基于51单片机的电子密码锁
原理图:
总电路图(附件中可以下载完整)
控制电路:
程序:
- //包含头文件
- #include <REG51.h>
- #include<intrins.h>
- //宏定义
- #define LCM_Data P0 //将P0口定义为LCM_Data
- #define uchar unsigned char
- #define uint unsigned int
- //1602的控制脚
- sbit lcd1602_rs=P2^7;
- sbit lcd1602_rw=P2^6;
- sbit lcd1602_en=P2^5;
- sbit Scl=P3^4; //24C02串行时钟
- sbit Sda=P3^5; //24C02串行数据
- sbit ALAM = P2^1; //报警
- sbit KEY = P3^6; //开锁
- bit pass=0; //密码正确标志
- bit ReInputEn=0; //重置输入允许标志
- bit s3_keydown=0; //3秒按键标志位
- bit key_disable=0; //锁定键盘标志
- unsigned char countt0,second; //t0中断计数器,秒计数器
- void Delay5Ms(void); //声明延时函数
- void DisplayChar(void);
- unsigned char code a[]={0xFE,0xFD,0xFB,0xF7}; //控盘扫描控制表
- //液晶显示数据数组
- unsigned char code start_line[] = {"password: "};
- unsigned char code name[] = { "===Coded Lock==="}; //显示名称
- unsigned char code Correct[] = {" correct "}; //输入正确
- unsigned char code Error[] = {" error "}; //输入错误
- unsigned char code codepass[] = {" pass "};
- unsigned char code LockOpen[] = {" open "}; //OPEN
- unsigned char code SetNew[] = {"SetNewWordEnable"};
- unsigned char code Input[] = {"input: "}; //INPUT
- unsigned char code ResetOK[] = {"ResetPasswordOK "};
- unsigned char code initword[] = {"Init password..."};
- unsigned char code Er_try[] = {"error,try again!"};
- unsigned char code again[] = {"input again "};
- unsigned char InputData[6]; //输入密码暂存区
- unsigned char CurrentPassword[6]={1,3,1,4,2,0}; //管理员密码(只可在程序中修改)
- unsigned char TempPassword[6];
- unsigned char N=0; //密码输入位数记数
- unsigned char ErrorCont; //错误次数计数
- unsigned char CorrectCont; //正确输入计数
- unsigned char ReInputCont; //重新输入计数
- unsigned char code initpassword[6]={0,0,0,0,0,0}; //输入管理员密码后将密码初始为000000
- //=====================5ms延时==============================
- unsigned int TempCyc = 5552;
- while(TempCyc--);
- //===================400ms延时==============================
- void Delay400Ms(void)
- unsigned char TempCycA = 5;
- unsigned int TempCycB;
- while(TempCycA--)
- TempCycB=7269;
- while(TempCycB--);
- //================================24C02========================================================
- void mDelay(uint t) //延时
- uchar i;
- while(t--)
- for(i=0;i<125;i++)
- void Nop(void) //空操作
- _nop_(); //仅作延时用一条语句大约1us
- _nop_();
- _nop_();
- _nop_();
- /*****24c02程序参照24c02时序图*****/
- /*起始条件*/
- void Start(void)
- Sda=1;
- Scl=1;
- Nop();
- Sda=0;
- Nop();
- /*停止条件*/
- void Stop(void)
- Sda=0;
- Scl=1;
- Nop();
- Sda=1;
- Nop();
- /*应答位*/
- void Ack(void)
- Sda=0;
- Nop();
- Scl=1;
- Nop();
- Scl=0;
- /*反向应答位*/
- void NoAck(void)
- Sda=1;
- Nop();
- Scl=1;
- Nop();
- Scl=0;
- /*发送数据子程序,Data为要求发送的数据*/
- void Send(uchar Data)
- uchar BitCounter=8;
- uchar temp;
- do
- temp=Data; //将待发送数据暂存temp
- Scl=0;
- Nop();
- if((temp&0x80)==0x80) //将读到的数据&0x80
- Sda=1;
- else
- Sda=0;
- Scl=1;
- temp=Data<<1; //数据左移
- Data=temp; //数据左移后重新赋值Data
- BitCounter--; //该变量减到0时,数据也就传送完成了
- while(BitCounter); //判断是否传送完成
- Scl=0;
- /*读一字节的数据,并返回该字节值*/
- uchar Read(void)
- uchar temp=0;
- uchar temp1=0;
- Sda=1;
- do
- Scl=0;
- Nop();
- Scl=1;
- Nop();
- if(Sda) //数据位是否为1
