这是小弟的代码
#include <LiquidCrystal.h>
LiquidCrystal lcd(7,8,9,10,11,12);
int runTimer = 1;
int runFor = 50; // time in seconds
int buzzerPin = 13;
int relayPin=4;
int data = 0;
const int switchPin = 5;
int hits = 0;
int switchState = 0;
int prevSwitchState = 0;
const int switchPin1 = 6;
int hits1 = 0;
int switchState1 = 0;
int prevSwitchState1 = 0;
void setup() {
pinMode(buzzerPin, OUTPUT);
pinMode(relayPin,OUTPUT);
lcd.begin(16, 0);
lcd.begin(16, 2);
pinMode(switchPin,INPUT);
pinMode(switchPin1,INPUT);
void loop() {
switchState = digitalRead(switchPin);
if (switchState != prevSwitchState) {
if (switchState == LOW) {
hits = hits + 1;
lcd.clear();
lcd.setCursor(0, 1);
lcd.print("Hits:");
lcd.setCursor(7, 1);
lcd.print(hits);
lcd.setCursor(11, 1);
lcd.print(hits1);
delay(90);
prevSwitchState = switchState;
switchState1 = digitalRead(switchPin1);
if (switchState1 != prevSwitchState1) {
if (switchState1 == LOW) {
hits1 = hits1 + 1;
lcd.clear();
lcd.print("Hits:");
lcd.print(hits1);
lcd.print(hits);
delay(90);
prevSwitchState1 = switchState1;
if(runTimer == 1){
digitalWrite(relayPin,LOW); // relay is OFF during countdown
lcd.clear();
lcd.print("TIMER=");
lcd.print("Hits:");
lcd.print(hits);
lcd.print(hits1)
//Start timer
;timer();
runTimer = 0;
lcd.noDisplay();
delay(250);
for(int duration = 0; duration < 100; duration ++){
digitalWrite(buzzerPin, HIGH);
delayMicroseconds(500);
digitalWrite(buzzerPin, LOW);
lcd.display();
delay(250);
void timer() {
for(int timer = runFor;timer > 0; --timer){
if(timer >= 10) {
lcd.setCursor(6,0);
} else {
lcd.setCursor(6,0);
lcd.print("0");
lcd.setCursor(7,0);
lcd.print(timer);
lcd.print(" SECOND!");
delay(1000);
lcd.setCursor(1,1);
lcd.clear();
lcd.print(" TIMER OUT!");
lcd.print("Hits:");
lcd.print(hits);
lcd.print(hits1);
当我用Arduino UNO 测试时,计时器工作但是开关计计数不工作。。请大神指点 |
