查看: 31919|回复: 3
STC15F104E.H头文件下载 引脚图 管脚定义封装及中文资料
STC15F104E引脚图 各种封装图的管脚定义如下:
STC15F104E.H头文件下载 :http://www.51hei.com/bbs/dpj-36960-1.html
  STC15F104E头文件内容预览
  1. #ifndef __STC15F104E_H_
  2. #define __STC15F104E_H_
  3. /////////////////////////////////////////////////
  4. //包含本头文件后,不用另外再包含"REG51.H"
  5. //内核特殊功能寄存器        // 复位值   描述
  6. sfr ACC         =   0xE0;   //0000,0000 累加器Accumulator
  7. sfr B           =   0xF0;   //0000,0000 B寄存器
  8. sfr PSW         =   0xD0;   //0000,0000 程序状态字
  9. sbit CY         =   PSW^7;
  10. sbit AC         =   PSW^6;
  11. sbit F0         =   PSW^5;
  12. sbit RS1        =   PSW^4;
  13. sbit RS0        =   PSW^3;
  14. sbit OV         =   PSW^2;
  15. sbit P          =   PSW^0;
  16. sfr SP          =   0x81;   //0000,0111 堆栈指针
  17. sfr DPL         =   0x82;   //0000,0000 数据指针低字节
  18. sfr DPH         =   0x83;   //0000,0000 数据指针高字节
  19. //I/O 口特殊功能寄存器
  20. sfr P0          =   0x80;   //1111,1111 端口0
  21. sbit P00        =   P0^0;
  22. sbit P01        =   P0^1;
  23. sbit P02        =   P0^2;
  24. sbit P03        =   P0^3;
  25. sbit P04        =   P0^4;
  26. sbit P05        =   P0^5;
  27. sbit P06        =   P0^6;
  28. sbit P07        =   P0^7;
  29. sfr P1          =   0x90;   //1111,1111 端口1
  30. sbit P10        =   P1^0;
  31. sbit P11        =   P1^1;
  32. sbit P12        =   P1^2;
  33. sbit P13        =   P1^3;
  34. sbit P14        =   P1^4;
  35. sbit P15        =   P1^5;
  36. sbit P16        =   P1^6;
  37. sbit P17        =   P1^7;
  38. sfr P2          =   0xA0;   //1111,1111 端口2
  39. sbit P20        =   P2^0;
  40. sbit P21        =   P2^1;
  41. sbit P22        =   P2^2;
  42. sbit P23        =   P2^3;
  43. sbit P24        =   P2^4;
  44. sbit P25        =   P2^5;
  45. sbit P26        =   P2^6;
  46. sbit P27        =   P2^7;
  47. sfr P3          =   0xB0;   //1111,1111 端口3
  48. sbit P30        =   P3^0;
  49. sbit P31        =   P3^1;
  50. sbit P32        =   P3^2;
  51. sbit P33        =   P3^3;
  52. sbit P34        =   P3^4;
  53. sbit P35        =   P3^5;
  54. sbit P36        =   P3^6;
  55. sbit P37        =   P3^7;
  56. sfr P4          =   0xC0;   //1111,1111 端口4
  57. sbit P40        =   P4^0;
  58. sbit P41        =   P4^1;
  59. sbit P42        =   P4^2;
  60. sbit P43        =   P4^3;
  61. sbit P44        =   P4^4;
  62. sbit P45        =   P4^5;
  63. sbit P46        =   P4^6;
  64. sbit P47        =   P4^7;
  65. sfr P5          =   0xC8;   //xxxx,1111 端口5
