = 1;
        LCD_E = 0;
/***********写指令********************************************************/
void WriteCommandLCD(unsigned char WCLCD,BuysC) //BuysC为0时忽略忙检测
        if (BuysC) ReadStatusLCD(); //根据需要检测忙
        LCD_RS = 0;
        LCD_RW = 0;
        LCD_Data = WCLCD;
        LCD_E = 1;
        LCD_E = 1;
        LCD_E = 0;
/***********读数据********************************************************/
        unsigned char LCDDA;
        LCD_RS = 1;
        LCD_RW = 1;
        LCD_E = 1;
        LCD_E = 1;
        LCDDA=LCD_Data;
        LCD_E = 0;
        return(LCDDA);
/***********读状态*******************************************************/
        LCD_Data = 0xFF;
        LCD_RS = 0;
        LCD_RW = 1;
        LCD_E = 1;
        LCD_E = 1;
        while (LCD_Data & Busy); //检测忙信号
        LCD_E = 0;
        return(1);
/***********初始化********************************************************/
void LCDInit(void)
        WriteCommandLCD(0x30,1); //显示模式设置,开始要求每次检测忙信号
        WriteCommandLCD(0x01,1); //显示清屏
        WriteCommandLCD(0x06,1); // 显示光标移动设置
        WriteCommandLCD(0x0C,1); // 显示开及光标设置
/***********清屏********************************************************/
void LCDClear(void)
        WriteCommandLCD(0x34,1); // 显示光标移动设置
        WriteCommandLCD(0x30,1); // 显示开及光标设置
/***********闪烁效果********************************************************/
void LCDFlash(void)
        WriteCommandLCD(0x08,1); //显示清屏
        Delay400Ms();
        WriteCommandLCD(0x0c,1); // 显示开及光标设置
        Delay400Ms();
        Delay400Ms();
        Delay400Ms();
        Delay400Ms();
/***********按指定位置显示一个字符*******************************************/
        if(Y<1)
                Y=1;
        if(Y>4)
                Y=4;
        X &= 0x0F;                         //限制X不能大于16,Y不能大于1
        switch(Y){
        case 1:X|=0X80;break;
        case 2:X|=0X90;break;
        case 3:X|=0X88;break;
        case 4:X|=0X98;break;
        WriteCommandLCD(X, 0); //这里不检测忙信号,发送地址码
        WriteDataLCD(DData);
/***********按指定位置显示一串字符*****************************************/
        unsigned char ListLength,X2;
        ListLength = 0;
        X2=X;
        if(Y<1)
                Y=1;
        if(Y>4)
                Y=4;
        X &= 0x0F;                                 //限制X不能大于16,Y在1-4之内
        switch(Y){
        case 1:X2|=0X80;break;        //根据行数来选择相应地址
        case 2:X2|=0X90;break;
        case 3:X2|=0X88;break;
        case 4:X2|=0X98;break;
        WriteCommandLCD(X2, 1);         //发送地址码
          while (DData[ListLength]>=0x20){ //若到达字串尾则退出
                   if (X <= 0x0F){                         //X坐标应小于0xF
                     WriteDataLCD(DData[ListLength]);
                     ListLength++;
                         X++;
                         Delay5Ms();
/***********短延时********************************************************/
void Delay5Ms(void)
        unsigned int TempCyc = 5552;
        while(TempCyc--);
/***********长延时********************************************************/
        unsigned char TempCycA = 5;
        unsigned int TempCycB;
        while(TempCycA--){
                  TempCycB=7269;
                  while(TempCycB--);
ID:66729 发表于 2014-10-10 22:03 | 只看该作者
HEX文件
参与人数 1威望 +50 黑币 +50 收起 理由
admin + 50 + 50 共享资料的积分奖励!
ID:67992 发表于 2014-11-5 22:57 | 只看该作者
程序一点问题都没有,只改了3根控制线,正常显示。
参与人数 1威望 +50 收起 理由
admin + 50
ID:66840 发表于 2014-11-6 08:35 | 只看该作者
程序里由很多没加分号
ID:68253 发表于 2014-11-8 21:26 | 只看该作者
是你接口没整清楚吧
ID:66729 发表于 2014-11-15 19:38 | 只看该作者
wyy450y 发表于 2014-11-8 21:26
是你接口没整清楚吧
已经正常,换个程序就好了。。呵呵
ID:109647 发表于 2016-3-19 10:39 | 只看该作者
你好  我也是这个程序  出的问题  请问您改了哪三根控制线?
ID:147415 发表于 2017-9-7 16:16 | 只看该作者
rst没有强制复位一次