- temp=temp|0x01; //为1 temp的最低位为1(|0x01,就是将最低位变为1)
- else //如果为0
- temp=temp&0xfe; //temp最低位为0(&0xfe(11111110)最低位就是0)
- if(BitCounter-1) //BitCounter减1后是否为真
- temp1=temp<<1; //temp左移
- temp=temp1;
- BitCounter--; //BitCounter减到0时,数据就接收完了
- while(BitCounter); //判断是否接收完成
- return(temp);
- void WrToROM(uchar Data[],uchar Address,uchar Num)
- uchar i;
- uchar *PData;
- PData=Data;
- for(i=0;i<Num;i++)
- Start();
- Send(0xa0);
- Ack();
- Send(Address+i);
- Ack();
- Send(*(PData+i));
- Ack();
- Stop();
- mDelay(20);
- void RdFromROM(uchar Data[],uchar Address,uchar Num)
- uchar i;
- uchar *PData;
- PData=Data;
- Start();
- Send(0xa0);
- Ack();
- Send(Address+i);
- Ack();
- Start();
- Send(0xa1);
- Ack();
- *(PData+i)=Read();
- Scl=0;
- NoAck();
- Stop();
- //=======================================LCD1602====================================================
- #define yi 0x80 //LCD第一行的初始位置,因为LCD1602字符地址首位D7恒定为1(100000000=80)
- #define er 0x80+0x40 //LCD第二行初始位置(因为第二行第一个字符位置地址是0x40)
- //----------------延时函数,后面经常调用----------------------
- void delay(uint xms)//延时函数,有参函数
- uint x,y;
- for(x=xms;x>0;x--)
- for(y=110;y>0;y--);
- //--------------------------写指令---------------------------
- void write_1602com(uchar com)//****液晶写入指令函数****
- lcd1602_rs=0;//数据/指令选择置为指令
- lcd1602_rw=0; //读写选择置为写
- P0=com;//送入数据
- delay(1);
- lcd1602_en=1;//拉高使能端,为制造有效的下降沿做准备
- delay(1);
- lcd1602_en=0;//en由高变低,产生下降沿,液晶执行命令
- //-------------------------写数据-----------------------------
- void write_1602dat(uchar dat)//***液晶写入数据函数****
- lcd1602_rs=1;//数据/指令选择置为数据
- P0=dat;//送入数据
- delay(1);
- lcd1602_en=1; //en置高电平,为制造下降沿做准备
- delay(1);
- lcd1602_en=0; //en由高变低,产生下降沿,液晶执行命令
- //-------------------------初始化-------------------------
- void lcd_init(void)
- write_1602com(0x38);//设置液晶工作模式,意思:16*2行显示,5*7点阵,8位数据
- write_1602com(0x0c);//开显示不显示光标
- write_1602com(0x06);//整屏不移动,光标自动右移
- write_1602com(0x01);//清显示
- //==============将按键值编码为数值=========================
- unsigned char coding(unsigned char m)
- unsigned char k;
- switch(m)
- case (0x11): k=1;break;
- case (0x21): k=2;break;
- case (0x41): k=3;break;
- case (0x81): k='A';break;
- case (0x12): k=4;break;
- case (0x22): k=5;break;
- case (0x42): k=6;break;
- case (0x82): k='B';break;
- case (0x14): k=7;break;
- case (0x24): k=8;break;
- case (0x44): k=9;break;
- case (0x84): k='C';break;
- case (0x18): k='*';break;
- case (0x28): k=0;break;
- case (0x48): k='#';break;
- case (0x88): k='D';break;
- return(k);
- //=====================按键检测并返回按键值===============================
- unsigned char keynum(void)
- unsigned char row,col,i;
- P1=0xf0;
- if((P1&0xf0)!=0xf0)
- Delay5Ms();
- Delay5Ms();
- row=P1^0xf0; //确定行线
- i=0;
- P1=a[i]; //精确定位
- while(i<4)
- col=~(P1&0xff); //确定列线
- break; //已定位后提前退出
- else
- i++;
- P1=a[i];
- else
- return 0;
- while((P1&0xf0)!=0xf0);
- return (row|col); //行线与列线组合后返回
- else return 0; //无键按下时返回0
- //=======================一声提示音,表示有效输入========================
- void OneAlam(void)
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- //========================二声提示音,表示操作成功========================
