查看: 2501|回复: 0
ds1302在12864上不能显示
ID:70436 发表于 2015-1-1 16:30 | 显示全部楼层 |阅读模式
#include<reg52.h>
#include<intrins.h>
sbit en=P2^5;
sbit rs=P1^0;
sbit rw=P1^1;
sbit psb=P1^2;
sbit dula=P2^6;
sbit wela=P2^7;
sbit sclk=P2^1;
sbit sda=P2^0;
sbit rst=P2^4;
//int c;
uchar lin1[]="年月日";
uchar lin2[]="时分秒";
uchar lin3[]="星期";
//uchar lin4[]="一二三四五六日";
uchar lin5[]={0,1,2,3,4,5,6,7,8,9};
void delay(uint z)
   uint i,j;
   for(i=z;i>0;i--)
   for(j=110;j>0;j--);
void write_comdate(uint n,uchar date)
   rw=0;
   rs=(0|n);
   en=0;
   P0=date;
   en=1;
   delay(5);
   en=0;
   delay(5);
void LCD_chinese( char        *p )
  write_comdate(1,*p);
  p++;
void lcd_init()
{  psb=1;
  dula=0;
  wela=0;
  delay(10);
  write_comdate(0,0x38);
  delay(5);
  write_comdate(0,0x30);
  delay(5);
  write_comdate(0,0x06);
  delay(5);
  write_comdate(0,0x0c);
  delay(5);
  write_comdate(0,0x01);
  delay(5);
void write_ds(uchar date)
  uchar i;
  sclk=0;
  for(i=0;i<8;i++)
    sda=date&0x01;
        sclk=1;
        delay(1);
        sclk=0;
        delay(1);
        date>>=1;
void write_pos(uchar add,uchar date)
  rst=0;
  sclk=0;
  rst=1;
  write_comdate(0,add);
  write_comdate(1,date);
  rst=0;
  sclk=1;
  delay(5);
uchar read_comdate()
   uint i;
   uchar dat;
   sclk=0;
  for(i=0;i<8;i++)
    dat=dat>>1;
        if(sda==1)
        dat|=0x80;
        sclk=1;
        delay(1);
        sclk=0;
         return dat;
uchar read_pos(uchar add)
  uchar temp;
   rst=0;
   sclk=0;
   rst=1;
   temp=(read_comdate());
   sclk=1;
   rst=0;
   return temp;
void ds1302_init()
  write_pos(0x8e,0x00);
  write_pos(0x80,((55/10)<<4)|(55%10));
  delay(1);
  write_pos(0x8a,((3/10)<<4)|(3%10));
  delay(1);
  write_pos(0x82,((20/10)<<4)|(20%10));
  delay(1);
  write_pos(0x84,((23/10)<<4)|(23%10));
  delay(1);
  write_pos(0x86,((16/10)<<4)|(16%10));
  delay(1);
write_pos(0x88,((3/10)<<4)|(3%10));
delay(1);
write_pos(0x8c,((12/10)<<4)|(12%10));
delay(1);
//write_pos(0x90,0xa6);
//delay(1);
write_pos(0x8e,0x80);
uchar read_value(uchar add)
          uchar bcdvalue,dcevalue;
        bcdvalue=read_pos(add);
        dcevalue=((bcdvalue&0x70)>>4)*10+(bcdvalue&0x0f);
        return dcevalue;
uchar read_year()
bcdvalue=read_pos(0x8d);
dcevalue=((bcdvalue&0xf0)>>4)*10+(bcdvalue&0x0f);
return dcevalue;
void display(uchar add,uchar x)
uint i,j;
i=x/10;
j=x%10;
write_comdate(0,lin5[i]+0x30);
write_comdate(0,lin5[j]+0x30);
delay(5);
i=j=0;
void init_devise()
lcd_init();
delay(5);
ds1302_init();
delay(5);
void display_init()
  write_comdate(0,0x81);
  write_comdate(1,'2');
  write_comdate(1,'0');
  write_comdate(0,0x83);
  LCD_chinese(&lin1[0]);
  write_comdate(0,0x85);
  LCD_chinese(&lin1[2]);
  write_comdate(0,0x87);
  LCD_chinese(&lin1[4]);
   write_comdate(0,0x92);
  LCD_chinese(&lin2[0]);
   write_comdate(0,0x94);
  LCD_chinese(&lin2[2]);
   write_comdate(0,0x96);
  LCD_chinese(&lin2[4]);
   write_comdate(0,0x8a);
  LCD_chinese(&lin3[0]);
   write_comdate(0,0x8b);
  LCD_chinese(&lin3[2]);
  init_devise();
  delay(100);
  display_init();
  delay(20);
    display(0x82,read_year());
        display(0x84,read_value(0x89));
        display(0x86,read_value(0x87));
        display(0x95,read_value(0x81));
        display(0x93,read_value(0x83));
        display(0x91,read_value(0x85));
        display(0x8c,read_value(0x8b));
求大神指教
