- 件3:音乐程序
- shuzhi EQU 3fh ;选曲目的地址
- song EQU p1.2 ;扬声器播放
- play EQU p3.0 ;播放停止键
- addone EQU p3.1 ;曲目加一键
- subone EQU p3.2 ;曲目减一键
- dul EQU P1 ;段选
- wel EQU P2 ;位选
- ORG 0000H
- LJMP START
- ORG 000BH ;定时器0溢出中断入口地址
- AJMP cont
- ORG 0013H ;外部中断一入口地址
- AJMP pause ;指向外部中断程序
- ORG 0100H
- START:
- MOV SP,#50H
- MOV TH0,#0DBH ;定时器赋初值
- MOV TL0,#0FFH
- MOV TMOD,#01H ;设定T1工作于方式2
- MOV IE,#86H ;开中断
- MOV TCON,#00H
- MOV R0,#00H
- MOV shuzhi,#00H
- (是否顺序播放音乐)
- MAIN:
- JNB play,first ;判断P3.0键是否按下
- SJMP MAIN
- first:
- ACALL del20
- JNB play,first
- MOV shuzhi,#00H
- MOV dul,#06H ;共阴数码管显示1
- MOV wel,#80H
- MOV DPTR,#dat1 ;dat1首地址赋给DPTR
- ACALL music0
- ACALL next
- RET
- next:
- INC shuzhi
- MOV A,shuzhi
- CJNE A,#01,LOOP3 ;A是否=1,不等就跳转到LOOP3
- MOV DPTR,#dat2 ;表2首地址送DPTR
- MOV dul,#5BH ;显示数值2
- MOV wel,#80H
- ACALL music0
- INC A
- LOOP3:
- CJNE A,#02,LOOP4 ;A是否=2,不等就跳转到LOOP4
- MOV DPTR,#dat3 ;表3首地址送DPTR
- MOV dul,#4FH ;显示数值3
- MOV wel,#80H
- ACALL music0
- INC A
- LOOP4:
- CJNE A,#03,next
- ACALL first
- RET
- (按键播放上一首音乐)
- last:
- DEC shuzhi
- MOV a,shuzhi
- CJNE a,#02,last1
- MOV dptr,#dat3
- MOV dul,#4Fh
- MOV wel,#80h
- ACALL music0
- last1: cjne a,#01,last2
- MOV dptr,#dat2
- MOV dul,#5Bh
- MOV wel,#80h
- ACALL music0
- last2: cjne a,#00,last
- MOV dptr,#dat1
- MOV dul,#06h
- MOV wel,#80h
- ACALL music0
- RET
- music0:
- MOV 20h,#00h ;中断计数单元清0
- music1: clr a
- MOVC a,@a+dptr ;查表取音阶常数
- JZ end0 ;累加器判0看是否是结束符
- CJNE a,#0ffh,music5 ;是休止符?
- LJMP music3 ;产生100ms停顿
- music5:
- NOP
- key:
- JNB play,k0 ;判断P3.0键是否按下
- JNB addone,k1 ;判断P3.2键是否按下
- JNB subone,k2 ;判断P3.1键是否按下
- MOV r6,a ;音阶常数送R6
- INC dptr ;DPTR+1
- MOV a,#0
- MOVC a,@a+dptr ;取常数送R7
- MOV r7,a
- SETB tr0 ;启动定时器T0
- music2: nop
- CJNE r0,#0,$
- CPL song ;输出电平取反
- MOV a, r6
- MOV r3,a ;音阶常数送R3
- LCALL del20
- MOV a, r7 ;节拍常数送A
- CJNE a,20h,music2 ;节拍时间到否
- MOV 20h,#00h ;为取下一音阶作准备
- INC DPTR
- LJMP music1
- music3:
- NOP ;休止100ms
- CLR tr0 ;关闭定时器
- MOV r2, #14h
- music4: NOP
- MOV r3, #250 ;R3=250
- LCALL del20
- DJNZ r2, music4
- INC dptr ;为取下一音阶作准备
- LJMP music1
- end0: MOV r2, #200 ;歌曲结束后,延时1s后继续
- music6: MOV r3, #250
- LCALL del20
- DJNZ r2,music6
- (按键选择)
- k1: ACALL del20 ;调用延时子程序
- JNB addone,k1 ;判断P3.2键是否释放
- ACALL next
- k2: ACALL del20
- JNB subone,k2 ;判断P3.1键是否释放
- ACALL last
- k0: ACALL del20
- JNB play,k0 ;判断3.0键是否释放
- LJMP start
- RET
- del20: MOV r4,#05h ;延时子程序
- del4: NOP
- DJNZ r4,del4
- DJNZ r3,del20
- RET
- cont: INC 20h ;计数单元+1
- MOV th0,#0dbh ;重新10ms定时初值
- MOV tl0,#0ffh
- RETI ;跳出中断
- (停止播放)
- pause: ACALL del20
- JNB p3.0,pause ;判断P3.0键是否有释放
