- /* S16 S12 S8 S4分别是123+
- S15 S11 S7 S3分别是456-
- S14 S10 S6 S2分别是789*
- S13 S9 S5 S1分别是0 CLR = /
- /* 实现两个数的运算,每个数的位数至少可以八位 */
- #include<reg52.h>
- typedef unsigned char uint8;
- typedef unsigned int uint16;
- sbit rw=P2^5;
- sbit rs=P2^6;
- sbit e=P2^7;
- sbit led=P3^7;
- sbit beep=P2^0;
- uint8 key,num;
- uint8 fuhao;//定义具体的那个符号,是加减还是乘除。
- uint8 flag; //定义有没有按下符号键,这个是统称
- long a,b,c,d; //定义运算数据的第一个和第二个及等于的数变量
- uint8 k; //定义小数点后面显示的位数
- uint8 biao;
- uint8 dat1[]={1,2,3,0x2b-0x30, 4,5,6,0x2d-0x30, 7,8,9,0x2a-0x30, 0,0x01-0x30,0x3d-0x30,0x2b-0x30 };//保存显示的数据
- void delay(uint16 i)
- while(i--);
- void lcdwrc(uint8 c)
- delay(1000);
- rs=0;
- rw=0;
- e=0;
- P0=c;
- e=1;
- delay(1000);
- e=0;
- void lcdwrd(uint8 dat)
- delay(1000);
- rs=1;
- rw=0;
- e=0;
- P0=dat;
- e=1;
- delay(1000);
- e=0;
- rs=0;
- void lcdinit()
- delay(1500);
- lcdwrc(0x38);
- delay(500);
- lcdwrc(0x38);
- delay(500);
- lcdwrc(0x38);
- delay(500);
- lcdwrc(0x38);
- lcdwrc(0x08);
- lcdwrc(0x01);
- lcdwrc(0x06);
- lcdwrc(0x0c);
- key=0;
- num=0;
- flag=0;
- fuhao=0;
- a=0;
- b=0;
- c=0;
- d=0;
- biao=0;
- led=0;
- void keyscan()
- P1=0xfe; //令第一行为0,然后判断是哪一列按下
- if(P1!=0xfe)
- delay(1000);
- if(P1!=0xfe)
- key=P1&0xf0;
- switch(key)
- case 0xe0: num=0;break; //1
- case 0xd0: num=1;break; //2
- case 0xb0: num=2;break; //3
- case 0x70: num=3;break; //加
- while(P1!=0xfe);
- if(num==0||num==1||num==2) //确认第一行的数1,2,3
- if(flag==0) //没有按下符号键
- //led=1;
- a=a*10+dat1[num];
- else
- //led=1;
- b=b*10+dat1[num];
- if(num==3)
- //led=0;
- flag=1;
- fuhao=1;//加号+
- lcdwrd(0x30+dat1[num]);
- P1=0xfd; //令第二行为0,判断是哪一列按下
- if(P1!=0xfd)
- delay(1000);
- if(P1!=0xfd)
- key=P1&0xf0;
- switch(key)
- case 0xe0: num=4;break; //4
- case 0xd0: num=5;break; //5
- case 0xb0: num=6;break; //6
- case 0x70: num=7;break; //减—
- while(P1!=0xfd);
- if(num==4||num==5||num==6)
- //led=1;
- a=a*10+dat1[num];
- else
- //led=1;
- b=b*10+dat1[num];
- else
- flag=1;
- fuhao=2;//带表减号
- P1=0xfb; //令第三行为0,判断哪一列按下
- if(P1!=0xfb)
- delay(1000);
- if(P1!=0xfb)
- key=P1&0xf0;
- switch(key)
- case 0xe0: num=8;break; //7
- case 0xd0: num=9;break; //8
- case 0xb0: num=10;break; //9
- case 0x70: num=11;break; //乘*
- while(P1!=0xfb);
- if(num==8||num==9||num==10)
- //led=1;
- a=a*10+dat1[num];
- else
- //led=1;
- b=b*10+dat1[num];
- else
- flag=1;
- fuhao=3;//带表乘号*
- P1=0xf7; //令第四行为0,判断哪一列按下
- if(P1!=0xf7)
- delay(1000);
- if(P1!=0xf7)
- key=P1&0xf0;
- switch(key)
- case 0xe0: num=12;break; //0
- case 0xd0: num=13;break; //清除rst
- case 0xb0: num=14;break; //等号=
- case 0x70: num=15;break; //除/
- while(P1!=0xf7);
- switch(num)
- case 12:
- //led=1;
- a=a*10+dat1[num];
- lcdwrd(0x30);
- else
- //led=1;
- b=b*10+dat1[num];
- lcdwrd(0x30);
- break;
- case 13:
- lcdwrc(0x01); //清屏指令
- a=0;
- b=0;
- flag=0;
- fuhao=0;
- break;
- case 15:
- flag=1;
- fuhao=4;
- lcdwrd(0x2f);//除号/
- break;
- case 14:
- if(fuhao==1)//加
- lcdwrc(0x4f+0x80);
- lcdwrc(0x04);//设置光标左移,屏幕不移动
- c=a+b;
- while(c!=0) //一位一位显示
- lcdwrd(0x30+c%10);//显示结果的最后一位在0x4f的位置
- c=c/10;//取前面的结果数据
- lcdwrd(0x3d); //显示等于号=
- a=0;
- b=0;
- flag=0;
- fuhao=0;//全部清除为0
- if(fuhao==2) //减
- if(a>b)
- c=a-b;
- else
- c=b-a;
- c=c/10;//取前面的结果数据
- if(a<b) lcdwrd(0x2d); //显示-号
- a=0;
- b=0;
- flag=0;
- fuhao=0;//全部清除为0
- if(fuhao==3)//乘法
- c=a*b;
- c=c/10;//取前面的结果数据
- a=0;
- b=0;
- flag=0;
- fuhao=0;//全部清除为0
- if(fuhao==3)//乘法
- c=a*b;
- c=c/10;//取前面的结果数据
- a=0;
- b=0;
- flag=0;
- fuhao=0;//全部清除为0
- if(fuhao==4)
- k=0;
- c=(long)(((float)a/b)*1000);//强制转换为long。
- k++;
- c=c/10;//取前面的结果数据
- if(k==3)
- lcdwrd(0x2e);
- k=0;
- if(a/b<0) //如果a比b小的话那么除的结果最高位是0
- lcdwrd(0x30);
- lcdwrd(0x3d); //显示等号
- a=0;
- b=0;
- flag=0;
- fuhao=0;//全部清除为0
- break;
- void main()
- lcdinit();
- while(1)
- keyscan();
复制代码 |
