单片机万年历的仿真原理图
- #define uchar unsigned char
- #define uint unsigned int
- #define DQ P3_7
- #include<AT89X51.H>
- uint sec;
- uint min=41;
- uint hour=18;
- uint day=14;
- uint month=9;
- uint yearl=6;
- uint yearh=20;
- uint tcnt;
- uint cursor=0;
- uchar a=0xff;
- uchar code Seg[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- void delay(uint t)
- uint i;
- while(t--)
- {for (i=0;i<125;i++);}
- void Tdelay(unsigned int i)
- while(i--);
- void Kdelay()
- uchar i,j;
- for(i=100;i>0;i--)
- for(j=248;j>0;j--);
- Init_DS18B20(void)
- unsigned char x=0;
- DQ = 1;
- Tdelay(8);
- DQ = 0;
- Tdelay(80);
- DQ = 1;
- Tdelay(14);
- Tdelay(20);
- //读一个字节
- ReadOneChar(void)
- unsigned char i=0;
- unsigned char dat = 0;
- for (i=8;i>0;i--)
- DQ = 0;
- dat>>=1;
- DQ = 1;
- if(DQ)
- dat|=0x80;
- Tdelay(4);
- return(dat);
- //写一个字节
- WriteOneChar(unsigned char dat)
- for (i=8; i>0; i--)
- DQ = 0;
- DQ = dat&0x01;
- Tdelay(5);
- DQ = 1;
- dat>>=1;
- //读取温度
- ReadTemperature(void)
- unsigned char a=0;
- unsigned char b=0;
- unsigned int t=0;
- float tt=0;
- Init_DS18B20();
- WriteOneChar(0xCC);
- WriteOneChar(0x44);
- Init_DS18B20();
- WriteOneChar(0xBE);
- a=ReadOneChar();
- b=ReadOneChar();
- t=b;
- t<<=8;
- t=t|a;
- tt=t*0.0625;
- t= tt*10+0.5;
- return(t);
- void display(uchar L1,uchar L2,uchar L3,uchar L4,uchar L5,uchar L6,uchar L7,
- uchar L8,uchar L9,uchar L10,uchar L11,uchar L12,uchar L13,uchar L14,uchar L15,
- uchar L16)
- P2=0x7F;P0=L1;delay(1); //yearh
- P2=0xBF;P0=L2;delay(1); //yearh
- if(cursor==6){P2=0xDF|a;P0=L3;delay(1);}else{P2=0xDF;P0=L3;delay(1);} //yearl
- if(cursor==6){P2=0xEF|a;P0=L4;delay(1);}else{P2=0xEF;P0=L4;delay(1);} //yearl
- if(cursor==5){P2=0xF7|a;P0=L5;delay(1);}else{P2=0xF7;P0=L5;delay(1);} //month
- if(cursor==5){P2=0xFB|a;P0=L6;delay(1);}else{P2=0xFB;P0=L6;delay(1);} //month
- if(cursor==4){P2=0xFD|a;P0=L7;delay(1);}else{P2=0xFD;P0=L7;delay(1);} //day
- if(cursor==4){P2=0xFE|a;P0=L8;delay(1);}else{P2=0xFE;P0=L8;delay(1);} //day
- P2=0xFF;
- if(cursor==3){P1=0x7F|a;P0=L9;delay(1);}else{P1=0x7F;P0=L9;delay(1);} //hour
- if(cursor==3){P1=0xBF|a;P0=L10;delay(1);}else{P1=0xBF;P0=L10;delay(1);} //hour
- if(cursor==2){P1=0xDF|a;P0=L11;delay(1);}else{P1=0xDF;P0=L11;delay(1);} //min
- if(cursor==2){P1=0xEF|a;P0=L12;delay(1);}else{P1=0xEF;P0=L12;delay(1);} //min
- if(cursor==1){P1=0xF7|a;P0=L13;delay(1);}else{P1=0xF7;P0=L13;delay(1);} //sec
- if(cursor==1){P1=0xFB|a;P0=L14;delay(1);}else{P1=0xFB;P0=L14;delay(1);} //sec
- P1=0xFD;P0=L15;delay(1); //temp
- P1=0xFE;P0=L16;delay(1); //temp
- P1=0xFF;
- main()
- uint i;
- TMOD=0x02; //设置模式为定时器T0的模式2 (8位自动重装计数初值的计数值)
- TH0=0x06; //设置计数器初值,靠TH0存储重装的计数值X0=256-250=6
- TL0=0x06;
- TR0=1; //启动T0
- ET0=1; //开启定时器T0中断允许
- EA=1; //开启中断总控制
- while(1)
- if(P3_0==0)
- Kdelay();
- if(P3_0==0)
- cursor++;
- if(cursor>=7){cursor=0;}
- if(P3_1==0)
- Kdelay();
- if(P3_1==0)
- if(cursor==1){sec++;if(sec==60)sec=0;}
- if(cursor==2){min++;if(min==60)min=0;}
- if(cursor==3){hour++;if(hour==24)hour=0;}
- if(cursor==4){day++;if(day==31)day=0;}
- if(cursor==5){month++;if(month==12)month=0;}
- if(cursor==6){yearl++;if(yearl==100)yearl=0;}
- if(cursor==7){yearh++;if(yearh==30)yearh=20;}
- if(P3_2==0)
- Kdelay();
- if(P3_2==0)
- if(cursor==1){sec--;}
- if(cursor==2){min--;}
- if(cursor==3){hour--;}
- if(cursor==4){day--;}
- if(cursor==5){month--;}
- if(cursor==6){yearl--;}
- if(cursor==7){yearh--;}
- i=ReadTemperature();
- display(Seg[yearh/10],Seg[yearh%10],Seg[yearl/10],Seg[yearl%10],
- Seg[month/10],Seg[month%10],Seg[day/10],Seg[day%10],Seg[hour/10],
- Seg[hour%10],Seg[min/10],Seg[min%10],Seg[sec/10],Seg[sec%10],Seg[i/100],
- Seg[i/10%10]);
- void t0(void)interrupt 1 using 0 //t0的中断程序
- tcnt++;
- if(tcnt==4000)//定时器的定时计数,4000次250us为1秒
- tcnt=0;
- P3_3=~P3_3;
- a=~a;
- sec++;
- if(sec==60)
- sec=0;
- min++;
- if(min==60)
- min=0;
- hour++;
- if(hour==24)
- hour=0;
- day++;
- if(month==2&&((yearl==0&&yearh%4==0)||(yearl!=0&&yearl%4==0))&&
- day==30)day=1;
- else if(month==2&&day==29)day=1;
- else if((month==4||month==6||month==9||month==11)&&day==31)day=1;
- else if(day==32)day=1;
- if(day==1)
- month++;
- if(month==13)
- month=1;
- yearl++;
- if(yearl==100)
- yearl=0;
- yearh++;
- if(yearh==100)
- yearh=20;
