查看: 4496|回复: 1
简单的基于51单片机定时器上呼吸灯
ID:111924 发表于 2016-4-14 20:23 | 显示全部楼层 |阅读模式
#include <reg52.h>
#define ufloat unsigned float
#define uchar  unsigned char
#define uint   unsigned int
uchar zkb, t0;
bit flag1, flag2;        //flag1占空比标志位, flag2占空比方向标志位(0自增, 1自减);
sbit led = P1^1;        //输出口;
void init ();
void display ();
int main (void)
        init();
        while (1)
                display ();
        return 0;
void init ()                                //初始化子函数
        TMOD = 0x01;                        //定时器0模式;
        TH0  = (65536-10)/256;        //附高8位初值(0.01ms);
        TL0  = (65536-10)%256;        //附底8位初值(0.01ms);
        EA   = 1;                        //开总中断;
        ET0  = 1;                        //开定时器0中断;
        TR0  = 1;                        //开启定时器0;
void display ()                                //占空比子函数;
        if (flag1 == 1)                        //占空比标志起始;
                flag1 = 0;                        //复位占空比标志位;
                if (flag2 == 0)                //占空比自增标志;
                        zkb++;
                        if (zkb == 200)        //占空比最大值;
                                flag2 = 1;        //占空比进入自减标志位开启;
                else                                //占空比自减开始;
                        zkb--;
                        if (zkb == 0)                //占空比最小值;
                                flag2 = 0;        //占空比进入自增标志位开启;
void timer0() interrupt 1
        t0++;
        if (t0 <= zkb)        //未到占空比数值输出为0;
                led = 0;
                led = 1;        //到达占空比数值输出为1;
        if (t0 == 200)        //总周期为200*0.01ms 一旦到达总周期,动态计数器t0累加值清零,进入下个循环;
                t0    = 0;
                led   = 1;
                flag1 = 1;        //占空比标志再次开启;
ID:111924 发表于 2016-4-15 21:06 | 显示全部楼层
自己顶一个
