查看: 6392|回复: 5
51单片机控制DHT11温湿度传感器在1602液晶屏上显示
ID:125275 发表于 2016-9-13 13:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg51.h>
#include <intrins.h>
typedef unsigned char BYTE;
typedef unsigned int WORD;
sbit io=P1^0;
sbit rw=P2^1;
sbit rs=P2^0;
sbit ep=P2^2;
typedef bit BOOL;
uchar data_byte;
uchar RH,RL,TH,TL;
void delay(uchar ms)
  uchar i;
  while(ms--)
  for(i=0;i<100;i++);
void delay1()
  uchar i;
  for(i=0;i<1;i++);
BOOL lcd_bz()
BOOL result;
  rs=0;
  rw=1;
  ep=1;
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  result = (BOOL)(P2&0x80);
  ep=0;
return  result ;
void write_cmd(uchar cmd)
   while (lcd_bz());
  rs=0;
  rw=0;
  ep=0;
  _nop_();
  _nop_();
  P0=cmd ;
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  ep=1;
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  ep=0;
void write_addr(uchar addr)
  write_cmd(addr|0x80);
void write_byte(uchar dat)
   while (lcd_bz());
  rs=1;
  rw=0;
  ep=0;
  _nop_();
  _nop_();
  P0=dat ;
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  ep=1;
  _nop_();
  _nop_();
  _nop_();
   _nop_();
  ep=0;
void lcd_init()
  write_cmd(0x38);
  delay(1);
  write_cmd(0x0c);
  delay(1);
  write_cmd(0x06);
  delay(1);
  write_cmd(0x01);
   delay(1);
void display(uchar addr,uchar q)
  delay(10);
  write_addr(addr);
  write_byte(q);
  delay(1);
void start()
  io=1;
  delay1();
  io=0;
  delay(25);
  io=1;
  delay1();
  delay1();
  delay1();
uchar receive_byte()
  uchar i,temp;
  for(i=0;i<8;i++)
   while(!io);
  delay1();
  delay1();
   delay1();
  temp=0;
  if(io==1)
   temp=1;
    while(io);
  data_byte<<=1;
  data_byte|=temp;
   return data_byte;
void receive()
   uchar T_H,T_L,R_H,R_L,check,num_check,i;
   start();
  io=1;
  if(!io)
while(!io);
while(io);
R_H=receive_byte();
  R_L=receive_byte();
T_H=receive_byte();
T_L=receive_byte();
check=receive_byte();
io=0;
for(i=0;i<7;i++)
delay1();
io=1;
num_check=R_H+R_L+T_H+T_L;
if(num_check==check)
   RH=R_H;
   RL=R_L;
   TH=T_H;
   TL=T_L;
   check=num_check;
  lcd_init();
     receive();
display(0x00,'R');
display(0x01,':');
display(0x02,RH/10+0x30);
display(0x03,RH%10+0x30);
display(0X04,'%');
display(0x40,'T');
display(0x41,':');
display(0x42,TH/10+0x30);
display(0x43,TH%10+0x30);
display(0x44,0xdf);
display(0x45,0x43);
参与人数 2黑币 +110 收起 理由
zwk34 + 10 共享资料的黑币奖励!
admin + 100 共享资料的黑币奖励!
收藏收藏1 分享淘帖 顶 踩
来自 6#
ID:718824 发表于 2020-4-1 22:25 | 只看该作者
无法显示,全是0
ID:33634 发表于 2016-9-13 21:35 | 只看该作者
谢谢啊,很不错.
ID:153553 发表于 2016-12-9 22:15 | 只看该作者
有仿真图吗?
ID:123712 发表于 2017-1-10 19:04 | 只看该作者
很棒的资料,学习中
ID:111637 发表于 2017-5-5 20:41 | 只看该作者
程序有问题  BOOL lcd_bz()函数内的P2应改为P0