- MOV a,r0 ;把R0的值给A
- CPL a ;A值取反
- MOV r0,a
- RETI
- dat1:
- db 3bh,20h,3bh,20h,30h,20h,33h,20h,3bh,80h,0ffh
- db 3bh,20h,3bh,20h,26h,20h,2bh,20h,26h,80h,0ffh
- db 26h,20h,26h,20h,20h,20h,26h,20h,2bh,20h,2bh,20h,30h,20h,33h,10h,33h,10h
- db 3bh,60h,40h,20h,4ch,80h,0ffh
- db 26h,20h,26h,20h,20h,20h,26h,20h,2bh,20h,2bh,20h,2bh,20h,30h,20h
- db 33h,20h,3bh,20h,3bh,20h,40h,2bh,3bh,80h,0ffh
- db 19h,20h,1ch,40h,26h,20h,19h,20h,1ch,40h,26h,20h,0ffh
- db 20h,20h,1ch,20h,1ch,20h,20h,20h,26h,80h,0ffh
- db 2bh,20h,2bh,40h,3bh,20h,2bh,20h,2bh,40h,2bh,20h,0ffh
- db 26h,20h,2bh,20h,2bh,20h,30h,20h,2bh,80h,0ffh
- db 2bh,20h,2bh,40h,3bh,20h,30h,20h,30h,40h,2bh,20h,0ffh
- db 33h,20h,3bh,20h,3bh,20h,40h,20h,3bh,80h,0ffh,0ffh
- dat2:
- db 18h,30h,1ch,10h,20h,40h,1ch,10h
- db 18h,10h,20h,10h,1ch,10h,18h,40h
- db 1ch,20h,20h,20h,1ch,20h,18h,20h
- db 20h,80h,0ffh,20h,30h,1ch,10h,18h
- db 20h,15h,20h,1ch,20h,20h,20h,26h
- db 40h,20h,20h,2bh,20h,26h,20h,20h
- db 20h,30h,80h,0ffh,20h,20h,1ch,10h
- db 18h,10h,20h,20h,26h,20h,2bh,20h
- db 30h,20h,2bh,40h,20h,20h,1ch,10h
- db 30h,20h,2bh,40h,20h,30h,1ch,10h
- db 18h,20h,15h,20h,1ch,20h,20h,20h
- db 26h,40h,20h,20h,2bh,20h,26h,20h
- db 20h,20h,30h,80h,20h,30h,1ch,10h
- db 20h,10h,1ch,10h,20h,20h,26h,20h
- db 2bh,20h,30h,20h,2bh,40h,20h,15h
- db 1fh,05h,20h,10h,1ch,10h,20h,20h
- db 26h,20h,2bh,20h,30h,20h,2bh,40h
- db 20h,30h,1ch,10h,18h,20h,15h,20h
- db 1ch,20h,20h,20h,26h,40h,20h,20h
- db 2bh,20h,26h,20h,20h,20h,30h,30h
- db 20h,30h,1ch,10h,18h,40h,1ch,20h
- db 20h,20h,26h,40h,13h,60h,18h,20h
- db 15h,40h,13h,40h,18h,80h,00h
- dat3:
- db 26h,20h,20h,20h,20h,20h,26h,10h,20h,10h,20h,80h,26h,20h,30h,20h
- db 30h,20h,39h,10h,30h,10h,30h,80h,26h,20h,20h,20h,20h,20h,1ch,20h
- db 20h,80h,2bh,20h,26h,20h,20h,20h,2bh,10h,26h,10h,2bh,80h,26h,20h
- db 30h,20h,30h,20h,39h,10h,26h,10h,26h,60h,40h,10h,39h,10h,26h,20h
- db 30h,20h,30h,20h,39h,10h,26h,10h,26h,80h,26h,20h,2bh,10h,2bh,10h
- db 2bh,20h,30h,10h,39h,10h,26h,10h,2bh,10h,2bh,20h,2bh,40h,40h,20h
- db 20h,10h,20h,10h,2bh,10h,26h,30h,30h,80h,18h,20h,18h,20h,26h,20h
- db 20h,20h,20h,40h,26h,20h,2bh,20h,30h,20h,30h,20h,1ch,20h,20h,20h
- db 20h,80h,1ch,20h,1ch,20h,1ch,20h,30h,20h,30h,60h,39h,10h,30h,10h
- db 20h,20h,2bh,10h,26h,10h,2bh,10h,26h,10h,26h,10h,2bh,10h,2bh,80h
- db 18h,20h,18h,20h,26h,20h,20h,20h,20h,60h,26h,10h,2bh,20h,30h,20h
- db 30h,20h,1ch,20h,20h,20h,20h,80h,26h,20h,30h,10h,30h,10h,30h,20h
- db 39h,20h,26h,10h,2bh,10h,2bh,20h,2bh,40h,40h,10h,40h,10h,20h,10h
- db 20h,10h,2bh,10h,26h,30h,30h,80h,00h
- END
复制代码 |
