查看: 15614|回复: 1
error:#8: missing closing quote 问题解决
ID:104126 发表于 2016-1-23 02:44 | 显示全部楼层 |阅读模式
MDK5无法编译汉子编码问题
MDK5.17编译EMWIN 提示错误,具体现象是在包含汉子显示的部分会出现这个BUG.
类似这种语句
    { BUTTON_CreateIndirect,   "安安安",          GUI_ID_BUTTON0,        350,20,420,150,0,0},
    { TEXT_CreateIndirect,     "安安安安安",      GUI_ID_TEXT0,          5, 10, 300, 33, 0,0},
    { TEXT_CreateIndirect,     "安安安安子",      GUI_ID_TEXT1,          5, 40,250, 50, 0,0},
但是原来mdk4.74的工程都无法完成编译,提示很多错误。都是有中文字符的地方。另一个论坛上也提到了这个问题,而且貌似无解。
解决方案:用notepad++把文件编码转换为UTF-8编码模式。之前打开显示的编码模式是UTF-8无BOM格式,那种格式在MDK5里面是无法正常解析的,MDK4确可以正确识别,大家在用MDK5.1遇到这个错误之后按照这个方法解决即可,具体原理不详。
编译器提示的错误汇总:
applications\MainTask.c(45): error: #8: missing closing quote
applications\MainTask.c(45): error:  #8:missing closing quote
      {BUTTON_CreateIndirect,   "瀹?瀹?瀹?",          GUI_ID_BUTTON0,        350,20,420,150,0,0},
applications\MainTask.c(46): error:  #253:expected a ","
      {TEXT_CreateIndirect,     "瀹?瀹?瀹?瀹?瀹?",      GUI_ID_TEXT0,          5, 10, 300, 33, 0,0},
applications\MainTask.c(46): error:  #8:missing closing quote
applications\MainTask.c(47): error:  #8:missing closing quote
      {TEXT_CreateIndirect,     "瀹?瀹?瀹?瀹?瀛?",      GUI_ID_TEXT1,          5, 40,250, 50, 0,0},
applications\MainTask.c(48): error:  #8:missing closing quote
      {TEXT_CreateIndirect,     "瀹?瀹?瀹?",          GUI_ID_TEXT2,          5, 100,360, 90, 0,0},
applications\MainTask.c(49): error:  #8:missing closing quote
      {TEXT_CreateIndirect,     "瀵?",             GUI_ID_TEXT3,          5, 220,144, 144, 0,0},
applications\MainTask.c(50): error:  #8:missing closing quote
      {TEXT_CreateIndirect,     "瀵?",             GUI_ID_TEXT4,          205, 230,144, 144, 0,0},
      {TEXT_CreateIndirect,     "瀵?",             GUI_ID_TEXT5,          405, 230,144, 144, 0,0},
error:  #67: expected a "}"
error:  #757: function "WM_GetDialogItem" isnot a type name
error:  #18: expected a ")"
error:  #79: expected a type specifier
error:  #147: declaration is incompatible with"void TEXT_SetFont(TEXT_Handle, const GUI_FONT *)" (declared atline 144 of "STemWin\inc\TEXT.h")
error:  #40: expected an identifier
error:  #147: declaration is incompatible with"void TEXT_SetTextColor(TEXT_Handle, GUI_COLOR)" (declared at line147 of "STemWin\inc\TEXT.h")
ID:948433 发表于 2021-7-7 14:18 | 显示全部楼层
