查看: 2049|回复: 0
基于RS-485的多机通信
ID:117656 发表于 2016-4-30 13:37 | 显示全部楼层 |阅读模式
//-----------------------oˉêyéùÃ÷£¬±äῶ¨òå--------------------------------------------------------
#include <reg51.h>
sbit RE_DE=P1^0;
#define COUNT 10                // ¶¨òå½óêÕ»o3åÇø′óD¡
#define ADD    5                                //¶¨òåé豸μØÖ·
unsigned char buffer[COUNT];        //¶¨òå½óêÕ»o3åÇø
unsigned char point;            //¶¨òå½óêÕêy¾Y¸öêyָ꾱äá¿
void UART_init();               //′®¿ú3õê¼»ˉoˉêy
void COM_send(void);            //′®¿ú½óêÕoˉêy
unsigned char CLU_checkdata(void);//¼ÆËãD£Ñéλoˉêy
// oˉêyÃû3Æ£o UART_init()′®¿ú3õê¼»ˉoˉêy
// oˉêy1|Äü£o ÔúÏμí3ê±ÖóÎa11.059MHZê±£¬é趨′®¿ú2¨ìØÂêÎa9600bit/s
//            ′®¿ú½óêÕÖD¶ÏÔêDí£¬·¢ËíÖD¶Ï½ûÖ1
void UART_init()
                     //3õê¼»ˉ′®DD¿úoí2¨ìØÂê·¢éúÆ÷
SCON =0x0F0;          //Ñ¡Ôñ′®¿ú1¤×÷·½ê½Îa3£¬′ò¿a½óêÕÔêDí
TMOD =0x21;          //¶¨ê±Æ÷11¤×÷Ôú·½ê½2£¬¶¨ê±Æ÷01¤×÷Ôú·½ê½1
TH1 =0xfd;           //êμÏÖ2¨ìØÂê9600£¨Ïμí3ê±Öó11.0592MHZ£©
TL1 =0xfd;           //êμÏÖ2¨ìØÂê9600£¨Ïμí3ê±Öó11.0592MHZ£©
TR1 =1;              //Æô¶ˉ¶¨ê±Æ÷T1
ET1 =0;
ES=1;                //ÔêDí′®DD¿úÖD¶Ï
PS=1;                //éè¼Æ′®DD¿úÖD¶ÏóÅÏ輶
EA =1;               //μ¥Ƭ»úÖD¶ÏÔêDí
SM2=1;                //é豸′|óúμØÖ·¼àìy×′ì¬
// oˉêyÃû3Æ£o com_interrup()′®¿ú½óêÕÖD¶Ï′|àíoˉêy
// oˉêy1|Äü£o ½óêÕ°üà¨Æeê¼Î»0xFE£¬μØַλoíÖÕÖ1λ0xEFÔúÄúμÄê®Î»êy¾Yμ½êy¾Y»o3åÇø£¬
//            μØÖ·2»Æ¥Å䣬Ôò½óêÕμ½μÄêÇÎTD§êy×Ö£¬2»D′μ½½óêÕ»o3åÇø
com_interrupt(void) interrupt 4 using 3
  unsigned char RECEIVR_buffer;
  if(RI)
  {                               //′|àí½óêÕÖD¶Ï
   RI=0;                                 //Çå3yÖD¶Ï±ê־λ
   RECEIVR_buffer=SBUF;                            //½óêÕ′®¿úêy¾Y
   if(point==0)                                                    //èç1û»1ûóD½óêÕμ½Æeê¼Î»
        if(RECEIVR_buffer==0xFE)         //ÅD¶ÏêÇ·ñÆeê¼±ê־λ
             buffer[point++]=RECEIVR_buffer;//Æeê¼Õyè·£¬½óêÕÆeê¼Î»
                     point=0;                                    //2»êÇ£¬¼ìDøμè′yÆeê¼Î»
     else if(point==1)                                                //êÇ·ñμØַλ
        if(RECEIVR_buffer==ADD)          //ÅD¶ÏμØÖ·êÇ·ñÆ¥Åä
          buffer[point++]=RECEIVR_buffer;//μØÖ·Æ¥Å䣬½óêÕ¿aê¼½óêÕ
                     point=0;                                    //2»Æ¥Å䣬¼ìDøÏÂò»¸öÆeê¼Î»
else if(point>0&&point<10)                                 //ÅD¶ÏêÇ·ñ½óêÕ1»ê®Î»êy¾Y
         buffer[point++]=RECEIVR_buffer;         //2»1»£¬°Ñ½óêÕμ½μÄêy¾Y·Åèë½óêÕ»o′æÇø
else point=0;                                        //»o3åÇøòÑÂú£¬Çå3y»o′æÇøÄúêy¾YÖØD½óêÕ
if(TI)                                   //′®¿ú·¢ËíÖD¶Ï
TI=0;                                   //Çå3y·¢ËíÖD¶Ï
// oˉêyÃû3Æ£o COM_send()′®¿ú·¢Ëíoˉêy
// oˉêy1|Äü£o °Ñêy¾Y»o3åÇøμÄê®Î»êy¾Y·¢Ëí3öè¥
void COM_send(void)
RE_DE=1;                                //éèÖÃMAX483½øèë·¢Ëí×′ì¬
for(point=0;point<=10,TI=1;point++)         //á¬Dø·¢Ëíê®Î»êy¾Y
                                         //°Ñ»o′æÇøμÄêy¾Y¶¼·¢Ëíμ½′®¿ú
   SBUF=buffer[point];
   TI=0;
    RE_DE=0;                                //éèÖÃMAX483½øèë½óêÕ×′ì¬
// oˉêyÃû3Æ£o Ö÷oˉêy
// oˉêy1|Äü£o μ÷¶è¸ö×óoˉêy£¬íê3éí¨DÅ1y3ì
void main(void)
   UART_init();                                                 //3õê¼»ˉ′®¿ú
  do
   while(point!=10);                //ÅD¶Ïêy¾YêÇ·ñ½óêÕíê3é
   COM_send();                                //μØÖ·Æ¥Å䣬êy¾YíêÕû½óêÕ£¬μ÷ó÷¢Ëí3ìDòí¨ÖaÖ÷»ú
  SM2=0;                  //éèÖÃÎaμã¶Ôμãí¨DÅ×′쬠
