查看: 2906|回复: 2
求讲解ADC0832中数据
ID:67134 发表于 2014-10-9 14:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一下是一个ADC0832模数转换显示,特别是红色不能不明白啥意思,求高手讲解。
#include <reg51.h>
#include <intrins.h>
#define delay4us() {_nop_();_nop_();_nop_();_nop_();}
sbit RS = P2^0;
sbit RW = P2^1;
sbit E  = P2^2;
sbit CS  = P1^0;
sbit CLK = P1^1;
sbit DIO = P1^2;
uchar Display_Buffer[] = "0.00V";
uchar code Line1[] = "Current Voltage:";
void DelayMS(uint ms)
        uchar i;
        while(ms--)
                 for(i=0;i<120;i++);
bit LCD_Busy_Check()
        bit result;
        RS = 0;
        RW = 1;
        E  = 1;
        delay4us();
        result = (bit)(P0&0x80);
        E  = 0;
        return result;
void LCD_Write_Command(uchar cmd)
        while(LCD_Busy_Check());
        RS = 0;
        RW = 0;
        E  = 0;
        _nop_();
        _nop_();
        P0 = cmd;
        delay4us();
        E = 1;
        delay4us();
        E = 0;
void Set_Disp_Pos(uchar pos)
        LCD_Write_Command(pos | 0x80);
void LCD_Write_Data(uchar dat)
        RS = 1;
        RW = 0;
        E  = 0;
        P0 = dat;
        delay4us();
        E = 1;
        delay4us();
        E = 0;
void LCD_Initialise()
        LCD_Write_Command(0x38); DelayMS(1);
        LCD_Write_Command(0x0c); DelayMS(1);
        LCD_Write_Command(0x06); DelayMS(1);
        LCD_Write_Command(0x01); DelayMS(1);
uchar Get_AD_Result()
        uchar i,dat1=0,dat2=0;
        CS  = 0;
        CLK = 0;
        DIO = 1; _nop_(); _nop_();
        CLK = 1; _nop_(); _nop_();
        CLK = 0;DIO = 1; _nop_(); _nop_();
        CLK = 1;DIO = 1; _nop_(); _nop_();
        for(i=0;i<8;i++)
                CLK = 0; _nop_(); _nop_();
                dat1 = dat1 << 1 | DIO;
        for(i=0;i<8;i++)
                 dat2 = dat2 |((uchar)(DIO)<<i);
        CS = 1;
        return (dat1 == dat2) ? dat1:0;
        uchar i;
        uint d;
        LCD_Initialise();
        DelayMS(10);
                 d = Get_AD_Result()*500.0/255;
                Display_Buffer[0]=d/100+'0';
                Display_Buffer[2]=d/10%10+'0';
                Display_Buffer[3]=d%10+'0';
                Set_Disp_Pos(0x01);
                i = 0;
                while(Line1!='\0')
                         LCD_Write_Data(Line1[i+1]);
                Set_Disp_Pos(0x46);
                i = 0;
                while(Display_Buffer!='\0')
                         LCD_Write_Data(Display_Buffer[i+1]);
收藏收藏1 分享淘帖 顶 踩
ID:44262 发表于 2014-10-10 11:52 来自手机 | 只看该作者
我觉得应该要先从0832的pdf中文资料开始入手
ID:70769 发表于 2014-12-24 21:18 | 只看该作者
GOOD!!!