  66. sbit P50        =   P5^0;
  67. sbit P51        =   P5^1;
  68. sbit P52        =   P5^2;
  69. sbit P53        =   P5^3;
  70. sbit P54        =   P5^4;
  71. sbit P55        =   P5^5;
  72. sbit P56        =   P5^6;
  73. sbit P57        =   P5^7;
  74. sfr P6          =   0xE8;   //0000,0000 端口6
  75. sbit P60        =   P6^0;
  76. sbit P61        =   P6^1;
  77. sbit P62        =   P6^2;
  78. sbit P63        =   P6^3;
  79. sbit P64        =   P6^4;
  80. sbit P65        =   P6^5;
  81. sbit P66        =   P6^6;
  82. sbit P67        =   P6^7;
  83. sfr P7          =   0xF8;   //0000,0000 端口7
  84. sbit P70        =   P7^0;
  85. sbit P71        =   P7^1;
  86. sbit P72        =   P7^2;
  87. sbit P73        =   P7^3;
  88. sbit P74        =   P7^4;
  89. sbit P75        =   P7^5;
  90. sbit P76        =   P7^6;
  91. sbit P77        =   P7^7;
  92. sfr P0M0        =   0x94;   //0000,0000 端口0模式寄存器0
  93. sfr P0M1        =   0x93;   //0000,0000 端口0模式寄存器1
  94. sfr P1M0        =   0x92;   //0000,0000 端口1模式寄存器0
  95. sfr P1M1        =   0x91;   //0000,0000 端口1模式寄存器1
  96. sfr P2M0        =   0x96;   //0000,0000 端口2模式寄存器0
  97. sfr P2M1        =   0x95;   //0000,0000 端口2模式寄存器1
  98. sfr P3M0        =   0xB2;   //0000,0000 端口3模式寄存器0
  99. sfr P3M1        =   0xB1;   //0000,0000 端口3模式寄存器1
  100. sfr P4M0        =   0xB4;   //0000,0000 端口4模式寄存器0
  101. sfr P4M1        =   0xB3;   //0000,0000 端口4模式寄存器1
  102. sfr P5M0        =   0xCA;   //0000,0000 端口5模式寄存器0
  103. sfr P5M1        =   0xC9;   //0000,0000 端口5模式寄存器1
  104. sfr P6M0        =   0xCC;   //0000,0000 端口6模式寄存器0
  105. sfr P6M1        =   0xCB;   //0000,0000 端口6模式寄存器1
  106. sfr P7M0        =   0xE2;   //0000,0000 端口7模式寄存器0
  107. sfr P7M1        =   0xE1;   //0000,0000 端口7模式寄存器1
  108. //系统管理特殊功能寄存器
  109. sfr PCON        =   0x87;   //0001,0000 电源控制寄存器
  110. sfr AUXR        =   0x8E;   //0000,0000 辅助寄存器
  111. sfr AUXR1       =   0xA2;   //0000,0000 辅助寄存器1
  112. sfr P_SW1       =   0xA2;   //0000,0000 外设端口切换寄存器1
  113. sfr CLK_DIV     =   0x97;   //xxxx,x000 时钟分频控制寄存器
  114. sfr BUS_SPEED   =   0xA1;   //xx10,x011 总线速度控制寄存器
  115. sfr P1ASF       =   0x9D;   //0000,0000 端口1模拟功能配置寄存器
  116. sfr P_SW2       =   0xBA;   //0000,0000 外设端口切换寄存器
  117. sfr IRC_CLKO    =   0xBB;   //0000,0000 内部振荡器时钟输出控制寄存器
  118. //中断特殊功能寄存器
  119. sfr IE          =   0xA8;   //0000,0000 中断控制寄存器
  120. sbit EA         =   IE^7;
  121. sbit ELVD       =   IE^6;
  122. sbit EADC       =   IE^5;
  123. sbit ES         =   IE^4;
