查看: 3889|回复: 2
12232液晶屏串行驱动51单片机C程序
ID:73735 发表于 2015-2-18 23:33 | 显示全部楼层 |阅读模式
#include <reg52.h>
#define uint  unsigned int
#define x1    0x80
#define x2    0x88
#define y     0x80
#define comm  0
#define dat   1
sbit cs   = P3^3;
sbit std  = P3^1;
sbit sclk = P3^0;
void wr_lcd (uchar dat_comm,uchar content);
void delay (uint us);
uchar code tab1[]={
"天行健君子以自强不息"
"地势坤君子以厚德载物"
uchar code tab31[]={
"北京欢迎你WelcometoBeijing"
uchar code tab32[]={
/*--  调入了一幅图像:F:\梁\画图\HOCO12832.bmp  --*/
/*--  宽度x高度=128x32  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1E,0x00,0x00,0x00,0x00,0x00,0x07,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x7F,0x80,0x00,0x00,0x00,0x00,0x18,0x0C,0x00,0x00,0x01,0x00,0x00,0x00,0x00,
0x01,0xFF,0x80,0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x13,0x10,0x03,0xFE,0x00,
0x03,0xFF,0xC0,0x00,0x00,0x00,0x00,0x58,0x00,0x00,0x00,0x3F,0x30,0x1F,0xFF,0xC0,
0x03,0xFF,0xE0,0x00,0x00,0x00,0x00,0x8C,0x03,0xF0,0x00,0x7F,0xE0,0x7C,0x01,0xE0,
0x03,0xFF,0xF0,0x00,0x00,0x00,0x01,0x36,0x06,0xC0,0x00,0x5F,0xC0,0xFF,0xFC,0x60,
0x01,0xFF,0xF0,0x00,0x00,0x00,0x02,0x1B,0x0F,0x80,0x00,0xFF,0x01,0xFE,0x0F,0x30,
0x00,0xEF,0xF0,0x00,0x00,0x00,0x02,0x6D,0x9F,0x00,0x00,0x3E,0x03,0xFF,0xF1,0x90,
0x00,0xFF,0xF8,0x00,0x00,0x00,0x04,0x36,0xFE,0x00,0x01,0xFF,0x07,0xFF,0xFC,0x90,
0x00,0xEF,0xFF,0xFF,0x80,0x00,0x04,0xDB,0x7E,0x00,0x03,0xFF,0x87,0xFF,0xFC,0xD0,
0x00,0x0F,0xFF,0xFF,0xC0,0x00,0x04,0x6D,0xFC,0x00,0x07,0xFF,0x8F,0xFF,0xFE,0x50,
0x00,0x0F,0xFF,0xFF,0xE0,0x00,0x04,0x36,0xFC,0x10,0x07,0xFF,0x8F,0xFF,0xFE,0x90,
0x00,0x0F,0xFF,0xFF,0xE0,0x00,0x04,0x1B,0xF8,0x10,0x07,0xFF,0xCF,0xFF,0xFE,0x80,
0x00,0x0F,0xFF,0xFF,0xF0,0x00,0x04,0x0F,0xF8,0x10,0x07,0xFF,0xFF,0xFF,0xFA,0x00,
0x00,0x07,0xFF,0xFF,0xF0,0x00,0x04,0x07,0xF0,0x10,0x07,0xFF,0xFF,0xFF,0xFA,0x00,
0x00,0xFF,0xFF,0xFF,0xF8,0x00,0x02,0x03,0xF0,0x20,0x07,0xFF,0xFF,0xFF,0xBA,0x00,
0x00,0xFD,0xFF,0xFF,0xFC,0x00,0x02,0x03,0xF0,0x20,0x03,0xFF,0xFF,0xDF,0xB8,0x00,
0x00,0xC1,0xC0,0x3F,0xFC,0x00,0x01,0x01,0xE0,0x40,0x00,0xFF,0xFF,0xDF,0xB0,0x00,
0x00,0x81,0xC0,0x3F,0xCE,0x00,0x00,0x81,0xE0,0x80,0x00,0x7F,0xFF,0xDF,0xA0,0x00,
0x00,0x81,0x80,0x1D,0xCF,0x00,0x00,0x41,0xE1,0x00,0x00,0x3F,0xFF,0x9B,0x00,0x00,
0x01,0x83,0x80,0x1F,0xC7,0x80,0x00,0x21,0xE2,0x00,0x00,0x1F,0xFD,0xB6,0x00,0x00,
0x01,0xC3,0x00,0x0E,0xE6,0x80,0x00,0x19,0xEC,0x00,0x00,0x07,0xFE,0x20,0x00,0x00,
0x00,0xC3,0x00,0x07,0x67,0x40,0x00,0x07,0xF0,0x00,0x00,0x03,0x3E,0x00,0x00,0x00,
0x00,0x02,0x00,0x03,0xE7,0xA0,0x00,0x00,0x00,0x00,0x00,0x02,0x8E,0x00,0x00,0x00,
0x00,0x06,0x00,0x03,0x83,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x03,0x00,0x00,0x00,
0x00,0x06,0x00,0x07,0x03,0x00,0x77,0x46,0x74,0x24,0x80,0x06,0x04,0x00,0x00,0x00,
0x00,0x1C,0x00,0x06,0x00,0x00,0x55,0x45,0x54,0x57,0x80,0x00,0x00,0x00,0x00,0x00,
0x00,0x1C,0x00,0x0E,0x00,0x00,0x45,0x45,0x74,0x57,0x80,0x08,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x1C,0x00,0x00,0x55,0x45,0x44,0x74,0x80,0xF0,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x38,0x00,0x00,0x77,0x76,0x47,0x54,0x80,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
uchar code tab5[]={
/*--  调入了一幅图像:F:\梁\画图\COCK.bmp  --*/
/*--  宽度x高度=128x64  --*/
0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x80,0x00,0x0F,0xFF,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x0C,0x43,0x01,0x80,0x00,0x7F,0xFF,0xF0,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x19,0xFF,0x07,0x00,0x07,0xFF,0xFF,0xFE,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x01,0x3F,0xFC,0x1E,0x00,0x1F,0xFF,0xFF,0xFF,0x80,0x00,0x00,0x00,