- void TwoAlam(void)
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- //========================三声提示音,表示错误========================
- void ThreeAlam(void)
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- //=======================显示提示输入=========================
- unsigned char i;
- if(pass==1)
- //DisplayListChar(0,1,LockOpen);
- write_1602com(er); //在二行开始显示
- for(i=0;i<16;i++)
- write_1602dat(LockOpen[i]); //显示open 开锁成功
- else
- if(N==0)
- //DisplayListChar(0,1,Error);
- for(i=0;i<16;i++)
- write_1602dat(Error[i]); //显示错误
- else
- //DisplayListChar(0,1,start_line);
- for(i=0;i<16;i++)
- write_1602dat(start_line[i]);//显示开始输入
- //========================重置密码==================================================
- void ResetPassword(void)
- unsigned char i;
- unsigned char j;
- if(pass==0)
- pass=0;
- DisplayChar(); //显示错误
- ThreeAlam(); //没开锁时按下重置密码报警3声
- else //开锁状态下才能进行密码重置程序
- if(ReInputEn==1) //开锁状态下,ReInputEn置1,重置密码允许
- if(N==6) //输入6位密码
- ReInputCont++; //密码次数计数
- if(ReInputCont==2) //输入两次密码
- for(i=0;i<6;)
- if(TempPassword[i]==InputData[i]) //将两次输入的新密码作对比
- i++;
- else //如果两次的密码不同
- for(j=0;j<16;j++)
- write_1602dat(Error[j]); //显示错误Error
- ThreeAlam(); //错误提示
- pass=0; //关锁
- ReInputEn=0; //关闭重置功能,
- ReInputCont=0;
- DisplayChar();
- break;
- if(i==6)
- //DisplayListChar(0,1,ResetOK);
- for(j=0;j<16;j++)
- write_1602dat(ResetOK[j]); //密码修改成功,显示
- TwoAlam(); //操作成功提示
- WrToROM(TempPassword,0,6); //将新密码写入24C02存储
- ReInputEn=0;
- ReInputCont=0;
- CorrectCont=0;
- else //输入一次密码时
- OneAlam();
- //DisplayListChar(0, 1, again); //显示再次输入一次
- for(j=0;j<16;j++)
- write_1602dat(again[j]); //显示再输入一次
- for(i=0;i<6;i++)
- TempPassword[i]=InputData[i]; //将第一次输入的数据暂存起来
- N=0; //输入数据位数计数器清零
- //=======================输入密码错误超过三过,报警并锁死键盘======================
- void Alam_KeyUnable(void)
- P1=0x00;
- ALAM=~ALAM; //蜂鸣器一直闪烁鸣响
- Delay5Ms();
- //=======================取消所有操作============================================
- void Cancel(void)
- unsigned char i;
- unsigned char j;
- //DisplayListChar(0, 1, start_line);
- for(j=0;j<16;j++)
- write_1602dat(start_line[j]); //显示开机输入密码界面
- TwoAlam(); //提示音
- for(i=0;i<6;i++)
- InputData[i]=0; //将输入密码清零
- KEY=1; //关闭锁
- ALAM=1; //报警关
- pass=0; //密码正确标志清零
- ReInputEn=0; //重置输入充许标志清零
- ErrorCont=0; //密码错误输入次数清零
- CorrectCont=0; //密码正确输入次数清零
- ReInputCont=0; //重置密码输入次数清零
- s3_keydown=0;
- key_disable=0; //锁定键盘标志清零
- N=0; //输入位数计数器清零
- //==========================确认键,并通过相应标志位执行相应功能===============================
- void Ensure(void)
- unsigned char i,j;
- RdFromROM(CurrentPassword,0,6); //从24C02里读出存储密码
- if(N==6)
- if(ReInputEn==0) //重置密码功能未开启
- for(i=0;i<6;)
- if(CurrentPassword[i]==InputData[i]) //判断输入密码和24c02中的密码是否相同
- i++; //相同一位 i就+1
- else //如果有密码不同
- ErrorCont++; //错误次数++
- if(ErrorCont==3) //错误输入计数达三次时,报警并锁定键盘
- for(i=0;i<16;i++)
- do
- Alam_KeyUnable();
- while(1);
- else //错误次数小于3次时,锁死键盘3秒,然后重新可以输入
- TR0=1; //开启定时
- key_disable=1; //锁定键盘
- pass=0; //pass位清零
- break; //跳出
- if(i==6) //密码输入对时
- CorrectCont++; //输入正确变量++
- if(CorrectCont==1) //正确输入计数,当只有一次正确输入时,开锁
- for(j=0;j<16;j++)