  124. sbit ET1        =   IE^3;
  125. sbit EX1        =   IE^2;
  126. sbit ET0        =   IE^1;
  127. sbit EX0        =   IE^0;
  128. sfr IP          =   0xB8;   //0000,0000 中断优先级寄存器
  129. sbit PPCA       =   IP^7;
  130. sbit PLVD       =   IP^6;
  131. sbit PADC       =   IP^5;
  132. sbit PS         =   IP^4;
  133. sbit PT1        =   IP^3;
  134. sbit PX1        =   IP^2;
  135. sbit PT0        =   IP^1;
  136. sbit PX0        =   IP^0;
  137. sfr IE2         =   0xAF;   //0000,0000 中断控制寄存器2
  138. sfr IP2         =   0xB5;   //xxxx,xx00 中断优先级寄存器2
  139. sfr INT_CLKO    =   0x8F;   //0000,0000 外部中断与时钟输出控制寄存器
  140. //定时器特殊功能寄存器
  141. sfr TCON        =   0x88;   //0000,0000 T0/T1控制寄存器
  142. sbit TF1        =   TCON^7;
  143. sbit TR1        =   TCON^6;
  144. sbit TF0        =   TCON^5;
  145. sbit TR0        =   TCON^4;
  146. sbit IE1        =   TCON^3;
  147. sbit IT1        =   TCON^2;
  148. sbit IE0        =   TCON^1;
  149. sbit IT0        =   TCON^0;
  150. sfr TMOD        =   0x89;   //0000,0000 T0/T1模式寄存器
  151. sfr TL0         =   0x8A;   //0000,0000 T0低字节
  152. sfr TL1         =   0x8B;   //0000,0000 T1低字节
  153. sfr TH0         =   0x8C;   //0000,0000 T0高字节
  154. sfr TH1         =   0x8D;   //0000,0000 T1高字节
  155. sfr T4T3M       =   0xD1;   //0000,0000 T3/T4模式寄存器
  156. sfr T3T4M       =   0xD1;   //0000,0000 T3/T4模式寄存器
  157. sfr T4H         =   0xD2;   //0000,0000 T4高字节
  158. sfr T4L         =   0xD3;   //0000,0000 T4低字节
  159. sfr T3H         =   0xD4;   //0000,0000 T3高字节
  160. sfr T3L         =   0xD5;   //0000,0000 T3低字节
  161. sfr T2H         =   0xD6;   //0000,0000 T2高字节
  162. sfr T2L         =   0xD7;   //0000,0000 T2低字节
  163. sfr WKTCL       =   0xAA;   //0000,0000 掉电唤醒定时器低字节
  164. sfr WKTCH       =   0xAB;   //0000,0000 掉电唤醒定时器高字节
  165. sfr WDT_CONTR   =   0xC1;   //0000,0000 看门狗控制寄存器
  166. //串行口特殊功能寄存器
  167. sfr SCON        =   0x98;   //0000,0000 串口1控制寄存器
  168. sbit SM0        =   SCON^7;
  169. sbit SM1        =   SCON^6;
  170. sbit SM2        =   SCON^5;
  171. sbit REN        =   SCON^4;
  172. sbit TB8        =   SCON^3;
  173. sbit RB8        =   SCON^2;
  174. sbit TI         =   SCON^1;
  175. sbit RI         =   SCON^0;
  176. sfr SBUF        =   0x99;   //xxxx,xxxx 串口1数据寄存器
  177. sfr S2CON       =   0x9A;   //0000,0000 串口2控制寄存器
  178. sfr S2BUF       =   0x9B;   //xxxx,xxxx 串口2数据寄存器
  179. sfr S3CON       =   0xAC;   //0000,0000 串口3控制寄存器
  180. sfr S3BUF       =   0xAD;   //xxxx,xxxx 串口3数据寄存器