0x00,0x00,0x00,0x01,0xBF,0xFF,0xFC,0x00,0x7F,0xFC,0x00,0x7F,0xC0,0x00,0x00,0x00,
0x00,0x00,0x00,0x01,0xFF,0xFF,0xF0,0x00,0xFF,0xC0,0x00,0x0F,0xE0,0x00,0x00,0x00,
0x00,0x00,0x00,0x01,0xFF,0xFF,0xE0,0x03,0xFF,0xFF,0xFC,0x01,0xF0,0x00,0x00,0x00,
0x00,0x00,0x00,0x01,0xDF,0xFF,0xC0,0x07,0xFF,0xFF,0xFF,0x80,0xF0,0x00,0x00,0x00,
0x00,0x00,0x00,0x03,0xFF,0xFF,0x00,0x0F,0xFF,0xFF,0xFF,0xE0,0x38,0x00,0x00,0x00,
0x00,0x00,0x00,0x07,0xFF,0xF8,0x00,0x1F,0xFF,0xF0,0x03,0xF8,0x38,0x00,0x00,0x00,
0x00,0x00,0x00,0x07,0xFF,0xE0,0x00,0x3F,0xFF,0xFF,0xC0,0x7C,0x18,0x00,0x00,0x00,
0x00,0x00,0x00,0x04,0x7F,0xF0,0x00,0x3F,0xFF,0xFF,0xF8,0x1E,0x08,0x00,0x00,0x00,
0x00,0x00,0x00,0x01,0xFF,0xF8,0x00,0x7F,0xFF,0xFF,0xFE,0x0F,0x08,0x00,0x00,0x00,
0x00,0x00,0x00,0x0F,0xFF,0xFC,0x00,0xFF,0xFF,0xFF,0xFF,0x87,0x08,0x00,0x00,0x00,
0x00,0x00,0x00,0x1F,0xFF,0xFE,0x00,0xFF,0xFF,0xFF,0xFF,0x83,0x88,0x00,0x00,0x00,
0x00,0x00,0x00,0x3F,0xFF,0xFE,0x01,0xFF,0xFF,0xFF,0xFF,0xC3,0x88,0x00,0x00,0x00,
0x00,0x00,0x00,0x7F,0xFF,0xFE,0x01,0xFF,0xFF,0xFF,0xFF,0xE1,0x88,0x00,0x00,0x00,
0x00,0x00,0x00,0xFF,0xFF,0xFE,0x03,0xFF,0xFF,0xFF,0xFF,0xE1,0x88,0x00,0x00,0x00,
0x00,0x00,0x01,0xFF,0xFF,0xFE,0x03,0xFF,0xFF,0xFF,0xFF,0xF1,0x88,0x00,0x00,0x00,
0x00,0x00,0x01,0xFF,0xFF,0xFE,0x03,0xFF,0xFF,0xFF,0xFF,0xF3,0x08,0x00,0x00,0x00,
0x00,0x00,0x01,0xFF,0xFF,0xFF,0x07,0xFF,0xFF,0xFF,0xFF,0xF2,0x10,0x00,0x00,0x00,
0x00,0x00,0x01,0xFF,0xFF,0xFF,0x8F,0xFF,0xFF,0xFF,0xFF,0xF0,0x20,0x00,0x00,0x00,
0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x00,0x00,0x00,
0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x70,0x00,0x00,0x00,0x00,
0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0x70,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0xFF,0x7F,0x20,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xBF,0xFF,0x7F,0x20,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0x7E,0x20,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0x3E,0x40,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xCF,0xFF,0x3C,0x40,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xCF,0xFE,0x38,0x40,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0x8F,0xFE,0x38,0x40,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0x8F,0xFE,0x30,0x40,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x1F,0x7C,0x20,0x40,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFE,0x1E,0x78,0x00,0x40,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFE,0x1E,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xDA,0x3C,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xF2,0x30,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xF1,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0xFE,0x7F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x7C,0x3F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x78,0x1F,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x72,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x70,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x60,0x00,0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x60,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0xC0,0x03,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x01,0x40,0x04,0xD8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x01,0x00,0x01,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x02,0x0C,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x02,0x40,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x0C,0x48,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x38,0x41,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x0F,0xE2,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*------------------初始化-----------------*/
