黑块是一闪一闪的,下面是我的程序
#include<intrins.h>
#include<AT89X52.H>
uchar code digit[]={"0123456789"}; //定义字符数组显示数字
uchar code Error[]="Error!Check!"; //说明没有检测到DS18B20
uchar code table[]="Alarm Clock";
uchar code table1[]="0123456789";
uchar code table2[]="WEEK";
uchar code table3[]="Today is fine!";
uchar code table4[]="HELLO!";
uchar code table5[]="Made by Kaili";
uchar code table6[]="Happy new year!!";//1.1
//uchar code table7[]="Valentine's Day"; //2.14
以下是对液晶模块的操作程序
sbit RS=P2^5; //寄存器选择位,将RS位定义为P2.0引脚
sbit RW=P2^6; //读写选择位,将RW位定义为P2.1引脚
sbit E=P2^7; //使能信号位,将E位定义为P2.2引脚
sbit BF=P0^7; //忙碌标志位,,将BF位定义为P0.7引脚
sbit ceshi=P1^0;
sbit T_RST=P1^6;
sbit T_CLK=P1^4;
sbit T_IO=P1^5;
sbit beep=P1^7;
sbit key1=P3^0; //调闹钟的小时即x
sbit key2=P3^1; //调闹钟的分钟即y
sbit key4=P3^5; //显示切换
sbit key3=P3^2;
sbit ACC0=ACC^0;
sbit ACC7=ACC^7;
sbit io=P1^1;
uchar time; //设置全局变量,专门用于严格延时
static uchar x=0x08,y=30;
uchar t_sec,sec1,sec2;
uchar t_min,min1,min2;
uchar t_hour,hour1,hour2;
uchar t_mon,mon1,mon2;
uchar t_day,day1,day2;
uchar t_year,year1,year2;
uchar week,week1;
uchar com,inf;
/*定义变量*/
uchar data_byte=0,count,SHISHI,SHIGE,WENSHI,WENGE;
uint TH_data,TL_data,RH_data,RL_data,CK_data;
uint TH_temp,TL_temp,RH_temp,RL_temp,CK_temp;
uchar num;
/*10微妙延时程序*/
void delay1()
unsigned char i;
for(i=0; i<3; i++);
函数功能:延时若干微秒
入口参数:n
void delaynus(unsigned char n)
unsigned char i;
for(i=0;i<n;i++)
函数功能:延时1ms
(3j+2)*i=(3×33+2)×10=1010(微秒),可以认为是1毫秒
void delay1ms()
uchar i,j;
for(i=0;i<10;i++)
for(j=0;j<33;j++)
函数功能:延时若干毫秒
入口参数:n
void delaynms(uchar n)
uchar i;
for(i=0;i<n;i++)
delay1ms();
/**********************DHT11模块**********************/
uchar receive_byte()//接收一个字节
uchar i,temp;
for(i=0;i<8; i++)
count = 2;
while((!io)&&count++)//等待50us低电平结束并防止死循环
temp = 0;
delay1();
delay1();
delay1();
if (io==1)
temp = 1;
count = 2;
while(io && count++);
temp = 0;
data_byte<<=1;
data_byte|=temp;
return (data_byte);
/*DHT11开始函数*/
void read_io()//开始信号读数据并校验
io = 0;
delaynms(18);//主机拉低18ms
io=1;//DATA总线由上拉电阻拉高 主机延时20us
delay1();
delay1();
delay1();
delay1();
io = 1;//主机设置为输入高电平判断从机响应信号
if(!io)
count = 2;
while((!io)&&count++);//判断DHT11发出80us低电平响应信号是否结束
count = 2;
while(io && count++);//判断DHT11拉高总线80us高电平是否结束
RH_temp = receive_byte();
RL_temp = receive_byte();
TH_temp = receive_byte();
TL_temp = receive_byte();
CK_temp = receive_byte();
io = 1;
num = (RH_temp+RL_temp+TH_temp+TL_temp);//数据校验
if(num==CK_temp)
RH_data=RH_temp;
RL_data=RL_temp;
TH_data=TH_temp;
TL_data=TL_temp;
CK_data=CK_temp;
//湿度整数部分
SHISHI = RH_data/10;
SHIGE = RH_data%10;
//温度整数部分
WENSHI =(char) TH_data/10;
WENGE = (char) TH_data%10;
函数功能:判断液晶模块的忙碌状态
返回值:result。result=1,忙碌;result=0,不忙
bit BusyTest(void)
bit result;
RS=0; //根据规定,RS为低电平,RW为高电平时,可以读状态
RW=1;
E=1; //E=1,才允许读写
_nop_(); //空操作
_nop_();
_nop_();
_nop_(); //空操作四个机器周期,给硬件反应时间
delaynms(5);
result=BF; //将忙碌标志电平赋给result
E=0; //将E恢复低电平
return result;
函数功能:将模式设置指令或显示地址写入液晶模块
入口参数:dictate
void WriteInstruction (uchar dictate)
