给你个程序你研究,其实论坛里很多程序你怎么不找- /******************************************************
- 功能 :二组2位数码管分别显示1秒加一和减一
- 单片机:STC12C5A60S2
- 晶振 :11.0582M
- 作者 :苏义江
- 时间 :2016-1-2
- 注释 :在大数码管实验板实验通过,用定时器0定时
- #include <reg52.h>
- //#include <intrins.h>
- sbit wei= P0^6; //
- sbit duan = P0^7; //
- #define uchar unsigned char
- #define uint unsigned int
- uchar code table1[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,
- 0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xBF};//共阳LED段码表
- uchar code table[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf};//位码
- uchar t,a,b,c,d,shi=90,ge=0;//定义变量
- void delay(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=610;y>0;y--);
- void init()//定时器0初始化
- TMOD=0X01;
- TH0=0X4C;//11.0592M 50ms初值
- TL0=0X00;
- ET0=1;
- TR0=1;
- EA=1;
- t=0;//计数初始为0
- void display()//显示函数
- a=ge/10;
- b=ge%10;
- c=shi/10;
- d=shi%10;
- wei=1;
- P2=0xfe;
- wei=0;
- duan=1;
- P2=table1[a];
- duan=0;
- delay(5);
- P2=0xff;
- wei=1;
- P2=0xfd;
- wei=0;
- duan=1;
- P2=table1[b];
- duan=0;
- delay(5);
- P2=0xff;
- wei=1;
- P2=0xfb;
- wei=0;
- duan=1;
- P2=table1[c];
- duan=0;
- delay(5);
- P2=0xff;
- wei=1;
- P2=0xf7;
- wei=0;
- duan=1;
- P2=table1[d];
- duan=0;
- delay(5);
- P2=0xff;
- void main()
- init();
- while(1)
- display();
- void t0() interrupt 1//定时器0中断服务函数
- TH0=0X4C;
- TL0=0X00;
- t++;
- if(t==20)//1秒到
- t=0;//计数清零
- ge++;
- shi--;
- if(ge==90)
- ge=0;
- if(shi==0)
- shi=90;
复制代码 |