void init_lcd (void)
  wr_lcd (comm,0x30);  /*30---基本指令动作*/
  wr_lcd (comm,0x01);  /*清屏,地址指针指向00H*/
  delay (100);
  wr_lcd (comm,0x06);  /*光标的移动方向*/
  wr_lcd (comm,0x0c);  /*开显示,关游标*/
/*--------上半屏显示汉字或字符---------*/
void chn_dispup (uchar code *chn)
  uchar i,j;
  wr_lcd (comm,0x80);  //把显示地址设为0X80,即为第一行的首位--第一页
  j=0;
  for (i=0;i<16;i++)
  wr_lcd (dat,chn[j*16+i]);
/*--------下半屏显示汉字或字符---------*/
void chn_dispdown (uchar code *chn)
  uchar i,j;
  wr_lcd (comm,0x90);        //把显示地址设为0X90,即为第二行的首位--第二页
  j=0;
  for (i=0;i<16;i++)
/*--------上下半屏顺序显示汉字或字符---------*/
void chn_disp1 (uchar code *chn)
  uchar i,j;
  j=0;
  for (i=0;i<16;i++)
  j=1;
  for (i=0;i<16;i++)
/*------------显示图形-------------*/
void img_disp (uchar code *img)
  uchar i,j;
  for(j=0;j<32;j++)
    for(i=0;i<8;i++)
      wr_lcd (comm,0x34); //扩充指令操作
      wr_lcd (comm,y+j);
      wr_lcd (comm,x1+i);
      wr_lcd (comm,0x30);
      wr_lcd (dat,img[j*16+i*2]);
      wr_lcd (dat,img[j*16+i*2+1]);
  for(j=32;j<64;j++)
    for(i=0;i<8;i++)
      wr_lcd (comm,0x34);
      wr_lcd (comm,y+j-32);
      wr_lcd (comm,x2+i);
      wr_lcd (comm,0x30);
  wr_lcd (comm,0x36);
/*--------------显示点阵----------------*/
void lat_disp (uchar data1,uchar data2)
  uchar i,j,k,x;
  x=x1;
  for(k=0;k<2;k++)
    for(j=0;j<16;j++)
      for(i=0;i<8;i++)
        wr_lcd (comm,0x34);
        wr_lcd (comm,y+j*2); //把显示地址设为0X80,即为第一行的首位
        wr_lcd (comm,x+i);
        wr_lcd (comm,0x30);  //功能设置:一次送8位数据,基本指令集
        wr_lcd (dat,data1);
        wr_lcd (dat,data1);
      for(i=0;i<8;i++)
        wr_lcd (comm,y+j*2+1);
        wr_lcd (comm,x+i);
        wr_lcd (comm,0x30);    //基本指令操作
        wr_lcd (dat,data2);
        wr_lcd (dat,data2);
    x=x2;
  wr_lcd (comm,0x36);
/*--------------清DDRAM------------------*/
void clrram (void)
  wr_lcd (comm,0x30);
  wr_lcd (comm,0x01);
  delay (180);
  uchar a,i,j;
  delay (50);
  a=content;
  cs=1;
  sclk=0;
  std=1;
  for(i=0;i<5;i++)
    sclk=1;
    sclk=0;
  std=0;
  sclk=1;
  sclk=0;
  if(dat_comm)
    std=1;   //data
    std=0;   //command
  sclk=1;
  sclk=0;
  std=0;
  sclk=1;
  sclk=0;
  for(j=0;j<2;j++)
    for(i=0;i<4;i++)
      a=a<<1;
      std=CY;
      sclk=1;
      sclk=0;
    std=0;
    for(i=0;i<4;i++)
      sclk=1;
      sclk=0;
void delay (uint us)   //delay time
  while(us--);
void delay1 (uint ms)
  uint i,j;
  for(i=0;i<ms;i++)
  for(j=0;j<15;j++)
  delay(1);
/*------------------主程序--------------------*/
void main ()
  SP=0x5f;
  init_lcd ();
  while (1)
    clrram();
    lat_disp (0x00,0x00); //显示点阵
    delay1 (8000);
    clrram();
    lat_disp (0xcc,0xcc); //显示点阵
    delay1 (8000);
    clrram();
    chn_disp1 (tab1);       //上下半屏顺序显示汉字或字符
    delay1 (8000);
    clrram();
    lat_disp (0xff,0x00);  //显示点阵
    delay1 (8000);
    img_disp (tab5);       //显示图形
    delay1 (8000);
    clrram();
    chn_dispup (tab31); //上半屏顺序显示汉字或字符
    delay1 (8000);
clrram();
    chn_dispdown (tab31); //下半屏顺序显示汉字或字符
delay1 (8000);
ID:114296 发表于 2016-4-19 21:36 | 显示全部楼层
学习了,谢谢提供
ID:451441 发表于 2018-12-27 12:33 | 显示全部楼层
谢谢LZ分享资料
