参照济南市日出日落时刻表。
小ARM菜菜
2013年4月20日
日照高科园
济南市日出日落时刻表,参考百度www.baidu.com
TYP_Sunrise_set_tab code Sunrise_set_map[12]=
7,25,17,7,
7,25,17,16,
7,22,17,26,
7,15,17,37,
7,5,17,48,
6,54,17,58,
6,44,18,6,
6,3,18,16,
6,15,18,24,
5,59,18,34,
5,45,18,43,
5,31,18,51,
5,19,19,0,
5,9,19,9,
5,1,19,17,
4,55,19,25,
4,53,19,31,
4,53,19,34,
4,57,19,35,
5,2,19,33,
5,9,19,28,
5,17,19,19,
5,26,19,8,
5,34,18,56,
5,43,18,41,
5,51,18,26,
5,59,18,11,
6,7,17,56,
6,15,17,42,
6,25,17,29,
6,35,17,16,
6,45,17,6,
6,56,17,0,
7,5,16,56,
7,14,16,56,
7,21,17,0,
时间调度
uint8_t Day(uint8_t hour,uint8_t minute,uint8_t month,uint8_t day)
month-=1;
//0-12点
if(( 0<=hour)&&(hour<=12 ))
if(hour>Sunrise_set_map[month].Sunrise_Sunset_time[day].Sunrise.hour)
{ //当前时间大于日出小时
return 0; //关灯
if(hour==Sunrise_set_map[month].Sunrise_Sunset_time[day].Sunrise.hour)
//当前时间和日出小时相等要判定分钟
if(minute>=Sunrise_set_map[month].Sunrise_Sunset_time[day].Sunrise.minute)
//当前分钟超出日出分钟或相等,那么
return 0; //关灯
return 1;//开灯
return 1;
//13点到无穷大呵呵怎么可能嫩
if((12<hour)){
if(hour>Sunrise_set_map[month].Sunrise_Sunset_time[day].Sunset.hour)
{ //当前时间大于落小时
return 1;//开灯
if(hour==Sunrise_set_map[month].Sunrise_Sunset_time[day].Sunset.hour)
//当前时间和日落小时相等要判定分钟
if(minute>=Sunrise_set_map[month].Sunrise_Sunset_time[day].Sunset.minute)
//当前分钟超出日落分钟或相等,那么
return 1; //开灯
return 0;//关灯
return 0;
return 0xfa; //异常情况
uint8_t CHCK(uint8_t month,uint8_t hour,uint8_t minute,uint8_t day )
if((1<=day)&&(day<=11))
return Day(hour,minute,month,0);
} /*如果是1号到11号*/
if ((11<day)&&(day<=21))
return Day(hour,minute,month,1);
}/*如果是11号到21号*/
return Day(hour,minute,month,2);
} /*其他*/
uint8_t Process_cal_scheduling_information(unsigned char month,unsigned char day,unsigned char hour ,unsigned char minute )
switch (month)
case 1:{
return CHCK(month,hour, minute,day );
break;}
case 2:{
break;}
case 3:{
break;}
case 4:{
break;}
case 5:{
break;}
case 6:{
break;}
case 7:{
break;}
case 8:{
break;}
case 9:{
break;}
case 10:{
break;}
case 11:{
break;}
case 12:{
break;}
unsigned char DecimaltoBcd(unsigned char Decimal )
uint8_t l,m;
m= Decimal/10;
l=Decimal%10;
m=(m&0x0f)<<4;
return (m+l);
unsigned char BcdtoDecimal(unsigned char bcd)
uint8_t l,m;
l=(bcd&0x0f);
m=(bcd&0xf0)>>4;
return ((m*10)+l);
时刻调度法调度器
unsigned char Timetable_scheduling_switch_lights()
uint8_t xdata year,month,day,week,hour,minute,second,l,m;
year = Read_RTC_Data(Year_Register);
month = Read_RTC_Data(Month_Register);
day = Read_RTC_Data(Day_Register );
week = Read_RTC_Data(Week_Register); //lode new time
hour = Read_RTC_Data(Hour_Register);
minute = Read_RTC_Data(Minute_Register);
second = Read_RTC_Data(Second_Register);
l= hour ;
m= minute;
month=BcdtoDecimal(month);
day=BcdtoDecimal(day);
hour=BcdtoDecimal(hour);
minute=BcdtoDecimal(minute);
// SendOneByte(month) ;
// SendOneByte(day) ;
SendOneByte(((l&0xf0)>>4)+0x30 );
SendOneByte((l&0x0f)+0x30) ;
SendOneByte(0x3a) ;
SendOneByte(((m&0xf0)>>4)+0x30) ;
SendOneByte((m&0x0f)+0x30) ;
return Process_cal_scheduling_information(month,day,hour,minute );
void printf_time()
SendOneByte(Read_RTC_Data(Year_Register));
SendOneByte(Read_RTC_Data(Month_Register));
SendOneByte(Read_RTC_Data(Day_Register ));
SendOneByte(Read_RTC_Data(Week_Register));
SendOneByte(Read_RTC_Data(Hour_Register));
SendOneByte(Read_RTC_Data(Minute_Register));
SendOneByte(Read_RTC_Data(Second_Register));
void Write_RTC( uint8_t Year,uint8_t Month,uint8_t Day,uint8_t Hour,uint8_t Minute,uint8_t Second,uint8_t Week)
EXT_CTRL= EXT_CTRL|0x80;
//关闭写保护 ]
Year = DecimaltoBcd(Year ) ;
Month = DecimaltoBcd(Month ) ;
Day = DecimaltoBcd(Day ) ;
Hour = DecimaltoBcd(Hour ) ;
Minute = DecimaltoBcd(Minute ) ;
Second = DecimaltoBcd(Second ) ;
Week = DecimaltoBcd(Week ) ;
EXT_ADR = Write_Protect_Register;
EXT_DAT = 0xff;
EXT_ADR = Time_Adjust_Register;
EXT_DAT = 0;
//日期
EXT_ADR = Year_Register;
EXT_DAT = Year;
EXT_ADR = Month_Register;
EXT_DAT = Month;
EXT_ADR = Day_Register;
EXT_DAT = Day;
EXT_ADR = Week_Register;
EXT_DAT = Week;
//时间
EXT_ADR = Hour_Register;
EXT_DAT = Hour;
EXT_ADR = Minute_Register;
EXT_DAT = Minute;
EXT_ADR = Second_Register;
EXT_DAT = Second;
//写保护
EXT_DAT = 0;
//读取RTC数据
uint8_t Read_RTC_Data(uint8_t addr)
uint8_t temp=0;
EXT_ADR = addr;
temp=EXT_DAT;
return temp;