while(BusyTest()==1); //如果忙就等待
P0=dictate; //将数据送入P0口,即写入指令或地址
RS=0; //根据规定,RS和R/W同时为低电平时,可以写入指令
RW=0;
E=0; //E置低电平(根据表8-6,写指令时,E为高脉冲,
// 就是让E从0到1发生正跳变,所以应先置"0"
delaynms(5);
_nop_();
_nop_(); //空操作两个机器周期,给硬件反应时间
_nop_();
_nop_();
_nop_();
delaynms(5);
E=1; //E置高电平
_nop_();
_nop_();
_nop_();
delaynms(5);
E=0; //当E由高电平跳变成低电平时,液晶模块开始执行命令
delay1ms();
函数功能:指定字符显示的实际地址
入口参数:x
void WriteAddress(unsigned char x)
WriteInstruction(x|0x80); //显示位置的确定方法规定为"80H+地址码x"
函数功能:将数据(字符的标准ASCII码)写入液晶模块
入口参数:y(为字符常量)
void WriteData(uchar y)
P0=y; //将数据送入P0口,即将数据写入液晶模块
RS=1; //RS为高电平,RW为低电平时,可以写入数据
RW=0;
delaynms(5);
delaynms(5);
_nop_();
_nop_();
_nop_();
delaynms(5);
E=1; //E置高电平
_nop_();
_nop_();
_nop_();
函数功能:对LCD的显示模式进行初始化设置
void LcdInitiate(void)
delaynms(15); //延时15ms,首次写指令时应给LCD一段较长的反应时间
WriteInstruction(0x38); //显示模式设置:16×2显示,5×7点阵,8位数据接口
delaynms(5); //延时5ms ,给硬件一点反应时间
WriteInstruction(0x38); //连续三次,确保初始化成功
WriteInstruction(0x0c); //显示模式设置:显示开,无光标,光标不闪烁
WriteInstruction(0x06); //显示模式设置:光标右移,字符不移
WriteInstruction(0x01); //清屏幕指令,将以前的显示内容清除
void write_com(uchar com)//向1602写指令
P0=com;
delaynms(5);
RS=0;
RW=0;
delaynms(5);
delaynms(10);
E=1;
delaynms(10);
E=0;
函数功能:显示温度的小数点
void display_dot(void)
WriteAddress(0x80+0x40+0x03); //写显示地址,将在第2行第10列开始显示
WriteData('.'); //将小数点的字符常量写入LCD
delaynms(50); //延时1ms给硬件一点反应时间
函数功能:显示温度的单位(Cent)
void display_cent(void)
WriteAddress(0x80+0x40+0x02); //写显示地址,将在第2行第13列开始显示
WriteData(0xdf);
WriteData('C');
向1302写一个字节
void input_BYTE(uchar dat)
uchar i;
ACC=dat;
for(i=8;i>0;i--)
T_IO=ACC0;
T_CLK=1;
delaynms(5);
T_CLK=0;
ACC=(ACC>>1);
1302读出一个字节
uchar output_BYTE()
uchar i;
for(i=8;i>0;i--)
ACC=(ACC>>1);
ACC7=T_IO;
T_CLK=1;
T_CLK=0;
return (ACC);
写数据
void write_1302(uchar add,uchar dat)
T_RST=0; //禁止数据传输
T_CLK=0; //确保写数据之前SCLK被拉低
T_RST=1; //启动数据传输
delaynms(5);
input_BYTE(add); //写入命令字
input_BYTE(dat); //写数据
delaynms(5);
T_CLK=1; //将时钟电平至于已知状态
T_RST=0;
读数据
uchar read_1302(uchar add)
uchar inf;
T_RST=0;
T_CLK=0;
T_RST=1;
delaynms(5);
input_BYTE(add);
inf=output_BYTE();
delaynms(5);
T_CLK=1;
T_RST=0;
return (inf);
void init_1302()
write_1302(0x8e,0x00);//关闭写保护;
// write_1302(0x90,0xaa);//设置充电方式;
write_1302(0x80,0x00);//秒寄存器初始化;
write_1302(0x82,0x29);//分.......
write_1302(0x84,0x08);//时.......
write_1302(0x86,0x10);//日........
write_1302(0x88,0x11);//月.......
write_1302(0x8a,0x02);//星期...
write_1302(0x8c,0x15);//年......
write_1302(0x8e,0x80);//打开写保护;
闹钟显示子程序
void show_naozhong(uchar x,uchar y)
uchar i,x1,x2,y1,y2;
x1=x/10; //十位
x2=x%10;//个位
WriteAddress(0x80+0x0b); //显示闹钟的小时部分
WriteData(table1[x1]);
WriteAddress(0x80+0x0c);
WriteData(table1[x2]);
y1=y/10; //十位
y2=y%10;//个位
WriteAddress(0x80+0x0e); //显示闹钟的分钟部分
WriteData(table1[y1]);
WriteAddress(0x80+0x0f);
WriteData(table1[y2]);
WriteAddress(0x80+0x0d); //显示小时与分钟之间的那个冒号
WriteData(':');
WriteAddress(0x80); //显示字符串:Alarm Clock
for(i=0;i<11;i++)
WriteData(table[i]);
WriteAddress(0x80+0x40); //显示字符串:Today is fine!