  181. sfr S4CON       =   0x84;   //0000,0000 串口4控制寄存器
  182. sfr S4BUF       =   0x85;   //xxxx,xxxx 串口4数据寄存器
  183. sfr SADDR       =   0xA9;   //0000,0000 从机地址寄存器
  184. sfr SADEN       =   0xB9;   //0000,0000 从机地址屏蔽寄存器
  185. //ADC 特殊功能寄存器
  186. sfr ADC_CONTR   =   0xBC;   //0000,0000 A/D转换控制寄存器
  187. sfr ADC_RES     =   0xBD;   //0000,0000 A/D转换结果高8位
  188. sfr ADC_RESL    =   0xBE;   //0000,0000 A/D转换结果低2位
  189. //SPI 特殊功能寄存器
  190. sfr SPSTAT      =   0xCD;   //00xx,xxxx SPI状态寄存器
  191. sfr SPCTL       =   0xCE;   //0000,0100 SPI控制寄存器
  192. sfr SPDAT       =   0xCF;   //0000,0000 SPI数据寄存器
  193. //IAP/ISP 特殊功能寄存器
  194. sfr IAP_DATA    =   0xC2;   //0000,0000 EEPROM数据寄存器
  195. sfr IAP_ADDRH   =   0xC3;   //0000,0000 EEPROM地址高字节
  196. sfr IAP_ADDRL   =   0xC4;   //0000,0000 EEPROM地址第字节
  197. sfr IAP_CMD     =   0xC5;   //xxxx,xx00 EEPROM命令寄存器
  198. sfr IAP_TRIG    =   0xC6;   //0000,0000 EEPRPM命令触发寄存器
  199. sfr IAP_CONTR   =   0xC7;   //0000,x000 EEPROM控制寄存器
  200. //PCA/PWM 特殊功能寄存器
  201. sfr CCON        =   0xD8;   //00xx,xx00 PCA控制寄存器
  202. sbit CF         =   CCON^7;
  203. sbit CR         =   CCON^6;
  204. sbit CCF2       =   CCON^2;
  205. sbit CCF1       =   CCON^1;
  206. sbit CCF0       =   CCON^0;
  207. sfr CMOD        =   0xD9;   //0xxx,x000 PCA 工作模式寄存器
  208. sfr CL          =   0xE9;   //0000,0000 PCA计数器低字节
  209. sfr CH          =   0xF9;   //0000,0000 PCA计数器高字节
  210. sfr CCAPM0      =   0xDA;   //0000,0000 PCA模块0的PWM寄存器
  211. sfr CCAPM1      =   0xDB;   //0000,0000 PCA模块1的PWM寄存器
  212. sfr CCAPM2      =   0xDC;   //0000,0000 PCA模块2的PWM 寄存器
  213. sfr CCAP0L      =   0xEA;   //0000,0000 PCA模块0的捕捉/比较寄存器低字节
  214. sfr CCAP1L      =   0xEB;   //0000,0000 PCA模块1的捕捉/比较寄存器低字节
  215. sfr CCAP2L      =   0xEC;   //0000,0000 PCA模块2的捕捉/比较寄存器低字节
  216. sfr PCA_PWM0    =   0xF2;   //xxxx,xx00 PCA模块0的PWM寄存器
  217. sfr PCA_PWM1    =   0xF3;   //xxxx,xx00 PCA模块1的PWM寄存器
  218. sfr PCA_PWM2    =   0xF4;   //xxxx,xx00 PCA模块1的PWM寄存器
  219. sfr CCAP0H      =   0xFA;   //0000,0000 PCA模块0的捕捉/比较寄存器高字节
  220. sfr CCAP1H      =   0xFB;   //0000,0000 PCA模块1的捕捉/比较寄存器高字节
  221. sfr CCAP2H      =   0xFC;   //0000,0000 PCA模块2的捕捉/比较寄存器高字节
  222. /////////////////////////////////////////////////
  223. #endif
STC15F104E中文资料下载链接: STC15F100中文资料.rar (197 Bytes, 下载次数: 165)
收藏收藏2 分享淘帖 顶 踩
ID:129869 发表于 2016-7-25 13:46 | 只看该作者
资料 下载的网页 怎么打不开啊
ID:183332 发表于 2017-3-25 16:25 | 只看该作者
下载不了
ID:216180 发表于 2017-7-16 20:56 | 只看该作者
坑................................
