- //**<程序名>:LED动态扫描子函数。 **
- //**<功能>: unsigned char * pucLedNum(unsigned long ulNumber); **
- //** 计算一个在000000到999999之间的数的每位数字并存储在数组中.并返回数组的首地址 **
- //** void vShowOneNum(unsigned char ucOneNum,unsigned char ucOrder); **
- //** 输入一个数字以及所要显示的位置,在LED相应位置上显示相应数字. **
- //* ******************************头文件及宏定义************************** *
- #include "LED6Show.h"
- //* ********************************全局变量****************************** *
- unsigned char code uca_LEDCode[]=
- {0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xFF};
- //0,1,2,3,4,5,6,7,8,9,空白。
- unsigned char code uca_LEDSelect[]=
- {0x01,0x02,0x04,0x08,0x10,0x20};
- //分别点亮第6,5,4,3,2,1号灯。
- unsigned char uca_LedNum[6];
- //存放数字的各个位。
- unsigned char uc_NumberFront=1; //只是数字的首位。
- extern unsigned char uca_ShowCustom[]; //在自定义模式下,LCD实时显示该字符。main.c
- //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<自定义报告显示字符>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
- unsigned char uca_ReportChar1[]={0xBF,0x86,0xC0,0x88,0xBF,0xF9};
- //被除数等于0。 -EOR-1
- unsigned char uca_ReportChar2[]={0xBF,0x86,0xC0,0x88,0xBF,0xA4};
- //被减数小于减数。 -EOR-2
- unsigned char uca_ReportChar3[]={0xC6,0x89,0x88,0xC2,0xBF,0xF9};
- //表明从计算器模式切换到计时模式。 CHAG-1
- unsigned char uca_ReportChar4[]={0xC6,0x89,0x88,0xC2,0xBF,0xC0};
- //表明从计时器模式切换到计算器模式。 CHAG-0
- unsigned char uca_ReportChar5[]={0xBF,0x8C,0x88,0xC1,0x92,0x86};
- //暂停 -PAUSE
- //unsigned char uca_ReportChar6[]={0xBF,0x92,0x87,0x88,0x88,0x87};
- //开始 -START
- unsigned char uca_ReportChar7[]={0xBF,0x92,0x87,0xC0,0x8C,0xBF};
- //停止 -StoP-
- unsigned char uca_ReportChar8[]={0xC0,0x8C,0x8C,0xC0,0x92,0x86};
- //切换到倒计时模式 OPPPOSE
- unsigned char uca_ReportChar9[]={0xBF,0x86,0xC0,0x88,0xBF,0x90};
- //超出可显示的最大值。 -EOR-9
- //* ********************************函数实现****************************** *
- unsigned char * pucLedNum(unsigned long ulNumber) //将一个数的各个位分别存到数组里。
- { //并返回首地址。
- if(ulNumber>999999)
- ulNumber=999999;
- if(ulNumber<0)
- ulNumber=0;
- uca_LedNum[5] = ulNumber/100000; //最高位存在数组【5】中。
- uca_LedNum[4] = (ulNumber-100000*(long)uca_LedNum[5])/10000;
- uca_LedNum[3] = (ulNumber-100000*(long)uca_LedNum[5]-10000*(long)uca_LedNum[4])/1000;
- uca_LedNum[2] = (ulNumber-100000*(long)uca_LedNum[5]-10000*(long)uca_LedNum[4]
- -1000*(long)uca_LedNum[3])/100;
- uca_LedNum[1] = (ulNumber-100000*(long)uca_LedNum[5]-10000*(long)uca_LedNum[4]
- -1000*(long)uca_LedNum[3]-100*(long)uca_LedNum[2])/10;
- uca_LedNum[0] = (ulNumber-100000*(long)uca_LedNum[5]-10000*(long)uca_LedNum[4]
- -1000*(long)uca_LedNum[3]-100*(long)uca_LedNum[2]-10*(long)uca_LedNum[1]);
- //最低位存在数组【0】中。
- for(uc_NumberFront=1;uc_NumberFront<6;uc_NumberFront++)
- if(uca_LedNum[6-uc_NumberFront]!=0) //判断数据的首位不为零数字在第几位。
- break; //例如:8502的uc_NumberFront为3;
- } // 0的uc_NumberFront为6;
- // 450530的uc_NumberFront为1。
- return uca_LedNum;
- //* *****************************将1个1位数按顺序显示**************************** *
- void vShowOneNum(unsigned char ucOneNum,unsigned char ucOrder)
- if(ucOneNum!=0) //如果数字不为0则正常输出。
- LEDSELECT=0;
- LEDCHAR=uca_LEDCode[ucOneNum]; //ucOrder:1~6
- LEDSELECT=uca_LEDSelect[ucOrder-1];
- else
- if(ucOrder<uc_NumberFront) //如果为0则判断是不是在数字首位之前。
- LEDSELECT=0; //如果在则输出空,不显示数据。
- else
- LEDSELECT=0; //如果在首位之后则正常输出。
- //* ***************************将1个自定义字符按顺序显示************************* *
- void vShowCustom(unsigned char ucOneCostom,unsigned ucOrder)
- LEDSELECT=0;
- LEDCHAR=ucOneCostom;
- LEDSELECT=uca_LEDSelect[ucOrder]; //ucOrder:0~5
- //* ***********************将字符数组复制到字符显示数组中************************* *
- void vCharCopy(unsigned char ucaArray[])
- unsigned char ucCount;
- for(ucCount=0;ucCount<6;ucCount++)
- uca_ShowCustom[ucCount]=ucaArray[ucCount];
- //* ***********************根据报告代号,显示不同的报告字符************************* *
- void vShowReport(unsigned char ucSymbol)
- switch(ucSymbol)
- case 1:vCharCopy(uca_ReportChar1);break; //显示:-EOR-1--被除数等于0;
- case 2:vCharCopy(uca_ReportChar2);break; //显示:-EOR-2--被减数小于减数;
- case 3:vCharCopy(uca_ReportChar3);break; //显示:CHAG-1--表明从计算器模式切换到计时模式;
- case 4:vCharCopy(uca_ReportChar4);break; //显示:CHAG-0--表明从计时器模式切换到计算器模式;
- case 5:vCharCopy(uca_ReportChar5);break; //显示:-PAUSE--暂停;
- // case 6:vCharCopy(uca_ReportChar6);break; //显示:-StART--开始;
- case 7:vCharCopy(uca_ReportChar7);break; //显示:-StoP---停止;
- case 8:vCharCopy(uca_ReportChar8);break; //显示:OPPOSE--切换到倒计时模式;
- case 9:vCharCopy(uca_ReportChar9);break; //显示:-EOR-9--超出可显示的最大值。
- default:break;
复制代码 |
