* 标题: 步进电机试验三(加减速运行) *
* 通过本例程了解步进马达使用及驱动程序编写 *
*; 单双八拍工作方式: *
*; A-AB-B-BC-C-CD-D-DA (即一个脉冲,转 3.75 度) *
* 请学员一定要消化掉本例程 *
#include "reg52.h"
void delay();
//Motor
sbit F1 = P1^0;
sbit F2 = P1^1;
sbit F3 = P1^2;
sbit F4 = P1^3;
unsigned char code FFW[8]={0xf1,0xf3,0xf2,0xf6,0xf4,0xfc,0xf8,0xf9}; //反转
unsigned char code FFZ[8]={0xf9,0xf8,0xfc,0xf4,0xf6,0xf2,0xf3,0xf1}; //正转
unsigned int K, rate;
* 步进电机驱动 *
void motor_ffw()
unsigned char i;
for (i=0; i<8; i++) //一个周期转30度
P1 = FFW[i]&0x1f; //取数据
delay(); //调节转速
延时程序
void delay()
unsigned int k,t;
t=rate;
while(t--)
for(k=0; k<100; k++)
*步进电机运行
void motor_turn()
unsigned char x;
rate=0x2a;
x=0x40;
do
motor_ffw(); //加速
rate--;
}while(rate!=0x08);
do
motor_ffw(); //匀速
x--;
}while(x!=0x01);
do
motor_ffw(); //减速
rate++;
}while(rate!=0x2a);
main()
motor_turn();
