本人最近在用UBW32开发板,里面是PIC32MX795。 我自己写了一个测试AD模块的程序。大体思想就是想通过函数发生器所发出的方波来控制LED的闪烁。从而实现测试AD转换是否运行正常,大体就是给1就亮,给0就不亮。然而我在运行程序时LED却一直亮。没有出现随着方波频率变化的情况。我用的是2.2HZ接近3.3V的方波。总之我的程序如下。本人菜鸟一枚,各位大神如有懂得请帮我指一条明路!跪谢!!/*
** ADCLib.c
// configuration bit settings, Fcy=72MHz, Fpb=36MHz
#pragma config POSCMOD=XT, FNOSC=PRIPLL
#pragma config FPLLIDIV=DIV_2, FPLLMUL=MUL_18, FPLLODIV=DIV_1
#pragma config FPBDIV=DIV_2, FWDTEN=OFF, CP=OFF, BWP=OFF
#include <p32xxxx.h>
#define POT 5 // 10k potentiometer on AN5 input
#define AINPUTS 0xffdf // Analog inputs for POT
// initilaize the ADC for single conversion, select input pins
void initADC( int amask)
AD1PCFG = amask; // select analog input pins
AD1CON1 = 0x00E0; // auto convert after end of sampling
AD1CSSL = 0; // no scanning required
AD1CON2 = 0; // use MUXA, AVss/AVdd used as Vref+/-
AD1CON3 = 0x1F3F; // max sample thime = 31Tad
AD1CON1SET = 0x8000; // turn on the ADC
} //initADC
int readADC( int ch)
AD1CHSbits.CH0SA = ch; // select analog input channel
AD1CON1bits.SAMP = 1; // start sampling
while (!AD1CON1bits.DONE); // wait to complete conversion
return ADC1BUF0; // read the conversion result
} // readADC
main()
DDPCONbits.JTAGEN=0;
TRISB=0x0020;
initADC( AINPUTS);
int a;
a=readADC( POT);
TRISE=0x0000; //PORTE pins are output,and connected to
while( 1)
PORTE=a;
