查看: 2028|回复: 1
一个定时器实现3个两位数码管倒数计时
ID:97948 发表于 2016-7-8 14:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg51.h>
uchar code Table[]=  {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar num3,num4,ge1,shi1,num1,num2,ge,shi,num5,num6,ge2,shi2;
void delay()
     uchar i,j;
    for(i=40;i>0;i--)
    for(j=110;j>0;j--);
void T0_time() interrupt 1
    TH0=(65535-45872)/256;
    TL0=(65535-45872)%256;
    num1++;
        num3++;
        num5++;
if(num1==20)
    num1=0;
    num2--;
    if(num2==0)
      num2=45;
if(num3==20)
    num3=0;
    num4--;
    if(num4==0)
      num4=65;
if(num5==20)
    num5=0;
    num6--;
    if(num6==0)
      num6=76;
void display(uchar ge,uchar shi )
         shi=num2/10;
         ge=num2%10;
        P2=0xfd;
        P0=Table[ge];   delay();
        P2=0xfe;
        P0=Table[shi];  delay();
void display1(uchar ge1,uchar shi1)
        shi1=num4/10;
         ge1=num4%10;
        P2=0xf7;
        P0=Table[ge1];   delay();
        P2=0xfb;
        P0=Table[shi1];  delay();
void display2(uchar ge2,uchar shi2)
        shi2=num6/10;
        ge2=num6%10;
        P2=0xdf;
        P0=Table[ge2];   delay();
        P2=0xef;
        P0=Table[shi2];  delay();
    TMOD=0x01;
    EA=1;
    ET0=1;
    TR0=1;
    num1=0;num2=45;
     num3=0;    num4=65;
    num5=0;num6=76;
     display(ge,shi);
    display1(ge1,shi1);
     display2(ge2,shi2);
ID:36359 发表于 2016-7-15 22:26 | 只看该作者
老大呀 原理图怎么没有啊?
