查看: 2532|回复: 0
为什么用按键控制mode=1时,定时器不能工作?smgdata没有改变那,为什么呢?
ID:77398 发表于 2015-5-17 21:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
#include <stdlib.h> //°üo¬rand()Ëæ»úoˉêyμÄí·Îļt
#include "DS18B20.H"
//o궨òå
#define N  2
#define wenduh 3000 //±¨¾ˉζ跶Χé趨
#define wendul 0
//붨òå
sbit k1=P1^1; //ὸö°′Å¥¶¨òå  P1^0òѾ-±»DS18b20Õ¼óÃ
sbit k2=P1^2;
sbit Rlight=P1^7;
sbit Glight=P1^6;
sbit Ylight=P1^5;
sbit speaker=P2^3;
sbit E=P3^4;
sbit F=P3^5;
sbit G=P3^7;
sbit H=P3^6;
char mode=0;  //Ä£ê½ÇD»»±äá¿
unsigned int num;
unsigned int smgdata=0;
unsigned int code SMG[20]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,
                                 0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10};
void delay(uint z)
        int x,y;
        for(x=115;x>0;x--)
                for(y=z;y>0;y--);
void shortdelay(unsigned int z)
        unsigned int x,y;
        for(x=z;x>0;x--)
                for(y=10;y>0;y--);
void kdeal()
        if((k1==0)&&(k2==1))
                delay(3);
                        mode++;
            if(mode==3)
                    mode=0;
void display(int a,int b,int c,int d)
        P0=SMG[a]; E=0;shortdelay(15);E=1;
        P0=SMG[b]; F=0;shortdelay(15);F=1;
        P0=SMG[c]; G=0;shortdelay(15);G=1;
        P0=SMG[d]; H=0;shortdelay(15);H=1;
void temperaturedatasolve(unsigned int temp)
        unsigned int x,a,b,c,d;
        x=temp/10000;
        a=temp/10000;
        b=temp/1000-a*10;
        c=temp/100-a*100-b*10;
        d=temp/10-a*1000-b*100-c*10;
        display(a,b,c+10,d);
void SMGdhdatasolve(unsigned int shijian)
        int qian,bai,shi,ge; char i;
        for(i=0;i<4;i++)
          qian=shijian/1000; P0=SMG[qian]; E=0; shortdelay(10); E=1;
                bai=shijian%1000/100; P0=SMG[bai]; F=0; shortdelay(10); F=1;
                shi=shijian%100/10; P0=SMG[shi]; G=0; shortdelay(10); G=1;
                ge=shijian%10; P0=SMG[ge]; H=0; shortdelay(10); H=1;
        unsigned int count=0;
        unsigned int wendu;
        TMOD=0x10; EA=1; ET1=1;
                TH1=(65536-45872)/256;
                kdeal();
                if(mode==0)
                        wendu=ReadTemperature();
                        temperaturedatasolve(wendu);
                        if((wendu<wendul)||(wendu>wenduh))
                                TR1=1;
                                if((num%10)==0)
                                        count++;
                                        if(count==5)
                                                Rlight=~Rlight;
                                                speaker=~speaker;
                                        if(count==10)
                                                count=0;
                                                Rlight=~Rlight;
                                                speaker=~speaker;
                                Rlight=1;
                                speaker=1;
                if(mode==1)
       TR1=1;
                        SMGdhdatasolve(smgdata);
void T1_time() interrupt 3
        TL1=(65536-45872)%256;
        num++;
        if((num%20)==0)
                smgdata++;