- write_1602dat(LockOpen[j]); //显示open开锁画面
- TwoAlam(); //操作成功提示音
- KEY=0; //开锁
- pass=1; //置正确标志位
- TR0=1; //开启定时
- for(j=0;j<6;j++) //将输入清除
- InputData[i]=0; //开锁后将输入位清零
- else //当两次正确输入时,开启重置密码功能
- //DisplayListChar(0,1,SetNew);
- for(j=0;j<16;j++)
- write_1602dat(SetNew[j]); //显示重置密码界面
- ReInputEn=1; //允许重置密码输入
- CorrectCont=0; //正确计数器清零
- else //=========================当第一次使用或忘记密码时可以用131420对其密码初始化============
- if((InputData[0]==1)&&(InputData[1]==3)&&(InputData[2]==1)&&(InputData[3]==4)&&(InputData[4]==2)&&(InputData[5]==0))
- WrToROM(initpassword,0,6); //强制将初始密码写入24C02存储
- //DisplayListChar(0,1,initword); //显示初始化密码
- for(j=0;j<16;j++)
- write_1602dat(initword[j]); //显示初始化密码
- TwoAlam(); //成功提示音
- Delay400Ms(); //延时400ms
- N=0; //输入位数计数器清零
- else //密码输入错误
- for(j=0;j<16;j++)
- write_1602dat(Error[j]); //显示错误信息
- ThreeAlam(); //错误提示音
- pass=0;
- else //当已经开启重置密码功能时,而按下开锁键,
- //DisplayListChar(0,1,Er_try);
- for(j=0;j<16;j++)
- write_1602dat(Er_try[j]); //错误,请重新输入
- else //密码没有输入到6位时,按下确认键时
- for(j=0;j<16;j++)
- pass=0;
- N=0; //将输入数据计数器清零,为下一次输入作准备
- //==============================主函数===============================
- void main(void)
- unsigned char KEY,NUM;
- P1=0xFF; //P1口复位
- TMOD=0x11; //定义工作方式
- TL0=0xB0;
- TH0=0x3C; //定时器赋初值
- EA=1; //打开中断总开关
- ET0=1; //打开中断允许开关
- TR0=0; //打开定时器开关
- Delay400Ms(); //启动等待,等LCM讲入工作状态
- lcd_init(); //LCD初始化
- DisplayChar(); //显示提示输入
- write_1602com(yi);//日历显示固定符号从第一行第0个位置之后开始显示
- for(i=0;i<16;i++)
- write_1602dat(name[i]);//向液晶屏写开机画面
- for(i=0;i<16;i++)
- write_1602dat(start_line[i]);//写输入密码等待界面
- write_1602com(er+9); //设置光标位置
- write_1602com(0x0f); //设置光标为闪烁
- Delay5Ms(); //延时片刻(可不要)
- N=0; //初始化数据输入位数
- while(1) //进入循环
- if(key_disable==1) //锁定键盘标志为1时
- Alam_KeyUnable(); //报警键盘锁
- else
- ALAM=1; //关报警
- KEY=keynum(); //读按键的位置码
- if(KEY!=0) //当有按键按下时
- second=0; //秒清零
- else //没有锁定键盘时
- NUM=coding(KEY); //根据按键的位置将其编码,编码值赋值给NUM
- switch(NUM) //判断按键值
- case ('A'): ; break;
- case ('B'): ; break;
- case ('C'): ; break; //ABC是无定义按键
- case ('D'): ResetPassword(); break; //重新设置密码
- case ('*'): Cancel(); break; //取消当前输入
- case ('#'): Ensure(); break; //确认键,
- default: //如果不是功能键按下时,就是数字键按下
- //DisplayListChar(0,1,Input);
- for(i=0;i<16;i++)
- write_1602dat(Input[i]); //显示输入画面
- if(N<6) //当输入的密码少于6位时,接受输入并保存,大于6位时则无效。
- OneAlam(); //按键提示音
- for(j=0;j<=N;j++)
- write_1602com(er+6+j); //显示位数随输入增加而增加
- write_1602dat('*'); //但不显示实际数字,用*代替
- InputData[N]=NUM; //将数字键的码赋值给InputData[]数组暂存
- N++; //密码位数加
- else //输入数据位数大于6后,忽略输入
- N=6; //密码输入大于6位时,不接受输入
- break;
- //*********************************中断服务函数**************************************
- void time0_int(void) interrupt 1 //定时器T0
- TL0=0xB0;
- TH0=0x3C; //定时器重新赋初值
- //TR0=1;
- countt0++; //计时变量加,加1次时50ms
- if(countt0==20) //加到20次就是1s
- countt0=0; //变量清零
- second++; //秒加
- if(pass==1) //开锁状态时
- if(second==1) //秒加到1s时
- TR0=0; //关定时器
- TL0=0xB0;
- TH0=0x3C; //再次赋初值
- second=0; //秒清零
- else //不在开锁状态时
- if(second==3) //秒加到3时
- TR0=0; //关闭定时器
- second=0; //秒清零
- key_disable=0; //锁定键盘清零
- s3_keydown=0;
- TL0=0xB0;
- TH0=0x3C; //重新赋初值
- else
- TR0=1; //打开定时器