for(i=0;i<14;i++)
WriteData(table3[i]);
void main(void)
uchar i;
// ceshi=0;
LcdInitiate(); //将液晶初始化
delaynms(5); //延时5ms给硬件一点反应时间
init_1302();
EA=1;//开总中断
EX0=1; //开外部中断1
IT0=0; //下降沿触发
WriteAddress(0x80+0x50);
for(i=0;i<13;i++)
WriteData(table5[i]);
for(i=0;i<30;i++)
write_com(0x18);
delaynms(250);
delaynms(250);
write_com(0x01);
{ read_io();
t_sec=read_1302(0x81);//读秒 ;
sec1=t_sec&0x0f;
sec2=(t_sec>>4);
t_min=read_1302(0x83);//读分 ;
min1=t_min&0x0f;
min2=(t_min>>4);
t_hour=read_1302(0x85);//读小时 ;
hour1=t_hour&0x0f;
hour2=(t_hour>>4);
t_day=read_1302(0x87);//读日;
day1=t_day&0x0f;
day2=(t_day>>4);
t_mon=read_1302(0x89);//读月 ;
mon1=t_mon&0x0f;
mon2=(t_mon>>4);
week=read_1302(0x8b);//读星期 ;
week1=week&0x0f;
t_year=read_1302(0x8d);//读年 ;
year1=t_year&0x0f;
year2=(t_year>>4);
WriteAddress(0x80+0x06);
WriteData('2');
WriteAddress(0x80+0x07);
WriteData('0');
WriteAddress(0x80); //显示星期(0x80~0x80+0x05)
for(i=0;i<4;i++)
WriteData(table2[i]);
WriteAddress(0x80+0x04);
WriteData(table1[week1]);
WriteAddress(0x80+0x08);//显示年
WriteData(table1[year2]);
WriteAddress(0x80+0x09);
WriteData(table1[year1]);
WriteAddress(0x80+0x0a); //显示‘/’
WriteData('/');
WriteAddress(0x80+0x0b);//显示月
WriteData(table1[mon2]);
WriteData(table1[mon1]);
WriteAddress(0x80+0x0d); //显示‘/’
WriteData('/');
WriteAddress(0x80+0x0e);//显示日
WriteData(table1[day2]);
WriteData(table1[day1]);
/*第一行在此显示完毕*/
// display_dot(); //显示温度的小数点
display_cent(); //显示温度的单位
WriteAddress(0x80+0x40); //温度
WriteData(table1[WENSHI]);
WriteAddress(0x80+0x40+0x01);//
WriteData(table1[WENGE]);
WriteAddress(0x80+0x40+0x05); //温度
WriteData(table1[SHISHI]);
WriteAddress(0x80+0x40+0x06);//
WriteData(table1[SHIGE]);
WriteAddress(0x80+0x40+0x08); //显示小时
WriteData(table1[hour2]);
WriteAddress(0x80+0x40+0x09);
WriteData(table1[hour1]);
WriteAddress(0x80+0x40+0x0a); //显示':'
WriteData(':');
WriteAddress(0x80+0x40+0x0b); //显示分钟
WriteData(table1[min2]);
WriteAddress(0x80+0x40+0x0c);
WriteData(table1[min1]);
WriteAddress(0x80+0x40+0x0d); //显示':'
WriteData(':');
WriteAddress(0x80+0x40+0x0e); //显示秒
WriteData(table1[sec2]);
WriteAddress(0x80+0x40+0x0f);
WriteData(table1[sec1]);
/*第二行在此显示完毕*/
//以下部分是闹钟键盘检测程序
if((x==hour2*10+hour1)&&(y==min2*10+min1))//若时间到了,则开启闹钟
beep=0;
else //否则,关闭闹钟
beep=1;
delaynms(10);
void exter0()interrupt 0
uint k;
write_com(0x01);
for(k=0;k<2000;k++)
while(key1==0) //键盘扫描.当key1按下时,
{ //闹钟的小时部分加一
delaynms(10);
if(key1==0) //消抖
delaynms(10);
while(key1==0); //松手检测
x++;
if(x==24) //小时部分加到24后自动清零
x=0;
while(key2==0) //键盘检测。当key2按下时,
delaynms(10); //闹钟的分钟部分加一
if(key2==0) //消抖
delaynms(10);
while(key2==0);//松手检测
y++;
if(y==60) //若分钟部分加到60,则自动清零
y=0;
show_naozhong(x,y); //调用闹钟显示程序
write_com(0x01);
